Author Topic: [GB] KAT Cyberspace - FINISHED - 720k units sold!  (Read 387371 times)
Offline KVLT
Re: [GB] KAT Cyberspace - GiD! Box60 Case! 180% MoQ week 1! Thank you!!!
« Reply #100 on: Tue, 11 August 2020, 11:38:09 »
I hope this better explains how each of the alpha kits will look
That picture is super helpful.  I didn't realize the purple will glow.
the glow of the purple has a bit more blue of a glow and i friggin love this set more than before
the bad guy wins in this one
Offline ttom
  • Formerly tvaro
Re: [GB] KAT Cyberspace - GiD! Box60 Case! 230% MoQ week 1! Thank you!!!
« Reply #101 on: Tue, 11 August 2020, 18:53:32 »
great sales, much deserved <3
Hoarder Collector and designer
Classifieds
Offline saltimate
« Reply #102 on: Wed, 12 August 2020, 07:59:11 »
will the box60 come with the stickers when ordered from dailyclack?
the previews on dailyclack aren't showing them...
Offline Ulliam
  • Formerly Papithered
  • 𝖚𝖑𝖑𝖎.𝖆𝖒
« Reply #103 on: Wed, 12 August 2020, 09:57:42 »
They will for sure (:
Offline Vizir
« Reply #104 on: Wed, 12 August 2020, 10:38:55 »
will the boardwalk pcb work with the box case?
Offline Hell-es
« Reply #105 on: Wed, 12 August 2020, 12:19:11 »
The picture is super helpful - wish there were raw blanks or/and mods for a white bulit
Offline Lazy_Borzoi
« Reply #106 on: Wed, 12 August 2020, 23:19:16 »
I second that!
Maybe next round?
Offline The.Ryan.Gamer
« Reply #107 on: Thu, 13 August 2020, 05:38:22 »
Hi. I'm from Asia, where to i buy? ZF appears to be China only.
Offline Ulliam
  • 𝖚𝖑𝖑𝖎.𝖆𝖒
Offline xwind
« Reply #109 on: Thu, 13 August 2020, 09:29:30 »
I am ready to pull the trigger on a GB but lemme ask something first:
- Does the stepped CapsLock has an off center stem? I can always use 1.25u CapsLock instead, but buying 40's kit for one cap is a bit of an overkill.
- Does the 6.25u Spacebar has an additional cherry style 11.9 mm off center stem as well?
Offline I5 20VT
« Reply #110 on: Thu, 13 August 2020, 11:23:04 »
So first post here. I´m quite new to the hobby, been stalking here for some time and joined the occasional GB. Mechs is quite the rabbit hole...
With that said, this GB peaked my interest, but I have a silly question.
Say, I wanted color matched alphas for a ISO Nordic 75% keyboard, what kits do I need?
The Alpha/Alpha + Omega/North + Mods?
Or Omega/TKL + Omega/North + Mods?
I´m asking because the Alpha/Alpha and Omega/North looks like it has off white legends while TKL kit has greenish legends. Sorry for the confusion.
Offline Ulliam
  • 𝖚𝖑𝖑𝖎.𝖆𝖒
« Reply #111 on: Thu, 13 August 2020, 14:55:39 »
- Like a normal stepped caps? as in one used for a hhkb layout? if so then yes.
- It does
Alpha:Alpha + North + Mods is what you want.
The TKL kit is just designed to cover "normie" ansi tkl's like the filco etc at a decent price.
Offline xwind
« Reply #112 on: Thu, 13 August 2020, 15:31:44 »
Never had to deal with HHKB in person, and Google was not helpful in that regard either. Could you explain for a noob again: where is the stem located on the 1.75u Stepped CapsLock?
I need something like this:
Offline Ulliam
  • 𝖚𝖑𝖑𝖎.𝖆𝖒
« Reply #113 on: Thu, 13 August 2020, 16:27:13 »
You're good!
Offline I5 20VT
« Reply #114 on: Thu, 13 August 2020, 17:51:00 »
Thank you for clarifying, much appreciated.
Offline Vizir
« Reply #115 on: Thu, 13 August 2020, 18:19:32 »
No one knows if the boardwalk PCB will work with the box case?
Sent from my Pixel 4 XL using Tapatalk
Offline Ulliam
  • 𝖚𝖑𝖑𝖎.𝖆𝖒
« Reply #116 on: Thu, 13 August 2020, 18:58:03 »
I'm going to assume yes, because it states the boardward is designed to fit in standard 60% cases and thats what this is. Check out the DZ60 pcb https://www.reddit.com/r/MechanicalKeyboards/comments/532yj4/60_pcb_dimensions/ should help you check.
