Author Topic: HHKB Question  (Read 2855 times)
Offline rgleas
HHKB Question
« on: Fri, 24 July 2020, 10:13:21 »
May I ask, what is the difference between:
A.) Happy Hacking Keyboard Professional Type-S
and
B.) Happy Hacking Keyboard Professional Hybrid Type-S
Offline powwu
    • Discord
Re: HHKB Question
« Reply #1 on: Fri, 24 July 2020, 10:15:44 »
The hybrid has USB-C, Bluetooth, and remappability, the original has Micro-USB and neither of the aforementioned features.
Offline rgleas
Re: HHKB Question
« Reply #2 on: Fri, 24 July 2020, 10:26:00 »
Awesome thanks for the help. Do you think USB-C is worth the extra? I can care less about Bluetooth, and shouldn't need to remap anything.
Offline powwu
    • Discord
Re: HHKB Question
« Reply #3 on: Fri, 24 July 2020, 10:36:19 »
If you only want the USB-C, might I recommend the classic? It's the same as the hybrid without Bluetooth (and there is a workaround for remappability if need be)
Offline rgleas
Re: HHKB Question
« Reply #4 on: Fri, 24 July 2020, 11:07:34 »
Great, thanks again!
Offline WholesomeDucky
  • lemme get uhhhhhhhhhhhhh bread
Re: HHKB Question
« Reply #5 on: Fri, 24 July 2020, 11:16:01 »
You can also get a regular HHKB 2 and get one of Hasu's USB controller boards. There's a version that has USB-C and has QMK support.
12 years of spending money on typing
"Name checks out" -Kustoms, 2020
Discord:wholesomeducky
Inbox always open, for whatever reason.
Offline rgleas
Re: HHKB Question
« Reply #6 on: Fri, 24 July 2020, 17:36:01 »
Another question, why would BKE Ultra Light Redux domes be superior to stock on HHKB Pro 2 Type-S?
« Last Edit: Fri, 24 July 2020, 23:28:26 by rgleas »
Offline powwu
    • Discord
Re: HHKB Question
« Reply #7 on: Sat, 25 July 2020, 00:03:31 »
Preference. Get a sample, and if you like the BKE domes more, swap em in
Offline rgleas
Re: HHKB Question
« Reply #8 on: Sat, 25 July 2020, 00:04:39 »
Sounds good! Thanks again for all your advice!
