Author Topic: [GB] Trivium Keyboard - MP/Challenge TKL [Manufacturing]  (Read 35180 times)
Offline pear_voz
« on: Thu, 11 June 2020, 23:57:13 »
Greeting everyone
This is the GB thread for our beloved board.
IC Thread: https://geekhack.org/index.php?topic=104162.0
Keyboard Specifications:
Slope: 7.5*
Supported Layout:
PCB: Non-hotswap with USB daughterboard and Modular MCU with separated RGB and Bluetooth MCU support.
Mass: 3.1kg full assembled in all aluminum configuration and 7.5 kg in all brass configuration.
Chassis included: Main Body, Plate, Mounting Bracket, Rear Bar and Bottom.
Group Buy Form: https://forms.gle/f2mqdjMWtCgbjkmv6
Unit Quantity: 150
Estimated Shipping Date: September 2020
Group Buy Period: Saturday, June 20 to Saturday, June 27 - GMT+7, FCFS
Color List:
Anodized Colors:
1. Signal Red - RAL 3001
2. Jet Black - RAL 9005
3. Anthracite Grey - RAL 7016
4. Turquoise Blue - RAL 5018
5. Ivory -RAL 1015
Cerakote Colors:
1.Magpul
2.Rose Gold
3.Stormtrooper White
4.Snow White
5.Corvette Yellow
6.Jesse James Cold War Grey
7.Jesse James Eastern Front Green
8.Northern Light
9.Cobalt
10.Crimson
11.Burnt Bronze
Kits:
Base kit [480$]:
All aluminum chassis parts + 1x full kit PCB with RGB and Bluetooth module
Brass Upgrade:
Main body: Not Available
Plate: +25$
Rear Body: 80$
Bottom: +245$
Mounting Bracket: Not Available
Extra Aluminum Parts:
Main body:+265$
Plate:+20$
Rear Body:+80$
Bottom:+115$
Mounting Bracket: +55$
Extra Brass Parts:
Plate: +55$
Rear Body: +165$
Bottom: +365$
Extra PCBs:
Matrix PCB and USB board: +20$
RGB MCU:+15$
Bluetooth MCU:+35$
Cerakote Version: (Limited 20 kits) [+200$]
Note: The mounting bracket and plate will be anodized.
« Last Edit: Mon, 20 July 2020, 11:46:19 by pear_voz »
Trivium Keyboard Co.
Offline Signature
  • master of puppers
  • * Moderator
  • snoozing
Re: [GB] Trivium Keyboard - MP/Challenge TKL
« Reply #1 on: Wed, 17 June 2020, 07:34:53 »
Approved
Offline IOVERCALLHISTIOCYTES
« Reply #2 on: Wed, 17 June 2020, 22:30:33 »
7.5kg is the weight for the aluminum main body, brass bottom, brass plate, and brass rear? Or is 7.5kg the weight if the whole thing is brass (which isn't available as there's no brass main body)
Offline pear_voz
« Reply #3 on: Thu, 18 June 2020, 03:59:08 »
Yes mate, if the whole thing's made with brass, the approx weight is around 22kg
Offline pear_voz
« Reply #4 on: Thu, 18 June 2020, 04:03:52 »
New timeline: Since zFrontier cannot resolve the project with Shopify, I will host the GB by myself, the new GB Period is: From 9am Sat, June 20 till 9am Sat, June 27
« Reply #5 on: Thu, 18 June 2020, 10:48:08 »
......time zone?
Edit: 22kg might be a bit much, huh...
« Last Edit: Thu, 18 June 2020, 10:52:59 by IOVERCALLHISTIOCYTES »
Offline pear_voz
« Reply #6 on: Thu, 18 June 2020, 11:39:16 »
......time zone?
GMT +7 man :D anw making a 22kg case is quite pointless so that's why the main body is aluminum only :D
By the way, since zFrontier cannot organize the GB, our new vendor for China region will be Geekmaker. They will run the GB on Monday, June 22.
« Reply #7 on: Thu, 18 June 2020, 12:15:21 »
Hey thanks. So you’ll cover everywhere but China, and Geekmaker does China but starts ~2 days later?
Offline pear_voz
« Reply #8 on: Thu, 18 June 2020, 12:59:11 »
Yes, exactly :D
Offline Aiwanei
    • ThocKeys.com
« Reply #9 on: Thu, 18 June 2020, 13:44:05 »
Good luck with the sale, I'm excited to try to buy one.
« Last Edit: Thu, 18 June 2020, 22:39:22 by Aiwanei »
ThocKeys.com
Offline pear_voz
« Reply #10 on: Thu, 18 June 2020, 23:29:45 »
I'd like to explain a little bit about the cerakote price and the weight of the board.
