Author Topic: [IC] Meridian  (Read 93661 times)
Offline holtenc
[IC] Meridian
« on: Thu, 06 August 2020, 22:43:44 »
Meridian
Ergonomic 60% Keyboard
Tradition and Revolution
A seamless design combined with sharp angles constructs a centerpiece fit for your modern desk.
The three LED indicators and identical alphanumeric bend angles carry on the legacy from the Prime_E.
Trustworthy Typing Experience
An aluminum top-mounted plate offers typing comfort and a middle-ground rigidity which pairs well with various switch types.
The internal brass weight adds enough heft to keep the board stable during heavy use.
The Ergonomic Factor
Based on the Prime_E, the alphas bend in at a soft 8 degree angle rather than the aggressive 12 degree bend of most Alice-esque boards.
The layout is built around common keycap sizes for maximized compatibility with existing keysets.
Specifications
PCB: Soldered, USB-C, ESD protected
Indicators: RGB LED indicators, in-switch caps lock LED
Plate: Aluminum, top mount
Typing angle: 7 degrees
Alphanumerics bend angle: 8 degrees
Weight: Brass, bead blasted
Likely Colors: Black, Dark Gray, Deep Blue
Layout
Typing Sounds
Other Info
Designed by: ai03
Produced and fulfilled by: Prime Keyboards
Availability: In stock. ETA is before the end of January 2021
Price: TBD
Gallery
« Last Edit: Thu, 07 January 2021, 21:45:38 by holtenc »
Offline yoot
    • none
Re: [IC] Meridian
« Reply #1 on: Thu, 06 August 2020, 22:44:41 »
Yes.
Offline FunBox
    • Null
Re: [IC] Meridian
« Reply #2 on: Thu, 06 August 2020, 22:45:07 »
Mega hype
Sent from my SM-N975U1 using Tapatalk
Offline darthcapn
Re: [IC] Meridian
« Reply #3 on: Thu, 06 August 2020, 22:51:29 »
Wish this was hot swap
Sent from my SM-G988U using Tapatalk
Praxis | Portal | Frog F13 | Vega | Sat75 | F2-84 | Iron 165 | KFE CE | Spring | Pandora | Mr Suit | MGA | Jelly Epoch
Dolice | Glare | Vmax chyuu | W1-AT | Hoshizora | iron 160 | Nazaré | Tomo
Offline holtenc
Re: [IC] Meridian
« Reply #4 on: Thu, 06 August 2020, 22:52:18 »
just realized the capslock key on the blue case is messed up.... oops. (no PCB underneath)
Offline Kafka
  • i like clean things
Re: [IC] Meridian
« Reply #5 on: Thu, 06 August 2020, 22:52:56 »
Offline X_point
Re: [IC] Meridian
« Reply #6 on: Thu, 06 August 2020, 22:58:52 »
hype train...  :cool: hopefully this will be my first ergo board...
Offline Hdjekso
Re: [IC] Meridian
« Reply #7 on: Thu, 06 August 2020, 23:01:53 »
what happened to the stepped caps on the navy board
Offline heyimpanda
Re: [IC] Meridian
« Reply #8 on: Thu, 06 August 2020, 23:03:24 »
in stock  :eek:
Offline holtenc
Re: [IC] Meridian
« Reply #9 on: Thu, 06 August 2020, 23:07:49 »
in stock  :eek:
It slipped. Didn’t notice until I posted this.
Offline ZongZiWang
Re: [IC] Meridian
« Reply #10 on: Thu, 06 August 2020, 23:13:09 »
Holten x ai03 the best duo to bring this to us
Offline HRB
Re: [IC] Meridian
« Reply #11 on: Thu, 06 August 2020, 23:21:12 »
reserved.
Offline GaNeBaL
Re: [IC] Meridian
« Reply #12 on: Thu, 06 August 2020, 23:30:30 »
gib
Obsessed with 60%TKLs
Offline Macmutant
Re: [IC] Meridian
« Reply #13 on: Thu, 06 August 2020, 23:35:36 »
100% in.
Offline aaronlau
Re: [IC] Meridian
« Reply #14 on: Thu, 06 August 2020, 23:39:09 »
Definitely Interested :)
Offline Leyva
Re: [IC] Meridian
« Reply #15 on: Thu, 06 August 2020, 23:49:27 »
yes pls
Offline pott
Re: [IC] Meridian
« Reply #16 on: Thu, 06 August 2020, 23:56:09 »
I absolutely adore this. I always wondered why Alice had these huge gaps on the bottom row. Adding the keys there (and keeping them all 1.25, so that one could keep a kit's 1.5 bottom row for another board, potentially) seems like a no-brainer. Awesome!
I was worried that the spacebar would be too far to the left... Then I ran a test on my own board and it seems I hit the spacebar between V and B anyway. So I guess this is just perfect.
