Author Topic: [GB] Tind: Series I [COMPLETED]  (Read 41312 times)
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« on: Tue, 30 June 2020, 13:00:39 »
Read this release paper on Mekanisk.com.
Visit store page.
Series I
Colors: Ultramarine or Dark Gray
Cornerstone: Copper
Units: 100
This keyboard is 100% designed by, CADed by, manufactured by and fulfilled by Mekanisk. Specifically me, LeandreN.
PCB designed by Wilba.tech.
Purposeful design
Mekanisk will always be heading away from established design norms to create something unique. With the Tind, we mix mechanical engineering with Norwegian nature.
In the Tind, you can find the sharp beveled mountainous edges seamlessly enclosing the rest of the keyboard, on the inside and under(hidden) you find the new Mekanisk Gasket System, and the purposeful copper cornerstone which contains the serial number.
Information
Tind is a high-end keyboard with a custom moulded self-aligning gasket system. The plate has total isolation. You just build your board, connect the daughterboard, throw it in and fasten the top from the bottom with screws.
The design of this keyboard started in 2017, right after Fjell R1 finished shipping. It has been a top mount, gasket mount, bottom mount, gasket mount(again) and I think I have finally found the recipe for a good silicone gasket keyboard. I want to have this mounting system available to use in future Mekanisk keyboards, and to finally prove that the solution works, is a huge milestone for me because it allows me to integrate gaskets in a good way into future designs, and develop good designs, faster.
The keyboard uses 12 custom moulded bottom gaskets that support the plate from the bottom as well from the sides by letting the plate rest on them. This mean that no alignment is needed. There are 12 corresponding small silicone gaskets that push the plate down from the top at the same places and creates a firm grip for the plate. The plate is totally isolated from the rest of the case. The bottom silicone pieces are thicker than normal keyboard gaskets.
The plates are designed from the ground up to support the keyboard in the best possible way. These do not support switch top removal.
Specifications and features
  • 60% keyboard
  • 8 degree typing angle
  • Heavily chamfered edges with refined design
  • Low profile front height
  • Full gasket isolation mount and seamless design
  • New plate designs with mild relief cuts
  • Custom molded silicone pieces for the top, bottom and under.
  • USB-C Wilba PCB with a centered daughterboard
  • VIA compatible PCB
  • Each keyboard is serial numbered
This article is continues under the photos.
Renders
Factory photos
Prototypes and renders will differ from final product. There are already decided adjustments. Factory photos are low quality and will show artifacts not seen in real life.
ANODIZED COLORS
Ultramarine: Beautiful Pantone 3035C inspired color. Blue with a hint of green.
Dark grey: Not the standard “warm gray”. This is a dark, cool gray. (Same as R1 grey)
PLATE MATERIAL
Available in ISO or ANSI. Possible half plates in both material and layout options.
Sandblasted brass
Carbon fiber
RAFFLE SPOTS: 100
KIT PRICE: $400
IN THE KIT
Tind top piece (Ultramarine / Dark grey)
Tind bottom piece (Dark grey)
12x Custom Molded Mekanisk Silicone Gasket System bottom gaskets
12x Mekanisk Silicone Gasket System top gaskets
4x Custom Molded Mekanisk Viewfinder Silicone Bumpons
Mekanisk Gasket Plate in sandblasted brass / carbon fibre (+ $25) with ISO or ANSI layout support
WT60-? PCB with an USB-C daughterboard
All necessary screws and tools for assembly
Packaging
Custom EVA foam, double cardboard shipping box.
SHIPPING
Shipping will only be done via DHL Express directly from our factory. If you are in Norway, your order will be shipped from Norway. Shipping cost has increased in 2020, expect a higher shipping cost than you normally would. Your countries taxes are not included in the price unless you are in Norway.
WHEN
We are aiming for a late June raffle, with November shipping. The raffle will be announced beforehand, and will not come as a surprise.
FAQ
Why are there no blocked corners or winkeyless options?
We need to limit all options as much as possible for this keyboard, so for this round, only the standard layout will be available. The next round we will supply different options and might include both blocked corners and winkeyless layouts.
Will there be more color options?
Not this round.
What does gasket/isolation mount mean?
To me, it means that the plate is isolated from the rest of the case in some way. There are many different methods that are used to achieve this. We developed our own.
Weight
Approx 1400g with brass plate. Unbuilt.
The status of this project is added to MEKANISK.XYZ so you can keep yourself updated there.
Thank you for reading.
