Author Topic: [GB] GMK Minimal 2 - Extras In Stock Now  (Read 93948 times)
Offline dvorcol
  • Discord: dvorcol_5071
Re: [GB] GMK Minimal 2 - Live Now!
« Reply #50 on: Thu, 20 August 2020, 12:17:18 »
Numbers are up to date for most vendors
* Standard: 1245
* Addition: 138
* Numbers: 209
* Colour: 545
* Mono: 116
* Command: 170
* Obscure: 245
* Norde: 47
* RAMA Black: 364
* RAMA Red: 64
* RAMA Green: 52
* RAMA Blue: 70
A little under 2 weeks left to buy this guys!  :)
<-- progress
« Last Edit: Fri, 21 August 2020, 13:18:47 by dvorcol »
Offline dvorcol
« Reply #51 on: Fri, 21 August 2020, 13:16:42 »
<-- progress
« Last Edit: Sun, 30 August 2020, 18:38:33 by dvorcol »
Offline iamtienng
« Reply #52 on: Wed, 26 August 2020, 08:41:25 »
jnd
Offline janglad
  • qoda.studio
    • Clavier.xyz
« Reply #53 on: Sun, 30 August 2020, 17:21:31 »
Almost all vendors are up to date this time!
* Standard: 1904
* Addition: 203
* Numbers: 286
* Colour: 796
* Mono: 157
* Command: 241
* Obscure: 349
* Norde: 73
* RAMA Black: 528
* RAMA Red: 98
* RAMA Green: 83
* RAMA Blue: 106
Just 3 days left to order!
« Last Edit: Sun, 30 August 2020, 18:09:51 by janglad »
Offline dvorcol
« Reply #54 on: Sun, 30 August 2020, 18:37:59 »
* Standard: 1904
* Addition: 203
* Numbers: 286
* Colour: 796
* Mono: 157
* Command: 241
* Obscure: 349
* Norde: 73
* RAMA Black: 528
* RAMA Red: 98
* RAMA Green: 83
* RAMA Blue: 106
<--progress
« Last Edit: Wed, 02 September 2020, 17:43:27 by dvorcol »
Offline janglad
  • qoda.studio
    • Clavier.xyz
« Reply #55 on: Wed, 02 September 2020, 04:57:25 »
* Standard: 2405
* Addition: 268
* Numbers: 372
* Colour: 1037
* Mono: 189
* Command: 304
* Obscure: 429
* Norde: 96
* RAMA Black: 592
* RAMA Red: 113
* RAMA Green: 99
* RAMA Blue: 127
Last day to order guys!
Offline dvorcol
« Reply #56 on: Wed, 02 September 2020, 17:42:59 »
* Standard: 2405
* Addition: 268
* Numbers: 372
* Colour: 1037
* Mono: 189
* Command: 304
* Obscure: 429
* Norde: 96
* RAMA Black: 592
* RAMA Red: 113
* RAMA Green: 99
* RAMA Blue: 127
<-- progress
« Last Edit: Fri, 04 September 2020, 20:29:38 by dvorcol »
Offline dvorcol
« Reply #57 on: Fri, 04 September 2020, 20:26:45 »
<-- progress
« Last Edit: Tue, 08 September 2020, 20:02:34 by dvorcol »
Offline IOVERCALLHISTIOCYTES
« Reply #58 on: Fri, 04 September 2020, 20:45:26 »
After extras kick in, Janglad will be at 15k base kits for 2020? (Modo light, modo2, mist, minimal r2?). Congrats to all.
Offline The.Ryan.Gamer
« Reply #59 on: Sat, 05 September 2020, 02:27:10 »
Man, i'm sooo happy i got these. It's always cheaper in ilumkb! <3
Got base + Colors. I'd like to get Rama too, but i'm also planning to get GMK Posh, KAT Mizu and SA Bliss, i had to pass on Rama. Sucks to have limited budget.  :(
Grats on the GB.  :thumb:
Offline janglad
  • qoda.studio
    • Clavier.xyz
« Reply #60 on: Sat, 05 September 2020, 18:05:42 »
Thanks man, those are some solid choices for other sets. Should be worth the trade off :D
Wew I never thought about it like that, that's pretty insane! As always I'm amazed by all the support on my projects, onwards and upwards. I have a lot more cool stuff in the works! ;)
Offline GarrettSucks
  • All project timelines at at timelines.omnitype.com
    • Omnitype
« Reply #61 on: Tue, 08 September 2020, 15:36:45 »
Finally here with final numbers after waiting for everything to conclude with all vendors. Our final numbers without extras was actually higher than we thought.
