Author Topic: How ergo is the Alice design?  (Read 18979 times)
Offline jamster
« on: Sat, 06 June 2020, 22:36:28 »
I've been seeing Alice boards pop up in renders and other threads.
How 'ergonomic' are they, or is the key angling more of a cosmetic effect? Looks like the keys under the pinkies are canted back towards horizontal, which would require the wrists to kink out away from straight to frequently accessed keys such as Enter, Backspace and Shift.
I have found earlier posts on the Alice layout which talk about the design, but there's no mention of ergonomics.
Offline yuppie
Re: How ergo is the Alice design?
« Reply #1 on: Sat, 06 June 2020, 23:47:18 »
its not really, it just looks cool.
"Overall, it's a good community..  wish you well on your Pokemon Journey.." - TP4
Current Trades -- Wishlist
Offline yicaoyimu
« Reply #2 on: Sun, 07 June 2020, 00:49:39 »
It's better than traditional staggered layout for sure. I have been using Alice layout for a couple months and it really helps relieve shoulder pain.
Offline jamster
« Reply #3 on: Sun, 07 June 2020, 01:06:47 »
Do you need to kink your wrists a bit to access the outermost keys like on a straight board? e.g. Enter or Control?
(I guess different people need different amounts of 'ergo')
Offline squizzler
    • My blog
« Reply #4 on: Sun, 07 June 2020, 02:32:29 »
I am not familiar with such a design. Would somebody be so kind as to put a link to what we are talking about?
« Last Edit: Sun, 07 June 2020, 02:34:53 by squizzler »
Running RSTHD on Minidox since 2019
Offline jamster
« Reply #5 on: Sun, 07 June 2020, 02:57:44 »
Just Google "Alice keyboard" and it'll pop up. It looks a bit like a Microsoft Natural board.
« Last Edit: Sun, 07 June 2020, 03:02:53 by jamster »
« Reply #6 on: Sun, 07 June 2020, 03:21:45 »
I'd say that they are mostly for people who have developed muscle memory on Microsoft's "Natural" keyboards before discovering mechs.
But do check out Slice. and BuzzSaw.
Offline nevin
« Reply #7 on: Sun, 07 June 2020, 08:03:22 »
Alice is not very ergo. Yes, better than straight, angles help when you can't split the board. Splits are better, space between halves. Ortho is a pretty easy transition as well. You won't miss the wide keys as much as you think you will. (At least in my experience)
Research & explore all the wonderful keyboard options we have these days.
Figure out what you can & can't live with and find a board that fits your guidelines.
Offline harlekein
« Reply #8 on: Mon, 29 June 2020, 08:59:32 »
That's a very low bar to pass.
