Author Topic: [GB] KAT Cyberspace - FINISHED - 720k units sold!  (Read 387372 times)
Offline dotcom
Re: [GB] KAT Cyberspace & BBox60 Case! (GIVEAWAYS) 300% MOQ
« Reply #150 on: Mon, 24 August 2020, 21:00:57 »
Does the TKL set come with F and J homing keys? I can see the homing keys in all the Alpha renders, but not in the TLK render.
Offline bliss
« Reply #151 on: Tue, 25 August 2020, 10:14:28 »
Code: [Select]
EXCEPTION
initiating handler...
#1 ?Undefined token 'Fuction' in module 'text mods': traceback beta / text mods / r2
#2 WARNING expected symbol < found symbol > instead in module 'north': traceback omega / north / r1
I came over from Slurp which borrowed kitting elements from this iconic masterpiece, and got stuck there looking at the North kit trying to piece together ISO-DE (there are multiple swaps of primary & shift legends in Slurp / North, I am going to address those in a separate post). Yes, I am aware of the down-shift legends (genius!)...
Short on credits, most probably going to pick up only TKL... and congratulations on the successful run :thumb:
Sorry if any of this was mentioned earlier, I do not have time to read the whole thread..
ps.
For reference, this is Ed's original keyboard, I have been using the picture as avatar here as well:
:D
« Last Edit: Tue, 25 August 2020, 13:20:16 by bliss »
Offline Tom_Kazansky
  • Oblivion Knight
« Reply #152 on: Wed, 26 August 2020, 00:10:55 »
Excuse me!
the case (BBox60) will ship with the keyset or is it shipped separately?
Offline Ulliam
  • Formerly Papithered
  • 𝖚𝖑𝖑𝖎.𝖆𝖒
« Reply #153 on: Thu, 27 August 2020, 23:52:07 »
Excuse me!
If you order them together they will be shipped together, they will both be delivered around the same time (end of Q1)
Offline Yilk81
« Reply #154 on: Fri, 28 August 2020, 04:24:00 »
Though I had already ordered but turned out i didn't. Good thing I found out in time! Ordered 10 kits!! So excited!!
Offline Magnificent Bureaucrat
  • Sooooo much red tape
« Reply #155 on: Fri, 28 August 2020, 18:39:37 »
After much deliberation I played it safe and went for alphas + icon mods. Really looking forward to pairing this set up with a HMKB. (Hopefully with a GiD cable)
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #156 on: Sat, 29 August 2020, 07:44:00 »
<-- progress
« Last Edit: Mon, 31 August 2020, 18:48:21 by dvorcol »
Offline Ulliam
  • 𝖚𝖑𝖑𝖎.𝖆𝖒
« Reply #157 on: Sun, 30 August 2020, 03:15:24 »
Thank you again so much dude 💜
Just over a day left to enter the discord giveaway for a full set and gid cyberspace stickers as runner up prizes (: https://discord.gg/njbnkAF
Offline highdsan
« Reply #158 on: Sun, 30 August 2020, 08:32:13 »
Made my preorder yesterday at DailyClack )))
But don't get one thing about ArtKey dog artisan - I missed GB on it? Or it will be avialable on their site later?
« Last Edit: Sun, 30 August 2020, 10:48:34 by highdsan »
Offline mk.adz
« Reply #159 on: Sun, 30 August 2020, 14:51:43 »
Hi, I'm a noob at this and this is my first official GB! Yey! Question about pcb compatibility. Are there other pcbs that "65%" are compatible with this aside from the gk64?
Offline Ulliam
  • 𝖚𝖑𝖑𝖎.𝖆𝖒
« Reply #160 on: Mon, 31 August 2020, 03:02:29 »
Less than 24 hours remaining for everywhere apart from the US. Thank you all so much for coming along with me for this crazy ride!