Final Numbers w/o Extras
Standard - 2,988
Addition - 314
Numbers - 448
Color - 1,301
Mono - 230
Command - 366
Obscure - 529
Norde - 106
Rama Black - 937
Rama Red Square - 187
Rama Green Triangle - 168
Rama Blue Circle - 214
Final Numbers w Extras
Standard - 5,043
Addition - 561
Numbers - 744
Color - 2,000
Mono - 427
Command - 615
Obscure - 784
Norde - 181
Rama Black - 1,075
Rama Red Square - 236
Rama Green Triangle - 217
Rama Blue Circle - 265
« Last Edit: Tue, 08 September 2020, 15:43:50 by GarrettSucks »
« Reply #62 on: Tue, 08 September 2020, 16:15:15 »
I’d underestimated: Minimal 5045, modo light 3008, modo2 7107, mist 1500 is 16,658 base kits for one designer in a 7 month stretch of 2020.
Left panel: you can’t just keep making hit after hit
Right panel: keycap machine go brrr
Offline dvorcol
« Reply #63 on: Tue, 08 September 2020, 19:59:33 »
Final numbers
Standard - 2,988
Addition - 314
Numbers - 448
Color - 1,301
Mono - 230
Command - 366
Obscure - 529
Norde - 106
Rama Black - 937
Standard - 5,043
Addition - 561
Numbers - 744
Color - 2,000
Mono - 427
Command - 615
Obscure - 784
Norde - 181
Rama Black - 1,075
Offline janglad
  • qoda.studio
    • Clavier.xyz
« Reply #64 on: Mon, 25 January 2021, 08:57:34 »
Hey everyone
We got the colour samples in! At first glance they were pretty close but we have decided to try and tweak the red and blue somewhat making the red a tad redder and more saturated and the blue lighter. Keep in mind colours change based on lighting conditions and such but I tried to portray them accurately in the pictures below (also smol Dharma leek)
Offline Prelim
« Reply #65 on: Fri, 29 January 2021, 02:48:41 »
is there any GMK minimal set (WS1) but with icon mods? I'm trying to figure out if it was ever made, but can find it.
2x GH60 revC - lubed Linjärs 65g / lubed H1s 65g with SPRIT 5mm acrylic plate | Dolch PAC - Cherry housing / Gateron sliders 65g and QMK clips | Raptor K1 G80-1890 stock
Floating on Cherry/GMK caps
Offline TjarleN
« Reply #66 on: Fri, 29 January 2021, 03:19:59 »
No, there was GMK Bleached last year which was WS2 with icon mods and there was an IC for GMK Paper some years ago which was WS1 with icon mods but the GB never happened as far as I know.
Offline Prelim
« Reply #67 on: Fri, 29 January 2021, 04:54:46 »
thanks, let hope for a next GB with icon mods then  :thumb:
Offline MMKB
« Reply #68 on: Sat, 30 January 2021, 23:21:45 »
Personally I dig the R1 samples. Just hope that R2 samples won’t cause additional delay. I guess this GB is waiting in some sort of production queue at GMK
Offline janglad
  • qoda.studio
    • Clavier.xyz
« Reply #69 on: Sun, 14 March 2021, 12:28:29 »
Small update: still waiting on the R2 colour samples but RAMA caps did arrive!
Offline worldtour
« Reply #70 on: Tue, 16 March 2021, 02:17:19 »
Does that mean Rama-only orders will ship soon? Or are those samples?
Offline TjarleN
« Reply #71 on: Tue, 16 March 2021, 03:00:02 »
That depends on the vendor.
Some vendors do ship Rama-only/deskmat-only orders before the rest of the GB items arrive and others ship once they receive everything that was part of the group buy.
Offline janglad
  • qoda.studio
    • Clavier.xyz
« Reply #72 on: Tue, 16 March 2021, 11:44:14 »
Just confirmed with Omnitype specifically and they said they would! AFAIK most vendors do ship out RAMA/Deskmat only orders ahead of GB.
Offline Obstsalatjaa
« Reply #73 on: Tue, 27 April 2021, 18:31:10 »
Did any region receive the set yet?
It's my first GB...
Offline itsmartin
« Reply #74 on: Tue, 27 April 2021, 18:50:02 »
It's my first GB...
No. Check Omnitype’s website for progress, they recently received more colour samples and it’s not going to ship from GMK until after all the other sets that ran before it. Pono ran in July 2020 and is currently scheduled to ship in July, and given this ran in August it’ll come after that.
Offline Jo_hannes
  • You can never learn less. You can only learn more.
« Reply #75 on: Wed, 28 April 2021, 03:21:31 »
It's my first GB...
See there: https://omnitype.com/blogs/timelines/gmk-minimal-2
Currently scheduled for August/September delivery, but color matching is still going on, so my own realistic estimate is end of the year.
/Johannes
    • Omnitype
« Reply #76 on: Thu, 27 May 2021, 15:12:01 »
We have officially approved all three accent colors and are now just waiting our turn in line for production.