Offline Vizir
« Reply #117 on: Thu, 13 August 2020, 21:46:12 »
Offline Ulliam
  • 𝖚𝖑𝖑𝖎.𝖆𝖒
Re: [GB] KAT Cyberspace & BBox60 Case! (GIVEAWAYS ANNOUNCED) 250% MOQ
« Reply #118 on: Fri, 14 August 2020, 06:01:13 »
Currently running a Giveaway on my Discord server, check the top of the first post for more info or heres a link to join (: https://discord.gg/njbnkAF Thank you everyone for helping make this set happen I've been beyond blown away by the support i've received so far (:
Offline xwind
« Reply #119 on: Fri, 14 August 2020, 12:32:51 »
You're good!
Many thanks, ordered! And thanks for work!
Offline Yilk81
Re: [GB] KAT Cyberspace & BBox60 Case! (GIVEAWAYS) 250% MOQ
« Reply #120 on: Sun, 16 August 2020, 09:55:52 »
Ordered!
Raw alphas (common! these are just too cool)
eng/katakana alphas (extreme high cyber feel over the rest of them)
colevrak kit (i'll throw these in for my colemak layout. Might make it look more cyber to have single legend sprinkled in. We'll see. not a fan of eng alphas so didn't go for that one)
Ortho mods (split keebs only for this guy. Thanks for splitting up the 40's and ortho :) )
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #121 on: Sun, 16 August 2020, 16:15:38 »
<-- progress
« Last Edit: Tue, 18 August 2020, 02:12:24 by dvorcol »
Offline tomatohammado
« Reply #122 on: Sun, 16 August 2020, 17:46:39 »
SO excited for this set! The Icon Mods picture doesn't explicitly say the sizing of the R1 Shift keys, I want to confirm that it include the following sizes:
2.75U
2.25U x2
1.75U
1.25U
It looks like it does but I wanted to make sure, thank you!
Offline Ulliam
  • 𝖚𝖑𝖑𝖎.𝖆𝖒
« Reply #123 on: Mon, 17 August 2020, 04:54:48 »
2.75U
2.25U x2
1.75U
1.25U
They do indeed.
Offline Ashen_21
« Reply #124 on: Mon, 17 August 2020, 05:06:37 »
Bought and so keen!
Offline dvorcol
« Reply #125 on: Mon, 17 August 2020, 15:57:24 »
<-- progress
« Last Edit: Mon, 24 August 2020, 17:30:51 by dvorcol »
Offline Ulliam
  • 𝖚𝖑𝖑𝖎.𝖆𝖒
« Reply #126 on: Mon, 17 August 2020, 22:31:56 »
Thank you so much for these dude, your work is highly appreciated. I can bearly setup a spreadsheet (as you have seen)
Offline dvorcol
« Reply #127 on: Tue, 18 August 2020, 02:11:46 »
You're running a successful group buy, that's quite an accomplishment.  And your spreadsheet isn't bad, either.
Offline Ulliam
  • 𝖚𝖑𝖑𝖎.𝖆𝖒
Re: [GB] KAT Cyberspace & BBox60 Case! (GIVEAWAYS) 300% MOQ
« Reply #128 on: Wed, 19 August 2020, 06:31:51 »
Goldenstar Keycaps
Raffle on August 23rd: https://discord.gg/m7qUSR5
https://www.instagram.com/goldenstar_keycap/
Latralum
(special 1 of 2 GiD Edition)
Date TBD
https://www.instagram.com/latrialum/
Goodluck!
Offline pandaman97
« Reply #129 on: Wed, 19 August 2020, 10:35:04 »
Will you have prototype or something similar? Anyway dope set  :eek: I think this will be my first gb  ;D
Offline hotnoodle666
« Reply #130 on: Wed, 19 August 2020, 23:25:12 »
Hey I have a quick question on the Rama keycaps. After manufacturing, will those keycaps be shipped to Rama Works first then distributed to all the vendors worldwide, or vendors like Zfrontier will get the shipments directly from the manufacturer (I assume the factory is in China)? Just trying to figure out the fastest way to get the delivery. Thanks.
Offline Ulliam
  • 𝖚𝖑𝖑𝖎.𝖆𝖒
« Reply #131 on: Thu, 20 August 2020, 03:40:17 »
I'd assume everything ships out of Rama.works for qc etc (:
Offline VagueOrigin
« Reply #132 on: Thu, 20 August 2020, 08:13:03 »
Hi, im using a 60% ansi layout, I was curious if the novelties cover the mods or would I need icon kit?