Because the thickness of the ceramic coating layer is around 0.1mm and sometime thicker so in order to fit every parts perfectly (even in cerakote version, the mounting bracket and plate are still aluminum), I have to machine a different batch for the cerakote with different specs and the surface finish is also different, the blasting media is different too so the price is quite high for this keyboard.
About the weight. 22kg is the calculated mass for every part to be made in brass, including the main body. But even if the very large bezel and a hole to stick your hand inside, lifting something this small and weight that much is pointless so I won't make it. The full brass configuration only have the Bottom, the Rear bar and the plate to be made in brass, the main body and mounting bracket are still aluminum.
Offline sctang
« Reply #11 on: Fri, 19 June 2020, 14:29:09 »
Any anode sample pics by chance? Was hard to pin down what ivory would like like on google images.
Also, does anything go in those 3 holes on the side? They looked empty in the photo.
Looks great! Thanks!
Offline glowcloud
« Reply #12 on: Fri, 19 June 2020, 17:21:45 »
I'm glad this is finally going into GB! I was wondering, is the "rear body" just the red piece in the proto on the IC? Thanks
Offline pear_voz
« Reply #13 on: Fri, 19 June 2020, 21:04:10 »
I've updated the GB form and it's open now. Have fun guys!
Offline pear_voz
« Reply #14 on: Fri, 19 June 2020, 21:12:02 »
Well I did not have the Ivory sample but it will look similar to this
https://cdn.webshopapp.com/shops/142494/files/91423241/hothot-radiators-in-light-ivory-colour-ral-1015.jpg
On the side, there's a 45 degree bolt that connect the main body with the rear bar and it secure the whole keyboard
Thank you man, and yes, the rear bar is the red piece, here's a picture to clarify
Offline nikron
« Reply #15 on: Fri, 19 June 2020, 22:24:42 »
So QMK works with Bluetooth for this? Any pictures of the different color options?
Offline pear_voz
« Reply #16 on: Sat, 20 June 2020, 00:54:57 »
Yes, the QMK works. I don't have the real color sample pieces but I got the render images, take a look here: https://imgur.com/gallery/898iWvZ
Offline nikron
« Reply #17 on: Sat, 20 June 2020, 05:52:02 »
Well hopefully I got on time.
Offline brillwill
« Reply #18 on: Mon, 22 June 2020, 00:10:27 »
has anyone received any emails regarding this? Submitted the form but no response...
Offline pear_voz
« Reply #19 on: Mon, 22 June 2020, 01:44:54 »
As I said on discord, I will send the remaining invoice out today. We don't have an automated system since we're filling form, not order via website but don't worry, it's on the way.
Offline outterspacetits
« Reply #20 on: Mon, 22 June 2020, 10:34:53 »
GB runner contacted me and was very courteous answering and addressing questions. I look forward to the product.
Offline pear_voz
« Reply #21 on: Fri, 26 June 2020, 19:48:42 »
Only 1 hour left, go get it guys!!
« Reply #22 on: Mon, 29 June 2020, 21:59:51 »
same here. changed my order quick. Looking forward to this board.
Offline pear_voz
Hello everyone, I've sent every invoices out, please check your email and paypal for payment request. Thank you all.
Offline pear_voz
Process Update:
Re: [GB] Trivium Keyboard - MP/Challenge TKL [Manufacturing]
« Reply #25 on: Wed, 11 November 2020, 23:31:22 »
Any updates on this?
Offline ExcitingWriting
« Reply #26 on: Sun, 22 November 2020, 22:12:09 »
Would love to learn about any extras
« Reply #27 on: Sun, 27 December 2020, 20:22:26 »
Edit: there's an update coming!
« Last Edit: Mon, 28 December 2020, 10:33:40 by IOVERCALLHISTIOCYTES »
« Reply #28 on: Fri, 29 January 2021, 01:54:58 »
Been a month since you said there would be an update soon, and today, 1/29/2021, is 193 days since you last posted an update here.
« Reply #29 on: Wed, 10 March 2021, 02:03:33 »
233 days since we last got an update. Maybe today’s the day.
Offline hiddensong
  • this too shall pass
« Reply #30 on: Wed, 10 March 2021, 02:44:44 »
WOW! I'm not involved in the board but happened to land here and was reading as the board looked interesting. Although its going on a year since money was received and updates ceased. I sincerely hope there's a Discord or Insta or some way the participants are being informed on the status of this board. Good luck to everyone involved including the creator.
« Reply #31 on: Wed, 10 March 2021, 03:33:54 »
There’s no other source of updates to my knowledge. I’d been told an update was coming soon so I kept the money in past the PayPal protection limit, which in hindsight probably wasn’t the smartest move. In a pm I was told there were pictures of actual boards, but given that that might take...a minute? to post an Imgur link and then copy it here I’m doubtful.
Offline Rexcramer
« Reply #32 on: Wed, 10 March 2021, 04:05:22 »
There is a discord : https://discord.gg/7bsZbnQ.