We have no new shipping estimate from our last one that said August to September shipping to customers.
Offline Jo_hannes
« Reply #77 on: Thu, 27 May 2021, 15:50:13 »
Sounds terrific, fingers crossed! :D /Johannes
Offline GSV-CargoCult
« Reply #78 on: Sat, 24 July 2021, 09:06:20 »
Omnitype is now saying Jan 22... Is that right?
« Reply #79 on: Sat, 24 July 2021, 10:57:14 »
Here was the link that said January. I assume it’s right in that it won’t ship before this.
Btw: love that you get the estimate and the date it was given, because if it's still months out, and the update was months old...you then know it's wrong.
« Last Edit: Sat, 24 July 2021, 12:35:45 by IOVERCALLHISTIOCYTES »
« Reply #80 on: Sat, 24 July 2021, 12:34:11 »
Duplicate sorry
Offline honoka
« Reply #81 on: Sun, 25 July 2021, 03:58:52 »
change the title. you are confusing people.
LIVE NOW
nope
Offline Domantas
« Reply #82 on: Wed, 04 August 2021, 19:03:07 »
January??  :-[ I am happy I have some keycaps, because this is soooo delayed. I feel like whatever next gmk keycap set is ordered it delays exponentially
« Reply #83 on: Mon, 17 January 2022, 05:42:21 »
Any updates on manufacturing?
Offline TjarleN
« Reply #84 on: Mon, 17 January 2022, 06:35:43 »
"Estimated shipping date from the manufacturer has been updated to the week of January 24th (as of 1.7.2022)"
from: https://omnitype.com/blogs/timelines/gmk-minimal-2
« Reply #85 on: Fri, 28 January 2022, 08:56:42 »
 Estimated shipping date from the manufacturer has been updated to the week of January 31st (as of 1.21.2022)
Offline Domantas
« Reply #86 on: Sun, 30 January 2022, 15:32:46 »
Nice so its tommorow. Though oh boi gb was in 2020 if I am correct
« Last Edit: Sun, 30 January 2022, 15:34:23 by Domantas »
Offline oilpapers
« Reply #87 on: Sun, 30 January 2022, 18:39:54 »
This is hilarious, 2 years for such a simple set? Keyboard people really do have more money than sense.
Offline Ensaum
« Reply #88 on: Sun, 30 January 2022, 19:16:11 »
When this set ran, GMK sets weren't taking 1.5 to 2 years to deliver. The excessive delays are a relatively new thing. Fwiw, I have stopped joining GMK gbs due to the delays.
Offline adigaforever
« Reply #89 on: Mon, 31 January 2022, 00:43:43 »
It's my first GB...
Man this is hilarious, poor soul, it's not even been shipped to vendors yet XD
Offline Domantas
« Reply #90 on: Tue, 08 February 2022, 06:08:33 »
Similar here :D joining only on something extremely special like relegendables, but joining gmk gb these days is not fun
Offline Domantas
« Reply #91 on: Thu, 17 February 2022, 10:32:31 »
Is it shipped?
Offline TjarleN
« Reply #92 on: Sat, 19 February 2022, 08:32:48 »
+ Keycaps are in transit from the manufacturer's warehouse to our warehouse. All groupbuy orders are expected to be shipped in March 2022. (as of 2.18.2022)
From Omnitype website
Offline seikosis
« Reply #93 on: Sat, 19 February 2022, 12:05:42 »
Any word on vendors selling extras?
Offline itsmartin
« Reply #94 on: Sat, 19 February 2022, 16:58:00 »
They have to ship them first.
Offline TjarleN
« Reply #95 on: Tue, 22 February 2022, 04:28:36 »
MyKeyboard started shipping Minimal 2 and will be selling extras soon.
Offline Liub
« Reply #96 on: Thu, 24 February 2022, 22:32:20 »
Received shipping notification from zFrontier  :thumb:
Offline darthcapn
« Reply #97 on: Mon, 16 May 2022, 13:13:04 »
I mounted my set yesterday and looks like the Ramas are ws2 instead of ws, or atleast much closer to ws2 than ws1?
Sent from my SM-G988U using Tapatalk
Praxis | Portal | Frog F13 | Vega | Sat75 | F2-84 | Iron 165 | KFE CE | Spring | Pandora | Mr Suit | MGA | Jelly Epoch
Dolice | Glare | Vmax chyuu | W1-AT | Hoshizora | iron 160 | Nazaré | Tomo
Offline TjarleN
« Reply #98 on: Mon, 16 May 2022, 23:55:51 »
I think every white Rama is using the same white. They use colors that are somewhat close but never really match. (Unless its like black maybe)
The infills are most times pretty accurate though.
