Author Topic: [IC] Trinite 60% keyboard case and Coast wrist rest  (Read 8548 times)
Offline Leighton13104
« on: Mon, 29 June 2020, 12:27:51 »
Hi I'm quite new to the keyboard Hobby and I designed this keyboard off the keycult 60% pcb. It has gasket mounted plates with a leaf spring design. Other colours and material options will be available if enough interest is shown. The keyboard should retail for 380- 420 USD (including pcb) and the wrist rest for 70-90 USD.
Plate available in:
Stainless Steel +20 USD
Brass +10 USD
Aluminum (included)
POM ( only available as extra ) + 25 USD
Weight available in:
Stainless Steel +40 USD
Brass +30 USD
Aluminum (included)
Case material- aluminium( maybe POM?)
Compatible with GH60 pcbs (DZ60, YD60MQ, etc)
5 degree typing angle
Celtic Knot engraving behind weight and on the bottom
USB C only
Updates :
No longer compatible with mainstream 60% boards. Only compatible with the keycult 60% pcb.
Reason for design change:
Bad placement for USB C Port as it would be protruding from the stainless steel weight
« Last Edit: Tue, 30 June 2020, 08:58:52 by Leighton13104 »
Offline bisoromi
  • Formerly Duwang
  • owo
Re: Trinite 60% keyboard case and Coast wrist rest
« Reply #1 on: Mon, 29 June 2020, 12:33:26 »
glwic, hope you stick around for a while
(credits to Kokaloo)
Offline SxM Designs
  • https://sxmdesigns.com
    • Website
Re: [IC] Trinite 60% keyboard case and Coast wrist rest
« Reply #2 on: Mon, 29 June 2020, 12:44:36 »
I like the design but this is so expensive even for a high end. Are you getting proxies for Eu?
« Reply #3 on: Mon, 29 June 2020, 13:16:25 »
Yeah thinking of proxies in the EU, US and Asia. If more interest I'll expand out more as I haven't yet got my hands on a prototype. And once everything is finalized price will drop when there is a larger batch price maybe 370-400 USD
« Last Edit: Mon, 29 June 2020, 13:19:19 by Leighton13104 »
Offline catamscott
« Reply #4 on: Mon, 29 June 2020, 14:50:59 »
not a bad looking keyboard, but feel like it's a little too inspired by the no1/60 and as a result doesn't really differentiate itself enough to consider buying this over a 1/60. the overall design is super similar and the mounting method looks to be largely identical. additionally, from the renders the front also looks a bit tall, and the corners look a bit too round imo. i do like the celtic knot engraving quite a bit though. i'd keep refining this design and make it a little more your own, but it looks like a good start  :thumb:
Offline NotYeMK
  • I will yeet your keyboard
« Reply #5 on: Mon, 29 June 2020, 14:53:21 »
Looks pretty good. I would get it if it doesn't have a max order quantity.
Offline KaosJ
« Reply #6 on: Mon, 29 June 2020, 14:57:07 »
Not a fan of 60% keebs but the design looks so damn good, gj  :thumb:
Offline NathanCVII
  • Weeb I am
« Reply #7 on: Mon, 29 June 2020, 16:20:29 »
Looks bootiful, would definitely consider buying.
Offline Hugs94
« Reply #8 on: Mon, 29 June 2020, 20:26:06 »
glwic, hope you decide to put the usb port down on the back side render somewhere.
Offline cyanide814
« Reply #9 on: Fri, 03 July 2020, 21:46:20 »
I'm in
« Reply #10 on: Fri, 03 July 2020, 21:53:02 »
corners have that weird off center thing going on with the wide side bezels but it's always nice to see new designers
Offline elmo
  • Hello I like keyboards
    • Elmo's keyboards
« Reply #11 on: Sat, 04 July 2020, 06:11:31 »
I hope that you are aware of the fact that the Keycult PCBs are not some "free for all" open source thing.
They are a copyright protected item and I highly doubt that you have the permission to use this pcb for your board.
Offline Icemanrec
« Reply #12 on: Wed, 14 October 2020, 00:03:50 »
is there a discord link?