The last relevant post on discord:
pearvn
 "Still waiting for the pcb. Good news is they're already at Vietnam customs
I'll try to grab it right after the national congress
If I failed to do that, we'll have to wait after Lunar New Year.
I'm sorry for the delay"
I only skimmed the discord since I didn't join the GB. If you want the full picture I suggest you join and see for yourself  :thumb:
« Reply #33 on: Wed, 10 March 2021, 05:11:53 »
pearvn
Good find thank you!
« Reply #34 on: Wed, 14 April 2021, 18:48:33 »
As today marks 268 days since the last official update here on geekhack, I figure I as one of the "buyers" (maximum sarcasm implied here) might as well share the discord updates.
pearvn — 01/26/2021
pearvn — 03/25/2021
The pcb is currently at smt assembly stage
Will finish soon
I was told months ago there was a picture of the finished boards, but i don't see that on the discord or here. Clearly what was at Vietnam customs in January wasn't finished PCBs.
« Reply #35 on: Tue, 18 May 2021, 20:56:35 »
https://imgur.com/a/KBbvcoy
Not my photo, but from the discord and I thought everyone should see. PCBs done too.
« Reply #36 on: Sun, 17 October 2021, 15:37:18 »
470 days later, with no updates on here or discord in months, I've asked for a refund. Unclear if they even got an ice cream machine out of it.
Offline emalider
« Reply #37 on: Sun, 17 October 2021, 20:54:58 »
Oof, I don't know if any updates will be coming. Looks like they were also involved with the Weaven board (https://geekhack.org/index.php?topic=107364.0), which was under Triviumtek for that IC. Going to Triviumtek's FB page (https://www.facebook.com/triviumtek/about), their last post was Jan 9, 2020 and clicking their link to their webpage errors out.
« Reply #38 on: Sun, 17 October 2021, 23:29:01 »
This translates to "I’m a broke-*** ***** and can’t be bothered to type to the people I scam."
"I'm really sorry but I can't refund. There's nothing more to update since the whole country is on lock down for almost a year and it still is."
Except…
https://imgur.com/a/fNPEjXI
Not exactly the whole country, is it?
« Reply #39 on: Mon, 18 October 2021, 20:09:06 »
https://imgur.com/a/pXkJ7sF
latest update. People who've DM'd me have vastly better reasons to ask for refunds on Weaven and MP/Challenge. We're not getting them.
Offline emalider
« Reply #40 on: Tue, 19 October 2021, 00:18:15 »
"Yea the boards are done, just being stored somewhere indefinitely since no one can ship out of a city of 9m."
Slimy. Sorry man.
« Reply #41 on: Fri, 10 December 2021, 11:35:35 »
“We’ll do weekly updates”
6 weeks later…no updates on discord. 508 days since they’ve updated here. Surely todays the day.
« Reply #42 on: Thu, 03 March 2022, 04:05:22 »
We cleared 600 days from GB close back in February. Still no boards. Maybe this’ll be the month.
Offline Vigrith
« Reply #43 on: Sat, 05 March 2022, 09:09:13 »
I know this isn't helpful given the current state of affairs for this specific GB but saving extreme extenuating circumstances (eg. knowing the runner personally), as soon as an update that is provided on Discord isn't posted to Geekhack within reasonable a reasonable timeframe and the window for dispute is still open on Paypal you file for a refund. This has saved plenty of people I know a decent amount of money, and includes other discord related red flags like "The GB will go live in 1h5m from now, join our Discord server for more information" from this same weirdo here in the Weaven IC, "geekhack is down so I'll just move the raffle to discord" like happened with the gskt (which personally saved me money), etc.
« Reply #44 on: Sat, 05 March 2022, 19:01:06 »
All good advice.
In the last few days there’s been some theater on discord about packing the Weavens and possibly the triviums. We’ll see. I’d be shocked if this actually delivered a functional board.
« Last Edit: Tue, 29 March 2022, 00:00:24 by IOVERCALLHISTIOCYTES »
Offline DukeEsquire
« Reply #45 on: Mon, 07 March 2022, 10:59:48 »
Sorry to hear about the folks that joined the GB, but I decide not to join after the weird and unexplained snaffu with zFrontier. The whole project smelled shady.
« Reply #46 on: Mon, 28 March 2022, 22:44:09 »
Anyone outside of Vietnam received tracking or a shipping invoice for this? On the Weaven channel, it was posted that all MP Challenge boards had shipped, which is news to me.
Sorta hate to bump this but I figure since Rukia quieted down all of you would appreciate something else
« Reply #47 on: Fri, 08 April 2022, 22:40:14 »
Probably fake news, but apparently there’s a deadline for Sunday to submit address changes for this board. I received no email or ping and saw it while I was in the discord to ****post.
