Author Topic: [GB]Bear 65% ergo keyboard-(28th July. -> payment checking)  (Read 99819 times)
Offline ronnie_gogs
Here I thought I was done buying new keyboards...  ;D
Offline eyedrop
Re: [GB]Bear 65% ergo keyboard- Gasket mount
« Reply #51 on: Wed, 15 July 2020, 21:01:54 »
i know that it's none of our business, but i would appreciate it if you would share approximate sales numbers. again, you don't have to, but i would appreciate it.
thanks.
He just mentioned right above your post that he will release the spreadsheet after the GB concludes.  You will know how many participates then.
Offline Ultimatum
I’m in.
Offline thanatic
Question 1: About the pink and blue coating. Is this the smooth soft touch coating you find on some OEM keyboards and mice? (e.g. Logitech) If so, this is not soft touch coating that turns into sticky surface later correct?
Question 2: The standard kit already comes with the brass bear weight included in the base price correct? The question in the form for +$45 (e-white, ano black, e-yellow) that is for coloring the bear weight? I just want to clarify.
Thank you.
Offline Daniel
Yes, the brass weight is the default one. The others for $45 are extra.
Offline bukowski
I am in.
Offline FruityMcSwirl
Absolutely no way this is gonna be done in the projected 5 months + QC with so many people joining. Godspeed friend.
Offline jacky
Please wait patiently,after GB end all spreadsheet will relase then you can request you orders !but only once !
Thanks all ,we still have one and a half hours for GB
Offline jacky
I have been said 4-5 monts ,early 2021
Offline plabeleda
Re: [GB]Bear 65% ergo keyboard- Gasket mount(Last hour)
« Reply #59 on: Thu, 16 July 2020, 08:30:22 »
I Yeet-ed! First international keyb i joined in! Question though. For the Hotswap version, does it support 5 pin switches? or only 3 pin switches?
Offline jacky
« Reply #60 on: Thu, 16 July 2020, 08:38:33 »
5
Offline jacky
Re: [GB]Bear 65% ergo keyboard- Gasket mount(Last 3 min)
« Reply #61 on: Thu, 16 July 2020, 09:01:08 »
Thansk to all ,Gb closed!  My 2nd GB  :thumb:
Offline aadk5
  • AKA: feeebleminded
« Reply #62 on: Thu, 16 July 2020, 10:19:12 »
Thanks again for the GB! I was super excited for this and glad I got in as soon as the GB opened and didn't wait
Offline beekey
« Reply #63 on: Thu, 16 July 2020, 13:10:37 »
Congratulations! Looking forward to 3rd GB - The Hippo, HHKB with oil suspended plate. :)
Offline 3ambutter
Re: [GB]Bear 65% ergo keyboard- Gasket mount(GB closed )
« Reply #64 on: Thu, 16 July 2020, 19:41:35 »
Congrats on the HUGE gb. GL w/ production!
Reborn60 | Keycult No.1 Rev.1 | SKB60 | TGR x SINGA UNIKORN | GSKT-00
Offline tonyjones
  • I like big butts and I cannot lie.
« Reply #65 on: Thu, 16 July 2020, 22:43:48 »
Great work Jacky on the design!
Offline thanatic
« Reply #66 on: Thu, 16 July 2020, 23:20:37 »
Whoops GB closed and filled up already? Missed this one.
Offline jacky
« Reply #67 on: Fri, 17 July 2020, 01:30:15 »
THANKS :thumb:
Offline jmarocchi
« Reply #68 on: Fri, 17 July 2020, 09:54:17 »
Have all invoices gone out yet? I caught the tail end of the form submission so I’m hoping it went through.
Offline eyedrop
« Reply #69 on: Fri, 17 July 2020, 12:33:13 »
It is very late for jacky, this just got posted on discord.
Here is the order check spreadsheet for Bear.
https://bit.ly/2OyWYT9
If you need to make any changes to your order, please fill out this form:
https://forms.gle/qnnMhJqncadkLTiu9
The edit request form will be closed on Sunday, and he will start sending out invoices on Monday.
Offline yookwh
« Reply #70 on: Fri, 17 July 2020, 15:18:26 »
So I got the FE version, and ordered a non-FE version. I don't see the FE on the google doc - if I wanted just that and not the FE, do I submit to cancel the latter only?
Offline jacky
« Reply #71 on: Fri, 17 July 2020, 20:28:35 »
You can pm me for the fe spot ,non fe if you need change orders fill the form
Offline yookwh
Re: [GB]Bear 65% ergo keyboard- Orders check
« Reply #72 on: Fri, 17 July 2020, 22:16:37 »
Cool cool, thanks. Cancelled the non-FE and I'll keep the FE
Offline Яain.
« Reply #73 on: Fri, 17 July 2020, 22:53:50 »
i missed my most anticipated GB of 2020 so if anyone has an extra baby blue or PC please let me know!
Offline korea
« Reply #74 on: Fri, 17 July 2020, 23:12:59 »
Good luck with the GB!
May
Offline jacky
Edit Form will be closed on Sunday 12:00 pm (noon) EDT ,make sure you orders were correct
« Last Edit: Sat, 18 July 2020, 00:59:41 by jacky »
Offline jacky
Friendly reminder: last 12 hours to get your edit in before the order is locked 。invoice will be send soon
Offline beekey
Would love to get a fitting wrist rest. Any ideas if existing ones fit?