« Last Edit: Mon, 08 February 2021, 03:09:43 by LeandreN »
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
Re: [GB] Tind: Series I - 60% Mekanisk Gasket Mount [RAFFLE 03.07.2020]
« Reply #1 on: Tue, 30 June 2020, 13:00:52 »
Reserved.
« Reply #2 on: Tue, 30 June 2020, 13:42:26 »
Approved :thumb:
Offline logo4poop
  • Talk to me on discord @logoooo
« Reply #3 on: Tue, 30 June 2020, 13:43:55 »
glwgb
LCK75 so lit
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #4 on: Tue, 30 June 2020, 13:47:50 »
Here are some renders of the cornerstone. Real photos will be available before friday.
Also, read this.
Offline konstantin
  • Formerly constexpr
« Reply #5 on: Tue, 30 June 2020, 13:58:20 »
Good luck to all participants!
Offline robrobro
« Reply #6 on: Tue, 30 June 2020, 13:58:40 »
I’m in!
Offline overhigh
« Reply #7 on: Tue, 30 June 2020, 14:03:54 »
sign me up
Offline txclack
« Reply #8 on: Tue, 30 June 2020, 14:24:40 »
Will the PCB have a relief cut?
Ultramarine is such a gorgeous color.
Offline dRnRcRr
« Reply #9 on: Tue, 30 June 2020, 14:53:06 »
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #10 on: Tue, 30 June 2020, 15:31:38 »
EDIT: No relief cuts like the WT60-D.
« Last Edit: Wed, 01 July 2020, 06:21:45 by LeandreN »
Offline santela
« Reply #11 on: Tue, 30 June 2020, 16:57:22 »
I want in!
Offline getlazy
« Reply #12 on: Tue, 30 June 2020, 17:10:37 »
looks awesome. still unsure if i would go brass or carbon plate though
Offline TofuOrganic
« Reply #13 on: Tue, 30 June 2020, 17:51:20 »
I will start praying for good RNG! Definitely in :)
Offline SxM Designs
  • https://sxmdesigns.com
    • Website
« Reply #14 on: Tue, 30 June 2020, 18:04:21 »
How do I get into the raffle?
Offline lakeboredom
« Reply #15 on: Tue, 30 June 2020, 18:16:07 »
will the raffle be a form posted here or from the store page?
Offline Tre3Cycl3S
« Reply #16 on: Tue, 30 June 2020, 18:24:41 »
I'm praying to RNG-sus so that I get a spot ><
QFR           HHKB Pro-2     JD45         VE.A                    XMIT 61-Key       JD40 Mk.II                    Realforce 87U     M65-A                 Custom:Annie      NightFox      Pearl                  E6-V2 R2                          Norbaforce
MX Blue     45g Topre        MX Blue     R5 67g Zealios     50g Hall Effect     Modded Gateron Red     55g Topre           R5 78g Zealios     62g Ergo Grey     Hako True     R9 62g Zilent     Lubed Holy Trash Panda     OG Sony BKE Domes
Offline pixelpusher
« Reply #17 on: Tue, 30 June 2020, 19:00:56 »
I fee like a full Carbon Fiber plate would fee the best, but interested in your opinion on the feel and sound of full vs half and CF vs Brass with this board
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #18 on: Tue, 30 June 2020, 19:33:16 »
Google forms posted here(And everywhere else) on the given time and date.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #19 on: Wed, 01 July 2020, 06:23:08 »
I personally like CF better than brass, but both are good options in this board.
This is not a "gasket for flex" board, it is more like a gasket for sound and soft bottom out.
I haven't had a chance to experiement with half plates.
Offline Nevermore012
« Reply #20 on: Wed, 01 July 2020, 09:32:20 »
hey leandre, do you know how long it will be finished? thanks a lot, looking toward to get one :))))))
Offline Paragon
« Reply #21 on: Wed, 01 July 2020, 14:52:26 »
I was wondering what time the raffle would be held on July 3rd since the title only says the date. The board looks great, I hope luck is on my side!
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #22 on: Wed, 01 July 2020, 15:26:13 »
Shipping date in November.
https://www.timeanddate.com/worldclock/converter.html?iso=20200703T160000&p1=187&p2=137&p3=179&p4=136&p5=240
Offline cyanide814
« Reply #23 on: Wed, 01 July 2020, 17:10:09 »
I'm beyond excited for this. I lose every raffle, I really hope I win this one.