« Last Edit: Mon, 31 August 2020, 03:04:06 by Ulliam »
Offline Zireael_
Re: [GB] KAT Cyberspace - LAST DAY(s)!!!!
« Reply #161 on: Mon, 31 August 2020, 05:15:38 »
Any updates on the cable? Possible estimate of when it might be available?
« Last Edit: Mon, 31 August 2020, 05:17:51 by Zireael_ »
Offline Ulliam
  • 𝖚𝖑𝖑𝖎.𝖆𝖒
« Reply #162 on: Mon, 31 August 2020, 06:32:34 »
flex is still waiting on the engraved aviator connectors coming, the buy will for sure be coming asap! I'll post it in every channel i can when it happen so dont worry about missing it.
The ArtKey artisans were a limited raffle of 10 pieces each, sorry dude :(
any pcb that shares the same standoff screw holes should work, but if you check this out, and compare it to the pcb you're looking at you should have a better idea. https://www.reddit.com/r/MechanicalKeyboards/comments/532yj4/60_pcb_dimensions/ It is only designed to work with the listed pcbs, while universal there for sure could be options out there.
Offline Baumstyler
« Reply #163 on: Mon, 31 August 2020, 17:22:15 »
better late than never, just ordered : D
Offline Bobatype
  • formerly bobasweatandtears
    • discord: bobatype
« Reply #164 on: Mon, 31 August 2020, 18:43:00 »
Yep, got my last day order in. As a big Matrix fan, this set was a no-brainer. It's nice having much more affordable kits (vs GMK), which means spare change to get artisans and deskmat too.
Offline dvorcol
« Reply #165 on: Mon, 31 August 2020, 18:47:54 »
<-- progress
« Last Edit: Thu, 10 September 2020, 16:54:18 by dvorcol »
Offline Tappaz
« Reply #166 on: Mon, 31 August 2020, 22:07:29 »
1st GB and am looking forward to this set. Love the whole Cyberpunk / Matrix aesthetics the set has going for it.
Offline Ulliam
  • 𝖚𝖑𝖑𝖎.𝖆𝖒
« Reply #167 on: Tue, 01 September 2020, 06:28:37 »
Thank you so much guys! I hope you enjoy the set.
<3 as always thank you man
Offline Pyk_
« Reply #168 on: Wed, 02 September 2020, 10:40:11 »
Hey if anyone is buying the purple or green bars and doesn’t need the 2u ones, I’d be happy to buy them from you. (I’m hoping to get 2 or more, which makes buying multiple kits a bit pricy). I’m mainly interested in the 2u, but if you also don’t need the other shorter ones I would buy the, too.
Offline gex
« Reply #169 on: Thu, 03 September 2020, 21:15:10 »
gb runs until 09/04 and it's already closed on mykeyboard?!
Offline -bl1nk
« Reply #170 on: Thu, 03 September 2020, 21:52:24 »
I'd do that if you remember to contact me when it ships lol. My discord is blink#1393 if you want to talk about it.
Offline Brawnyth
« Reply #171 on: Fri, 04 September 2020, 00:59:46 »
Hey there! I note that the previous renders includes purple escape and arrow keys for the icon mods but didn't see it whilst purchasing the kit. Is there any way I could get the purple arrow and escape key variant?
Offline dmatx1
« Reply #172 on: Fri, 04 September 2020, 03:40:45 »
Live August 1st till September 1st (†US August 3rd - September 4th)
It runs only in the US until 4th.
Offline Ulliam
  • 𝖚𝖑𝖑𝖎.𝖆𝖒
« Reply #173 on: Fri, 04 September 2020, 04:59:34 »
Kono have just confirmed it'll stay online till tomorrow (saturday) morning est, for anyone that thought they had missed it! (it's currently still up on zF too)
Offline Ulliam
  • 𝖚𝖑𝖑𝖎.𝖆𝖒
Re: [GB] KAT Cyberspace - FINISHED - 720k units sold!