Sent from my SM-G975U using Tapatalk
Offline nathanchere
« Reply #133 on: Thu, 20 August 2020, 08:26:59 »
[edit] never mind, I see the photo of the glow effect now. I'm in.
Offline Pizza_on_Pineapple
« Reply #134 on: Thu, 20 August 2020, 11:07:01 »
You need one of the mod kits or the TKL kit for most of the modifier keys. The novelties are accent keys for enter, the bottom row and various 1u key across the three top rows.
Offline VagueOrigin
« Reply #135 on: Thu, 20 August 2020, 11:42:43 »
Thanks, appreciate it! Just seeing if I could shave a set off at checkout, my wallets on fire lol.
Offline Magnificent Bureaucrat
  • Sooooo much red tape
« Reply #136 on: Thu, 20 August 2020, 15:34:45 »
I've been perving on Cyberspace for a while but only just noticed you can get full ISO coverage for the low-low cost of two kits! Now I'm going to spend the rest of the month going back and forth trying to justify the purchase :-\
No idea what I'm going to do with the BBox60 case I've already ordered but at the price point it would be rude not to.
« Reply #137 on: Thu, 20 August 2020, 23:14:39 »
Makes sense. Thank you!!
Offline Ulliam
  • 𝖚𝖑𝖑𝖎.𝖆𝖒
« Reply #138 on: Thu, 20 August 2020, 23:19:59 »
a massive shoutout to these amazing humans for their fan art <3
By Noshk#3676
https://www.instagram.com/uberchango/
Offline Yilk81
« Reply #139 on: Fri, 21 August 2020, 04:32:32 »
I wanted to show off the set to a good friend but there are actually not that many renders. How does one get into the render game and help visualize sets?
Offline pandaman97
« Reply #140 on: Sat, 22 August 2020, 02:33:15 »
If i need this to my 60% tsangan layout (not include step caps), will Alpha and Beta/40s complete it?
Offline tzarc
« Reply #141 on: Sat, 22 August 2020, 03:10:39 »
Do my eyes deceive me?!
Do the betas actually include an R3 1U |\ key?
I tried to get it addressed on the GB thread but didn’t seem to get it sorted back then.... it’s in now?
EDIT: Sweet, confirmed on discord chat history. Time to go order way too many sets :D
« Last Edit: Sat, 22 August 2020, 03:26:49 by tzarc »
« Reply #142 on: Sat, 22 August 2020, 08:45:12 »
No, you're missing 1.75u caps, 1.5u tab, 7u spacebar and 2.25u left shift and enter keys.
Offline LASERman Projects
  • Soldering is my native language.
« Reply #143 on: Sat, 22 August 2020, 14:57:23 »
I am pretty noob but.. what is the size of the second longer spacebar at the bottom of the mods kit if not 7u?
Also are you sure that among all that various shift keys none is 2.25u?
Offline Radium
  • Newbie
« Reply #144 on: Sat, 22 August 2020, 18:58:06 »
Why the color of alpha in TKL set is different from Alpha set. I really love the color of tkl but this set is not fit my 65% keyboard. :(
« Reply #145 on: Sun, 23 August 2020, 01:44:12 »
pandaman97 was talking about the Beta/40s kit which will not cover a tsangan layout. Both Beta/Icon and Beta/Text mods will cover that layout though, sorry for the confusion.
Offline pandaman97
« Reply #146 on: Sun, 23 August 2020, 05:02:18 »
Wow, that miss like .. a lots lol  :)) I guest Alpha and Mods eventually  :thumb: Thanks you
Offline Drakenocas
« Reply #147 on: Mon, 24 August 2020, 00:55:55 »
Would 2 alphas, 1 mod about cover 2 boards, or need 40s for good measure?  What's the best route for 65% and a 60 or 50? I said no more this year, but the price is too good to pass up.
« Reply #148 on: Mon, 24 August 2020, 01:52:43 »
2 alpha kits and a mod kit can cover a 60% and a 65%. Just have in mind that you'll have to use split and 2u backspace as well as ISO and ANSI enter on your boards. Also make sure that you use different bottom rows on both keyboards. There's also only a single R4 Esc key but that's easily substitutable.
If I were you I'd add the novelties instead of the 40s kit to your order because that adds additional (ANSI) enter, R4 and a bunch of bottom row keys. Also they look really cool ;) That's assuming of course that you don't plan on building anything sub 50%.
Offline dvorcol
« Reply #149 on: Mon, 24 August 2020, 17:30:20 »
<-- progress
« Last Edit: Sat, 29 August 2020, 07:44:31 by dvorcol »