Offline dRnRcRr
« Reply #24 on: Wed, 01 July 2020, 19:35:39 »
I wish you good luck and hope you score one.   I'm definitely in the same boat.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #25 on: Thu, 02 July 2020, 18:49:58 »
Product page is updated and has a lot of pictures available.
https://mekanisk.com/collections/tind/products/tind
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #26 on: Thu, 02 July 2020, 18:50:54 »
Offline keyboardkrill
« Reply #27 on: Thu, 02 July 2020, 19:27:27 »
nice copper plate; a pleasant surprise
Offline Clay333
« Reply #28 on: Thu, 02 July 2020, 19:41:29 »
I really hope I win this raffle. This boards looks incredible and it's designed by someone who can make a tray mount like no one else, so i can't wait to see what you can do with a gasket mount.
I do have a quick question. Will the plates and PCBs be readily available after the group buy. I am too scared to buy a board with only 1 plate and PCB, but if i knew they would be available in the future if needed it would be nice to save some cash up front.
Offline hkhawk
« Reply #29 on: Fri, 03 July 2020, 01:19:13 »
Wow, what is a copper plate like?
Offline pixelpusher
« Reply #30 on: Fri, 03 July 2020, 01:24:28 »
Slightly more dense than brass.  Similar firmness or perhaps a bit more flexible (very slight difference here).  Pretty much like brass but a tad heavier.
Offline hkhawk
« Reply #31 on: Fri, 03 July 2020, 01:27:26 »
Ooh, interesting! Thank you
Offline Carcha
« Reply #32 on: Fri, 03 July 2020, 06:44:24 »
My body is ready. I hope RNG-JC is too.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #33 on: Fri, 03 July 2020, 11:02:37 »
Offline cyanide814
« Reply #34 on: Fri, 03 July 2020, 11:05:05 »
Good luck everyone! I'm hoping for all of you and of course me :D
Offline Jo_hannes
  • You can never learn less. You can only learn more.
« Reply #35 on: Fri, 03 July 2020, 11:23:07 »
Good luck everyone, hope you're having a particularly good one today. :)
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #36 on: Fri, 03 July 2020, 11:29:58 »
Thanks for all the entries so far.
Offline santela
« Reply #37 on: Fri, 03 July 2020, 11:45:55 »
Lol I just lost out on buying an itx case, so hope this will work out. Can someone please just take my money today?
Offline Clay333
« Reply #38 on: Fri, 03 July 2020, 12:15:53 »
Entry submitted. I really hope I get lucky on this one. Assuming emails go out tomorrow? Will we get an email if we missed it or only the winners? Thanks for everything you do for the community. You are a true pioneer and I am particularly impressed with how you run the same board multiple times with slight revisions. It gets quite frustrating looking at a board and knowing that it's never going to be available again.
Offline Jyobah
« Reply #39 on: Fri, 03 July 2020, 12:19:55 »
looks great, color is by far one of the best.
Offline kaworu
« Reply #40 on: Fri, 03 July 2020, 13:29:05 »
Good luck everyone, thanks to LeandreN and everyone involved in this raffle.
Offline limenx
  • limenx#9145
« Reply #41 on: Fri, 03 July 2020, 15:13:22 »
An awesome board, good luck to everyone who entered the raffle :thumb:
Offline chowder266
« Reply #42 on: Fri, 03 July 2020, 15:32:52 »
good luck everyone! hoping for my first raffle win :)
Offline dRnRcRr
« Reply #43 on: Fri, 03 July 2020, 18:34:30 »
Results being sent out.   Good luck everyone.   I did not win.   Happy for those that did.
« Last Edit: Fri, 03 July 2020, 19:39:15 by dRnRcRr »
Offline honoka
« Reply #44 on: Fri, 03 July 2020, 18:44:21 »
Finally something to be excited about
« Last Edit: Fri, 03 July 2020, 19:01:33 by honoka »
Offline konstantin
« Reply #45 on: Fri, 03 July 2020, 19:27:55 »
Congrats to everyone who won!
Offline pixelpusher
« Reply #46 on: Fri, 03 July 2020, 20:39:10 »
No dice.  Kinda bummed.   Not gonna lie.  Guess I’ll look forward to Tind II
Offline santela
« Reply #47 on: Fri, 03 July 2020, 22:28:32 »
Didn’t win either, but congrats to those who did. Enjoy your very special keyboard this winter!
Offline ryptide11
« Reply #48 on: Sat, 04 July 2020, 00:58:44 »
Didn’t win either.  :(
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #49 on: Sat, 04 July 2020, 05:30:46 »
Hello.
I have sent out all the winning and losing mails.
If you haven't got one, contact support@mekanisk.co.
Unpaid spots will be reraffeled from the losers list.
Thank you so much!