« Reply #174 on: Thu, 10 September 2020, 04:03:27 »
Finished up everywhere now, Still got the cable collab to come.
Final numbers have been calculated and we're moving on to the next step, Thank you all so so much for joining, thank you to Mykeyboard, Deskhero, zFrontier, Kono and Daily Clack for beliving in my first set and helping me make it happen! you're all seriously the best.
Offline dvorcol
« Reply #175 on: Thu, 10 September 2020, 16:53:27 »
Final numbers
<-- without extras
Offline ttom
  • Formerly tvaro
« Reply #176 on: Thu, 10 September 2020, 17:01:17 »
Huge numbers, congrats my guy <3 much deserved
Hoarder Collector and designer
Classifieds
Offline Vizir
« Reply #177 on: Thu, 10 September 2020, 19:02:00 »
Extras means people who ordered multiple sets?
Sent from my Pixel 4 XL using Tapatalk
Offline LXVRGS
« Reply #178 on: Thu, 10 September 2020, 20:50:37 »
vendors that buy additional kits to sell after gb orders ship.
Offline WHAT!?
  • WHAT!?
« Reply #179 on: Tue, 29 September 2020, 10:03:35 »
I see Kono store is selling "extras". I'm not sure what that means. Are they still filling full orders for the kits listed, or is it a dice roll? Like maybe we get it, maybe we don't?
Offline dvorcol
« Reply #180 on: Tue, 29 September 2020, 14:44:04 »
It's not a dice roll.  Most vendors order extras to sell after the set has been received, since there are always people who regret missing the GB.  After the GB closes but before production, some vendors take orders for a percentage of their extras.  Often these are called pre-orders, but there's no hard and fast rule for the terminology.  It's a safe bet that pre-order prices are higher than GB prices.
Offline WHAT!?
  • WHAT!?
« Reply #181 on: Tue, 29 September 2020, 15:18:39 »
Alright, I think I got it. So the vendors order when the group buy is live and then resell their acquired stock of the item for profit after initial group buy has shipped? Which means since I wasn't quick enough I get to pay them for performing the service of having essentially reserved some extra stock for people like myself who came late.
Hopefully I got a firm hold on that. Still new to the hobby so I'm not completely familiar with how it all plays out yet. Thanks.
::EDIT::
Well I went ahead and paid for the extras... Now I get to pit it in a race against Dracula. If it gets here prior to a years time then it wins. lol
« Last Edit: Tue, 29 September 2020, 22:08:45 by WHAT!? »
Offline prizeS
    • TastyKeys
« Reply #182 on: Wed, 30 September 2020, 01:42:08 »
::EDIT::
Well, lets see if I can explain this so it makes more sense:
After a GB ends, vendors usually order extras ON TOP of what people bought during the length of the GB. Some vendors sell their extras right after the GB ends as "Pre-Orders" which is at a higher price because you wait less, since the set is already in production and it's guaranteed to be made. This is what Kono is doing.
On the other hand, some vendors sell their extras AFTER the sets ship, so they won't be released for sale until the customers that joined during GB got theirs, plus replacements for lost parcels, etc. Usually, "Extras" pricing is even higher than "Pre-Orders", since these will be in-stock, ready to ship sets with no production lead time. Furthermore, some vendors incorporate both of these strategies, having both "Pre-Orders" and "Extras" for sale, creating a 3-tier price structure.
It usually goes like this. GB price: $129.99 Pre-Order:$149.99 Extras: $179.99 (In the case of a standard base kit. This varies, of course.)
i lub 65% and wkl tkl.
Offline xwind
« Reply #183 on: Sat, 24 October 2020, 09:05:42 »
BTW, I am not sure whether anybody noticed it, but the RUS-ENG alphas render has a mistake (see attached image). I hope it is corrected in the production kit.
