Author Topic: Best Cheap Stock Linears.  (Read 8538 times)
Offline wyz3
« on: Fri, 12 June 2020, 08:06:45 »
I am looking to buy new switches for my keyboard and I am looking to buy cheap linears.
Here's a list of some cheap linears:
- Gateron Yellow
-Gateron Black
-Gateron Clear
-Kailh Pro Burgundy
-Kailh Speed Silver
-Gateron Red
-Kailh Black
-Kailh Red
-Kailh Dark Yellow
-Kailh Box Dark Yellow
-Kailh Speed Dark Yellow
-Cherry Red
-Cherry Black
-Cherry Speed Silver
-Cherry Silent Red
-Cherry Silent Black
-Gateron Linear Silent Switches (Black, Yellow, Red and Clear)
-Kailh Box Red
-Kailh Box Black
-TTC Gold V2 Red
-Gateron Merlot
These are just some of the many linear switches, these switches I have listed are on NovelKeys. These switches cost under 0.40 each or $4 for 10.
If you have any other cheap linear switches you know, please tell me their names down below. Now onto the basis of the topic, stock switches. Stock switches are just switches with no modifaction (e.g lubing, filming the switch), basically the switch in its original state when you ordered it. I am not to keen to mod my switches and so I am curious to which cheap linears are quite good, without no modification. I have heard Kailh Box linears tend to be really good stock switches because of their box design but that also leads to the process of modding and opening the switch being harder. Gateron Yellows,I have heard are really smooth, but I heard that putting lube makes a pretty big difference so maybe they are not great stocks but more great for modding. This is pretty much I know about stock switches, if you know anything more about cheap and good stock linears then I'm listening. Thank you.
Offline rinkaan
Re: Best Cheap Stock Linears.
« Reply #1 on: Fri, 12 June 2020, 09:43:12 »
depends on the actuation weight you prefer, i tried then below
gateron milky whites (seems like only chinese site taobao carries this, as it contains a 67gm spring)
gateron black
gateron yellow
gateron red
i think of them all, stock i would think gateron blanks feels good but would have preferred to have it slightly more weight... so for me i decided that the gateron milky whites are the best since it also allows me to dye them to any color i want (note the POM stems are harder to dye)
i think you can also consider Alpacas and Durocks and JWK, but they are not as cheap as gaterons。。
https://item.taobao.com/item.htm?spm=a1z09.2.0.0.40ac2e8dV2InQL&id=557299446515&_u=c1msah9nb71f
Offline wyz3
« Reply #2 on: Fri, 12 June 2020, 10:08:53 »
Can you send a link to buy Gateron Milky Whites
Offline rinkaan
« Reply #3 on: Fri, 12 June 2020, 10:58:48 »
yeah i linked it previously on the chinese site. altho this belongs to Kbd fans, i cant seem to find it on their kbdfans english site.. the milky clears there are 35gm springs... only the chinese site has it in 67g springs... save u some money buying replacement springs.
in case you need films here are some
https://item.taobao.com/item.htm?spm=a1z09.2.0.0.40ac2e8dV2InQL&id=572489779365&_u=c1msah9n0c6e
and switch opener
https://item.taobao.com/item.htm?spm=a1z09.2.0.0.40ac2e8dV2InQL&id=610195340711&_u=c1msah9nee39
I can read chinese so i dont require translation, but you can try to see if you can find any forwarders in your country that can purchase on your behalf.
have fun!
Offline wyz3
« Reply #4 on: Fri, 12 June 2020, 11:30:26 »
Thx man.  :D
Offline ddrfraser1
  • RIP Neil
« Reply #5 on: Fri, 12 June 2020, 11:56:32 »
I keep hearing Ink Blacks are the best quality and value. Never actually tried them though. I've heard they're incredibly smooth.
Offline envyy24
« Reply #6 on: Fri, 12 June 2020, 12:22:52 »
Gateron linear + a vial of kryptox 205 is always my recommendation
Offline HungerMechanic
« Reply #7 on: Fri, 12 June 2020, 12:40:09 »
You are right about BOX switches and Gateron Yellows. BOX linears are said to be smoother than Cherry, but the BOX switches are more difficult to mod or don't take to lube as well.