Offline Daniel
Jacky said that a wrist rest will be made at some point.
                      Other info:Wood wrist be available when shipping
Offline nevillesidhu
I edited my order yesterday, and it shows my order as confirmed but no changes where made??
Offline ZongZiWang
Hi, I didn't find any edit request from your geekhack ID, any chance you edit the order under your discord username? If you use discord, please ping the mod to verify your change.
Yeah i used my discord name and number to edit order. Im not really that familiar with discord but i will give pinging him a shot. Thanks
Offline jacky
Have any problem PM me on discord
Ty
Offline jacky
Re: [GB]Bear 65% ergo keyboard- Orders check (Invocied)
« Reply #83 on: Mon, 20 July 2020, 11:16:17 »
(Invoiced),check you email in time ,you can also join discord would be easy to reach us !
thanks
« Last Edit: Mon, 20 July 2020, 15:00:54 by jacky »
Offline plabeleda
Re: [GB]Bear 65% ergo keyboard- Orders check (Invoiced)
« Reply #84 on: Mon, 20 July 2020, 14:39:08 »
Hi Jacky,
Sorry quite new to this invoicing and I'm at work so couldn't check discord. What email address are we expecting the invoices to come from? would it be from Paypal?
Offline loud_asian
« Reply #85 on: Mon, 20 July 2020, 23:30:18 »
Hi Jacky,
The invoice should go to your paypal email
Offline jacky
« Reply #86 on: Tue, 21 July 2020, 11:54:46 »
All invoices are sent out! If you still haven't received invoice, please contact me. it's possible missed your invoice or you didn't provide a valid PayPal email to begin with.
Again, huge thanks for the patience for Bear GB! We know PayPal is not friendly to GB runner and we're trying our best to make this GB as smooth as possible.
 - About failure to pay PayPal email 33341862**@qq.com or 1413279***@qq.com: due to some limitation, we are fixing it, ETA in another 24 hours. You can retry paying, but if it still fails, you should retry tomorrow.
 - About deadline to pay the invoice: previously we were giving 5 days for you to pay, since we have the PayPal account issue right now, we will extend it to 7 days for you to pay, hope that will give you enough time.@everyone:heart: :emoji_1: :money_with_wings:
Best way was join discord .
Offline jacky
Re: [GB]Bear 65% ergo keyboard- Orders check (Payment deadline 28th)
« Reply #87 on: Wed, 22 July 2020, 23:14:48 »
Payment deadline was 28th ,July
make sure you are going for this ,we are not plan to do R2
THANKS
Offline jacky
« Reply #88 on: Mon, 27 July 2020, 07:59:53 »
Reminding :
Our payment deadline was 28th,July .after deadline we will move unpaid orders and cancel the invoice .if you have any special request please let me know
discord ID: jacky#8508
« Last Edit: Mon, 27 July 2020, 08:01:46 by jacky »
Offline jacky
Re: [GB]Bear 65% ergo keyboard-(28th July. -> payment deadline )
« Reply #89 on: Thu, 30 July 2020, 08:25:40 »
Last day for payment checking .
Offline JimmyJim
Re: [GB]Bear 65% ergo keyboard-(28th July. -> payment checking)
« Reply #90 on: Wed, 05 August 2020, 11:16:51 »
Do you have a pic of GMK Bento on blue?
Offline loud_asian
« Reply #91 on: Thu, 03 September 2020, 01:49:43 »
Hi jacky, any updates?
Offline Minterly
« Reply #92 on: Mon, 14 September 2020, 11:49:30 »
I've uploaded a VOD of a build stream:
Jacky sent me an e-white case/pc plate combination to try out. Scrub through/skip to the end for a complete build and sound test!
Offline Minterly
« Reply #93 on: Wed, 16 September 2020, 15:52:46 »
Sound test with stock Alpacas:
Offline aadk5
« Reply #94 on: Wed, 16 September 2020, 16:17:55 »
Oh. My. God
I didn't know I wanted this type of sound test until now lmao. All sound tests should be made like this moving forward
Offline Minterly
« Reply #95 on: Sat, 19 September 2020, 12:36:55 »
Ok last one.
Offline cloudtastrophe
« Reply #96 on: Mon, 21 September 2020, 07:22:02 »
I am still really sad I missed this board. I thought i had more time but the GB ended a lot earlier than the original announcement said it would..and bliss looks SOO GOOD on this board.
Offline dakatisshort
« Reply #97 on: Sat, 03 October 2020, 00:19:45 »
Damn, this board is so nice. Really wished I was into this hobby earlier to catch this.
Offline Donosir
« Reply #98 on: Wed, 28 October 2020, 08:22:20 »
Oh man, wish I had, had a chance at this board. I'm guessing that a round 2 (if such a thing will exist) would probably not be until mid-July at the earliest huh.
Well in any case if there needs to be an abundance of interest for that to happen I'm voicing my interest now!
Offline beekey
« Reply #99 on: Wed, 28 October 2020, 12:02:22 »
On discord Jacky mentioned that there will be no R2.
