Author Topic: Mysterium QMK RGB LED Underglow  (Read 3560 times)
Offline d1554573r
« on: Tue, 21 July 2020, 16:05:28 »
Hi Everyone,
I was wondering if it is possible to add a QMK RGB underglow with a WS2812 strip to the Mystrium PCB?
Adding a standard single-color strip should be as easy as soldering led to the proper 5V and GND pins on the PCB/chip, since I'm kinda new to the electronics part I was wondering where DIN should be connected to enable QMK RGB control?
So far I've only managed to find a tutorial that showcases how to achieve this with a pro micro controller: https://github.com/nicinabox/lets-split-guide/blob/master/rgb-underglow.md
« Last Edit: Tue, 21 July 2020, 16:08:36 by d1554573r »
