Author Topic: QMK - VIA programming and keyboard macros  (Read 49907 times)
Re: QMK - VIA programming and keyboard macros
« Reply #50 on: Fri, 02 April 2021, 07:17:45 »
... you said the link was too hard so you had read it to find that out, right? :blank:  Actually you're right - it assumes you know where the file is.  Not great documentation.
Wherever your qmk_firmware folder is go in keyboards/id87/keymaps/via or default and edit keymap.c in a text editor.
It should be both, theoretically, as per: https://altcodeunicode.com/pound-sign-alt-code/
The windows alt codes for £ are ALT 156 or ALT 0163 - I've got AHK using 0163 without issue, but perhaps QMK only likes the three digit codes.
Thanks for clearing that up.  Why not have two codes to do exactly the same thing...  I love Windows :p
Offline phinix
« Reply #51 on: Fri, 02 April 2021, 09:18:01 »
Sorry, I have no firmware folder, I only have qmk configurator, all I have is hex and json file.
Offline phinix
« Reply #52 on: Fri, 02 April 2021, 09:58:15 »
I dont get it, it just stopped working...:(
OK, weird - it only works in web browser.
Not in Windows explorer or Word etc
« Reply #53 on: Fri, 02 April 2021, 10:35:00 »
QMK configurator being the website?  Looks nice but no macros, as far as I can see.
After building the GH60 via version the program detected the board and showed me something usable.  I put the code below and it was happy to save the macro, then set a key as that macro and saved a json so I guess it works but I have no idea what to do with the json file to test.
SS_RALT(SS_TAP(X_P0)SS_TAP(X_P1)SS_TAP(X_P6)SS_TAP(X_P3))
Offline phinix
« Reply #54 on: Fri, 02 April 2021, 11:27:04 »
Yes QMK configurator as a website. Plus QMK toolbox just for flashing with hex files.
I have a feeling like we are very close, but dont know how to make it work:(
Offline phinix
« Reply #55 on: Fri, 02 April 2021, 11:36:24 »
OK OK...
I got qmk_firmware folder, that website configurator - I used compile and got the whole thing now on my PC.
Went to keyboards/id87/keymaps/via, editing keymap.c file.
So I have all this :
Code: [Select]
#include QMK_KEYBOARD_H
const uint16_t PROGMEM keymaps[][MATRIX_ROWS][MATRIX_COLS] = {
[0] = LAYOUT_tkl_ansi(
        KC_ESC,           KC_F1,   KC_F2,   KC_F3,   KC_F4,       KC_F5,   KC_F6,   KC_F7,   KC_F8,        KC_F9,   KC_F10,  KC_F11,  KC_F12,    KC_PSCR, KC_SLCK, KC_PAUS,
        KC_GRV,  KC_1,    KC_2,    KC_3,    KC_4,    KC_5,    KC_6,    KC_7,    KC_8,    KC_9,    KC_0,    KC_MINS, KC_EQL,  KC_BSPC,            KC_INS,  KC_HOME, KC_PGUP,
        KC_TAB,      KC_Q,    KC_W,    KC_E,    KC_R,    KC_T,    KC_Y,    KC_U,    KC_I,    KC_O,    KC_P,    KC_LBRC, KC_RBRC, KC_BSLS,        KC_DEL,  KC_END,  KC_PGDN,
        KC_CAPS,       KC_A,    KC_S,    KC_D,    KC_F,    KC_G,    KC_H,    KC_J,    KC_K,    KC_L,    KC_SCLN, KC_QUOT, KC_ENT,
        KC_LSFT,            KC_Z,    KC_X,    KC_C,    KC_V,    KC_B,    KC_N,    KC_M,    KC_COMM, KC_DOT,  KC_SLSH, KC_RSFT,                            KC_UP,
        KC_LCTL,   KC_LGUI,   KC_LALT,                       KC_SPC,                              KC_RALT,   KC_RGUI,   LT(1, KC_APP),     KC_RCTL,      KC_LEFT, KC_DOWN, KC_RGHT
    [1] = LAYOUT_tkl_ansi(
        RESET,            _______, _______, _______, _______,     _______, _______, _______, _______,      _______, _______, _______, _______,   _______, _______, _______,
        _______, _______, _______, _______, _______, _______, _______, _______, _______, _______, _______, _______, _______, _______,            _______, RGB_HUI, _______,