Offline KVLT
« Reply #184 on: Sun, 25 October 2020, 13:38:59 »
big wow
the bad guy wins in this one
Offline jacobson
« Reply #185 on: Fri, 06 November 2020, 20:59:56 »
I'm thinking of ordering some extras on Kono. The TKL doesn't have a 1u ctrl alt etc right? So I have to get the alphas+modifiers?
Offline Sabin
« Reply #186 on: Sun, 15 November 2020, 06:05:28 »
Just wondering whats the lead time on KAT caps? 9 months since GB finished?
EDIT: My order on MYkeyboard.eu state expected shipping Feb 21, is that likely to be correct?
« Last Edit: Mon, 16 November 2020, 03:20:43 by Sabin »
Offline prizeS
    • TastyKeys
« Reply #187 on: Mon, 16 November 2020, 05:22:54 »
tbh, i wouldn't count on it. if it does ship in feb21 then that would be a bonus.
Offline vixxy
« Reply #188 on: Sun, 22 November 2020, 00:01:37 »
Link to the glow cable is gone, know where it can be bought?
https://flexcablesstore.com/
Offline hottrout
  • I'd Hit Dat Key
« Reply #189 on: Mon, 23 November 2020, 07:38:05 »
I watched the set and thought it was quite odd.  I looked again but decided not to buy.  I bought it on the last day, it was a good choice.
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
Offline NoteMakoti
  • for sale, baby shoes, never worn
« Reply #190 on: Tue, 24 November 2020, 14:58:55 »
I might get another for Whimsy.
Offline horrorshow93
« Reply #191 on: Wed, 25 November 2020, 12:00:16 »
Kono Store (US Vendor) says production end of Q1 and shipping a month after. So the end of February would only be a couple months off. 9 months would be closer to June, right?
Offline Upgrayedd
« Reply #192 on: Thu, 26 November 2020, 09:45:55 »
I'm interested in buying this kit for a 75% build (GMMK Pro) with a 1u bottom row to the right of the spacebar and a 1.75u right shift key. Based on my options in the Kono store, the TKL kit is the only one available that comes with the darker green English keycap legends that I want on the alphas. Is that correct? The English alphas sold by themselves look like they've got brighter legends. I'm into the icon mods.
I could buy the TKL kit, but then I'd still need a 1.75u shift key, 1u Alt, 1u Fn, and 1u Ctrl (all icon mod) to complete my set. Could those be bought separately? What would be the most cost-effective way to achieve this? Could I buy the TKL + Omega/Novelties together to do that? Are the longer White Rabbit caps in the novelties kit 1.75u? I can't tell from the photo.
Offline miamii
« Reply #193 on: Sun, 06 December 2020, 04:41:45 »
Hi, is there any update on Cyberspace BBox60 Case?
Offline nick779
« Reply #194 on: Tue, 08 December 2020, 11:45:59 »
Is KAT R5 the same as R4 or is it a different sculpt?
Offline Argan12345
« Reply #195 on: Tue, 08 December 2020, 13:23:48 »
No the white rabbit caps are 1.5u at the longest.
Because I've looked into this myself, I'd like to help you out. For a 75% keyboard with the keys you need, you can get the TKL + 40% kits or the Alpha + Icon Mods kits. A cheaper (but not as esthetic as you'd be using a spacebar for shift) is to get TKL + a spacebar kit.
Offline Argan12345
« Reply #196 on: Tue, 08 December 2020, 13:25:08 »
No they're different.
Source: https://www.keycaps.info/
Offline dvorcol
« Reply #197 on: Tue, 08 December 2020, 14:26:42 »
That profile comparison site is awesome, thank you!  Did you make it?
Offline Argan12345
« Reply #198 on: Tue, 08 December 2020, 14:34:06 »
nope!
Offline Matt68
« Reply #199 on: Sat, 12 December 2020, 12:25:57 »
There are 2 mistakes on the french kit render :
- the > and the < should be reverted on the < > keycap
- the =+ keycap is on R4, not R1
