Author Topic: [IC] After | Noon - Two 65% Boards | ZTBoards x AEBoards (GB post pending)  (Read 40855 times)
Offline jubei
This looks great. A 65% with a rotary encoder is one of my board goals, but I only wish this had WK, hotswap, and RGB too. Hope this GB does well for future iterations
+1
Offline EvilemX8
Thanks all for tuning into the stream last night, we have some typing videos to show off some aspects of the board that we think are unique.
Here is the Noon typing test (Lubed Creams, half plate, 1.2mm flex cuts):
Here is the After typing test (Lubed H1 60g, half plate, 1.6mm flex cuts):
feature=youtu.be
While both flex the same amount, the After typing test video especially demonstrates it - pay attention to the alpha keys as phlop types with only regular typing pressure.
« Last Edit: Thu, 02 July 2020, 16:37:19 by EvilemX8 »
Offline Xemnova
Lovely boards, wish I could join in this. living in Alaska and seeing 'conus' is very depressing. I hope the GB goes well!
Offline adamjohari
Praying that this doesn't get promoted on Taeha or BT so that people that actually want one can get one.  ;D
After | KBD8X Mk2 | Prophet | Ducky One 2 Mini
GMK Laser | ePBT Kon MoMo | Infinikey Port | Sanctuary Rebirth PBT | GMK Deep Navy
Offline dstaar
there is a gap between Space and the purple Alt, that is larger than other gaps, in the e-white Noon prototype,
looks like it should be 1.5u but you used a 1.25u keycap, right?
« Last Edit: Thu, 02 July 2020, 23:10:15 by dstaar »
Offline junwon9710
Does this have any designs on the back? Also, do you guys allow users from outside of US to use proxy?
Offline PleaseBeMyFriend
  • formerly honsoo
  • reddit /u/PleaseBeMyFriend
No designs on the back, it's completely sterile.
And yes, you may use a proxy if you're located outside the US.
Offline EvilemX8
From the main post, right under the prototype picture:
"Prototype error visible here, with the right side blocker clearly placed incorrectly. This has since been fixed and will be reflected in the final product!"
Offline junwon9710
Can we use same proxy? My friend and I basically live in Korea using same proxy. Of course we will submit both of our raffles in each others house.
but I was wondering if we can use same address for proxy. Do we need to tell you guys about that beforehand?
Offline EvilemX8
Hey there, yeah, feel free to use the same proxy. We do have ways of telling a difference between what is legitimate or not :) Thanks for asking.
Offline junwon9710
Thank you!
Offline dstaar
ah, I was idiot!  the pictures are too attractive, I missed the words  ;D
« Last Edit: Fri, 03 July 2020, 01:28:09 by dstaar »
Offline hottrout
  • I'd Hit Dat Key
No ISO?
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
Offline ray160
Yooo where is the white wave pattern desk mat from?
The keyboard design is cool too. I like the spaced arrows in Noon a lot
Offline Diggidy
Very interested in the After.
You say plate will be half-plate Aluminum + others TBD - just curious what other materials you're most strongly considering?
Also, in this picture, is this weight something difference than brass? Are you experimenting with different weights?
Offline baksbaks
  • don't be so angry all the time
Here in Hawaii and feel the same way. Don't quite understand why US = CONUS, especially with similar shipping rates via USPS as a carrier. Was interested but time to get cucked again~ Good luck to all those that can enter!
  • formerly honsoo
The weight is brass, I'm not great at photos!
Sent from my SM-N975U1 using Tapatalk
  • formerly honsoo
We discussed it and we'll be allowing US as a whole, including Alaska and Hawaii.
  • formerly honsoo
We'll be allowing the US as a whole, please see my response below! Thank you :)
Offline arylated
Do you guys know when this would ship? Thanks
Offline sirpensir
super hyped for this!
Offline crd
  • Discord: crd#7617
These are both gorgeous. Nice work on the design and prototypes. Noon has stolen my heart with its classy minimal facade. Looking forward to all of this.
Offline Sabin
Lovely designs but I think I must be the only person who doesn't like WKL
Offline jubei
For the rotary/dial, can you please give an idea of what its currently mapped to in terms of function? I've only seen the Satisfaction with its LED to compare against. Thanks
Offline EvilemX8
You can map the rotary to anything you want. It is fully customizable. People use it often as a volume knob or brightness changer.
Offline EvilemX8
Timelines are extremely rough because of unstable world conditions. We estimate a 4 month minimum.
Offline mikeduran
No eu :(
« Reply #76 on: Sun, 05 July 2020, 10:04:21 »
I really like this, too bad we can't have it from europe :(
Offline japanesehorrorwriter
+1 of each. Amazing layout. Do a test with clickies next time...
Offline ArttVandelay
Great board. I want one :)
Offline musicgecko
can't unsee nintendo switch logo but rotated
Offline KBDfiend
both are great, but i'd choose the after over the noon. prefer the blocked off arrow keys.
Offline noorejji
Interesting Q&A section, gives off that budget Zambumon vibe.
Offline EvilemX8
In light of confusion despite all the info being in the main body of the post, I would like to clarify a few things:
- The bezels will be smaller, as we have said in the main body of the original post. Please, refer to the renders for the most up to date bezel sizes. The prototypes used M3 screws, but final production units have M2.5 screws instead.
- I can't believe I have to say this a million times, but the Noon prototype has an error in it and has since been fixed for final production, the gap between arrow keys and right blocker is NOT intended.
- These are TWO different keyboards.
To all who have read the IC, negative and positive feedback alike, thank you - love to hear it.
Offline Roastteed
****ing sick ass keyboard, Its really cool! i love the knob on the afters very much what i was looking for. The only problem is i am poor, and my parents wouldn't never let me spend 500 on a keyboard.
Offline EvilemX8
GB post has been approved! Please find it here with most up to date info:
https://geekhack.org/index.php?topic=107414.0
Offline erbedama
Zt. and ae. did you guys happen to play team fortress classic back in the day? Zt and ae were two really good clans back then.