        _______,     BL_TOGG, RGB_TOG, _______, _______, _______, _______, _______, _______, _______, _______, _______, _______, _______,        RGB_VAI, RGB_SAI, _______,
        _______,            _______, _______, _______, _______, _______, NK_TOGG, _______, _______, _______, _______, _______,                            BL_INC,
        _______,   _______,   _______,                      _______,                              _______,   _______,   _______,   _______,      BL_INC,  BL_DEC, RGB_MOD
[2] = LAYOUT_tkl_ansi(
        _______,            _______, _______, _______, _______,     _______, _______, _______, _______,      _______, _______, _______, _______,   _______, _______, _______,
        _______, _______, _______, _______, _______, _______, _______, _______, _______, _______, _______, _______, _______, _______,            _______, _______, _______,
[3] = LAYOUT_tkl_ansi(
pasting your bit here and have this.
Code: [Select]
enum custom_keycodes {
    UKPOUNDL = SAFE_RANGE,
    UKPOUNDW,
bool process_record_user(uint16_t keycode, keyrecord_t *record) {
    switch (keycode) {
    case UKPOUNDL:
        if (record->event.pressed) {
            // when keycod is pressed
            SEND_STRING(SS_LSFT(SS_RCTL("ua3")));
        } else {
            // when keycode is released
        break;
    case UKPOUNDW:
            // when keycode is pressed
            SEND_STRING(SS_RALT(SS_TAP(X_P0)SS_TAP(X_P1)SS_TAP(X_P6)SS_TAP(X_P3)));
        } else {
        break;
    return true;
What now?  :D
« Reply #56 on: Fri, 02 April 2021, 11:47:06 »
Random idea - added the 'macro' and built the via hex, the key now shows up as a seemingly random hex code in via but it still sends the right keys.  It's no use if you want to add more macros but you can do anything else including moving FN?
Or if you want to do this the proper (old fashioned) way you need to change the _____  which corresponds to the key you want £ on to UKPOUNDW then setup a compiler.  Pretty sure the compiler part was the main reason Windows users needed to make helpful GUIs to do this stuff, it's easy in Linux.
« Last Edit: Fri, 02 April 2021, 11:51:00 by suicidal_orange »
Offline phinix
« Reply #57 on: Fri, 02 April 2021, 13:12:59 »
I wanted to use this on all my keyboards with QMK, so ideally I would like to have this done proper way.
So now I would need to swap one of those ______ with UKPOUNDW and comply it.. somehow.
So that step would be the hard part?
I cant believe I cant find people who already tried this - at least someone in UK who uses ANSI keyboard would like to have £ sign handy, right?
I got rid of all ISO keyboards cause I hated to pay extra for ISO kits in caps sets. ANSI felt better anyway.
How can I now compile it to hex file?
« Reply #58 on: Mon, 05 April 2021, 04:23:10 »
Did you try adding this as a macro in via and loading the json to the board?
As to why no-one does this maybe it's easier to do it the other way round and say you have an ISO board?  Not sure what you prefer about ANSI, aside from @ and " swapping and the missing £ I couldn't tell you what the differences are...
Offline Keybadger
« Reply #59 on: Sat, 10 April 2021, 16:50:34 »
I wondered about this for ages also using an ANSI layout in the UK, as I mostly used Linux, I have a button for the compose key, which is a key designed for entering special characters.
I don't know why MS hasn't added this feature to Windows yet. Until they do you could do something like install 2 languages US standard and UK standard, then press win+space to swap between them and the £ symbol will be on 3 as normal then swap back.
Sent from my M2007J20CG using Tapatalk
