Author Topic: [GB] [RESTOCK] MAJA R2  (Read 118503 times)
Offline yummyhotdogwater
Re: [GB] Maja Ergo
« Reply #200 on: Tue, 05 January 2021, 22:53:17 »
Just received and had been using,my Maja for a month but both hot-swap plates for one of my keys fell off, and the whole wiring is messed up and I cant find anyone locally to fix it do you think there is a way to get another Maja PCB it doesn't have to be hot-swapped i just need something to replace my broken one thanks! ( i already contacted kbd fans and  they recommended fixing it myself but I don't have that many skills in spoldering) Anyway, i really enjoyed the MK hope you can get back to me.
Offline Vulcan
Re: [GB] Maja Ergo
« Reply #201 on: Wed, 06 January 2021, 01:09:16 »
Have you check aftermarket on reddit? Or if you can wait.. kbdfans is planing to stockup more maja pcb
Sent from my SM-A207F using Tapatalk
Offline hottrout
  • I'd Hit Dat Key
Re: [GB] Maja Ergo
« Reply #202 on: Thu, 07 January 2021, 08:06:31 »
I have noticed that while using the Maja with the wrist rest, if the wrist rest is touching the keyboard, it adds a really lovely sound signature to the board.  So much so that I think there could be something in this for future designs.  The wooden rest gives the solid board a deeper sound.  I really like it, if you got the wrist rest with your Maja, try it and let me know what you think.  (I imagine it really only works well with tactile switches, I used Kiwi in mine)
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
Offline prangano
Re: [GB] Maja Ergo
« Reply #203 on: Thu, 07 January 2021, 08:44:50 »
What are the screws I need to replace the case screws?
Offline Missingnumber
Re: [GB] Maja Ergo
« Reply #204 on: Tue, 23 March 2021, 08:44:55 »
I just saw another round is coming up on KBDfans. If I understand it correctly, it looks like it will be sold in-stock in May? I'm very tempted to get a second one, because the green one I own is my favorite keyboard even compared with more limited run ones. I'm considering either the gray or the blue for my work computer. It is crazy heavy, so the polycarb is also attractive.
Offline hottrout
  • I'd Hit Dat Key
Re: [GB] Maja Ergo
« Reply #205 on: Tue, 23 March 2021, 18:37:17 »
I love mine as well.  I could be tempted again for a PC version.
Systems -
  Keyboards -
Re: [GB] Maja Ergo
« Reply #206 on: Wed, 07 April 2021, 02:07:38 »
The Maja just came back in stock on KBDFans, if anybody wanted one and missed out.
Offline prognostics
Re: [GB] Maja Ergo
« Reply #207 on: Wed, 07 April 2021, 12:30:07 »
Thank you for letting me know  :thumb: I bought the second to last Rose Gold one for my SO.
Offline iceman2733
Re: [GB] Maja Ergo
« Reply #208 on: Wed, 05 May 2021, 16:53:27 »
anyone having issues with their maja just resetting the key layout by it's self? twice in a row i've woken up in the morning and booted up my pc and my maja has either had the left ctrl and caps lock swapped for some reason (not swapped in via, just the input is swapped despite the key not being switched in via) or the entire board has reset back to the default key layout. noticed sometimes when unplugging and replugging that the rgb would freeze up on my board and then after replugging again, it would reset. getting pretty annoying, is my pcb defective?
I just picked up this keyboard in the last drop, I am having this EXACT issue.  Everything from the RGB randomly freezing and keyboard locking up and the keymapping from VIA being lost randomly.  KBDfans sent me an updated firmware it seems to have fixed the start up it seems (not 100% still testing) however it has still lost any VIA keymapping randomly.
Were you able to find any solution??
Offline KurageOuji
Re: [GB] [RESTOCK] MAJA R2
« Reply #209 on: Wed, 05 May 2021, 17:43:06 »
Nope sorry, it happened once and then never again. Wish I could be of more help man.
Offline OmoideAeternum
Re: [GB] Maja Ergo
« Reply #210 on: Mon, 10 May 2021, 09:52:48 »
Do you know if this will restock every few months? Or was it just an extras drop?