Gateron Yellows are pretty much the go to for stock switches that are relatively smooth, and they can be made considerably better through lubing. They are a good bet for someone's first custom keyboard.
Go a little up the price scale and you can get the Durock linears. Like Alpacas and Mauves. They aren't so expensive if you can get a decent-sized order on a Group Buy. They are very smooth out-of-the-box, but they are a bit wobbly and plasticy-sounding. If you can both lube and film them, they become God-tier switches.
Offline konstantin
  • Formerly constexpr
« Reply #8 on: Tue, 16 June 2020, 21:06:39 »
You may be interested in Durock's L4, L6 and L7 lines of switches, as they are recolors of JWK linears similar to the ever-so-popular Alpacas, Marshmallows, Mauves, Tangerines, H1s etc. More details here.
Offline nathanchere
« Reply #9 on: Wed, 17 June 2020, 05:54:47 »
If I was on a tight budget and wanted linears I'd be going with either Gateron yellows or Cherry silent red (if I wanted silenced switches). Not the absolute cheapest but both well established with good reason.
Offline IronCheeks
« Reply #10 on: Wed, 17 June 2020, 07:47:03 »
Gateron Black Inks are bang for the buck in terms of availability and affordability, but they do come at the 70 g bottom out. Someone here mentioned JWK Linears and yes - they are basically recolors/base versions of Alpacas and Mauve and can be gotten at a low price, but with long shipping times if you are buying from AliExpress. I also would recommend NK_Creams on the higher end as they are now available again on NK for .65c/switch. Not exactly cheap, but are very good switches once lubed.
Offline Mekanist
    • Archetype
« Reply #11 on: Fri, 19 June 2020, 16:11:39 »
I'd have to agree here, in terms of bang for your buck, Blank Inks are the way to go. Its a bit more expensive than what you've budgeted, but theyre very nice switches. Silent or not, both are great.
Offline aclassynerd
« Reply #12 on: Tue, 01 December 2020, 09:35:55 »
and switch opener
have fun!
Yo thanks for this. I actually bought the films and the opener. Btw, you have any recommendations for a lubing station?
Offline treeleaf64
    • treeleaf64
« Reply #13 on: Tue, 01 December 2020, 14:00:50 »
How are black inks bang for your buck, they're like 70 cents a switch . . lol
Self advertisement
I think KTT Wine Red  are pretty good for stock linears, you can buy them from me at 0.15 a switch.
Everyone must pay the cat tax
Offline rinkaan
« Reply #14 on: Sat, 05 December 2020, 22:44:19 »
and switch opener
have fun!
20 key lubing station for 5 dollars
https://m.tb.cn/h.4UfpXPI?sm=cf9fa2
Maybe you can buy smaller ones and do in batches or 20. I got a 60 keys one but i found it hard to use all 60 keys at one time... This shop also have krytox lube mix
Sent from my Redmi K20 Pro using Tapatalk
Offline killyou
« Reply #15 on: Sun, 06 December 2020, 16:54:43 »
I'm a fan of Kailh BOX switches so I would recommend Kailh BOX Reds.
Offline treeleaf64
    • treeleaf64
« Reply #16 on: Mon, 07 December 2020, 09:29:01 »
Yeah I think kailh box are the nicest stock linears that I've tried
You don't need to lube them if you enjoy their stock smoothness
« Reply #17 on: Mon, 07 December 2020, 11:24:34 »
Kailh BOX Reds generally get good reviews, and there's something called ART BOX Reds, which are a variation produced for retailers in Korea. The housing is updated to work with Cherry-profile even with wrong-facing switches, and reviews say the ART BOX Reds are at least as smooth as regular BOX Reds. YMMV.
Offline treeleaf64
    • treeleaf64
« Reply #18 on: Mon, 07 December 2020, 15:46:56 »
Talked to friends who have them, they approve of them!
