Author Topic: Turning off signature views  (Read 8972 times)
Offline jamster
« on: Fri, 26 June 2020, 11:38:21 »
Is it possible to set an option so that user signatures are hidden?
I get that group buy participants are asked to advertise the projects they join, but this means that some threads more banner ad than original content.  This makes reading a thread especially hard on a phone screen, with its already reduced real estate.
For example, try scrolling through this thread on a phone:  https://geekhack.org/index.php?topic=106305.150
Offline dgneo
  • Supervillain
Re: Turning off signature views
« Reply #1 on: Fri, 26 June 2020, 12:43:03 »
If you go to Profile > Forum Profile, you can disable it from there.
Offline jamster
« Reply #2 on: Fri, 26 June 2020, 14:31:42 »
Many thanks. Profile updated.