Offline DaddyPhill
Re: [IC] Meridian
« Reply #17 on: Thu, 06 August 2020, 23:58:49 »
Just got finished putting together my Prime_ e! In for this
Offline Zach
Re: [IC] Meridian
« Reply #18 on: Thu, 06 August 2020, 23:59:38 »
 :thumb:
Whale x2 | Salamander | E6.5 x2 | E8.5 | Nunu | 2.0 ADD | 8XV2.0 | 1.2 OG | Noah | Polaris | Vega | Infinitum | KFE CE | Jaguar | Frog  | Whale75 | Mode80 | Kei | Mode65 | E7v2 SE | Dolphinv3 | *165 | *Tomo | *Cloudline | *Kage | *Bias | *3.0
Offline Mtvan87
Re: [IC] Meridian
« Reply #19 on: Fri, 07 August 2020, 00:23:56 »
Looking forward to the Deep Blue.
Offline Arcitan
  • pain peko
Re: [IC] Meridian
« Reply #20 on: Fri, 07 August 2020, 00:35:07 »
> Designed by ai03
Say no more.
Sent from my SM-G986U1 using Tapatalk
TGR Jane V2 CE | TGR Jane V2 | TGR x TM Jane v1.5 | Kepler | PC TGR 910 RE | Bauer | Iron165 | 2x Volcano660 (White + Black) | TGR x Singa Unikorn | LZ Physix | Rukia | Geonworks F1-8X | Polaris
Offline leexy
Re: [IC] Meridian
« Reply #21 on: Fri, 07 August 2020, 00:47:30 »
bring on the new accounts
Offline Drakenocas
Re: [IC] Meridian
« Reply #22 on: Fri, 07 August 2020, 00:57:39 »
When and where can you buy this at? Call me enthusiastic! I guess I thought it was out of the IC phase after reading everything.
Offline n.rdy
Re: [IC] Meridian
« Reply #23 on: Fri, 07 August 2020, 00:58:44 »
I want this
Offline Arcitan
  • pain peko
Re: [IC] Meridian
« Reply #24 on: Fri, 07 August 2020, 00:58:44 »
In the post:
Availability: In stock. ETA is Q4 2020 / Q1 2021
Offline vaf1en
Re: [IC] Meridian
« Reply #25 on: Fri, 07 August 2020, 01:04:35 »
There is a compact feel to this compared to other Alice style layouts.
I am more than interested in this.
Offline Zambumon
  • discord.zambumon.com
    • Keyset projects
Re: [IC] Meridian
« Reply #26 on: Fri, 07 August 2020, 02:53:42 »
Nice.
Offline maharuto
Re: [IC] Meridian
« Reply #27 on: Fri, 07 August 2020, 03:06:08 »
very nice indeed!
Offline tr0yr0x
  • TWICE Fanboi
Re: [IC] Meridian
« Reply #28 on: Fri, 07 August 2020, 03:25:22 »
Any ai03 board is a nice board.
Offline Rynxe
  • Braccas Meas Vescimini
Re: [IC] Meridian
« Reply #29 on: Fri, 07 August 2020, 03:41:01 »
Noice
Offline dmatx1
Re: [IC] Meridian
« Reply #30 on: Fri, 07 August 2020, 03:41:55 »
Really nice and clean design. It is always great to see prototypes in such an early IC phase (and even in multiple colors).
Just one layout question: could you add split left Shift support?
Offline VXQN
Re: [IC] Meridian
« Reply #31 on: Fri, 07 August 2020, 05:07:00 »
This ticks boxes I didn't even know I had. Love the dark grey colour especially.
Offline BIG_BUCKNUT
Re: [IC] Meridian
« Reply #32 on: Fri, 07 August 2020, 08:51:23 »
this nice
Offline Dubsadan
Re: [IC] Meridian
« Reply #33 on: Fri, 07 August 2020, 09:21:21 »
Looks great, might be the first ergo that doesn't scare me away with the sharp angle.  Can't wait for the in-stock bloodbath.
Offline Kyru
Re: [IC] Meridian
« Reply #34 on: Fri, 07 August 2020, 10:14:07 »
Definitely interested in this. Any chance of doing it in purple?
Sent from my ONEPLUS A6013 using Tapatalk
Offline Mekuno
Re: [IC] Meridian
« Reply #35 on: Fri, 07 August 2020, 10:14:50 »
Yes.
Offline MoonBiscuit
Re: [IC] Meridian
« Reply #36 on: Fri, 07 August 2020, 10:21:41 »
Yes please
Offline verity
Re: [IC] Meridian
« Reply #37 on: Fri, 07 August 2020, 10:21:50 »
v nice
Offline Bitmxp
  • I’ll take 12
    • Bitmap Studios
Re: [IC] Meridian
« Reply #38 on: Fri, 07 August 2020, 10:44:15 »
Heck yeah!
Offline thestrayed
Re: [IC] Meridian
« Reply #39 on: Fri, 07 August 2020, 11:12:27 »
Noice
Offline zoo
    • zoo
Re: [IC] Meridian
« Reply #40 on: Fri, 07 August 2020, 11:12:48 »
As a primarily macOS user, after using the Alice layout for some time, the bottom row here looks really good. Looking forward to this!
« Last Edit: Fri, 07 August 2020, 11:36:11 by zoo »
Offline synthtastic
Re: [IC] Meridian
« Reply #41 on: Fri, 07 August 2020, 11:21:51 »
Very sexy.
Expensive plastic makes me sigh.
Offline holtenc
Re: [IC] Meridian
« Reply #42 on: Fri, 07 August 2020, 11:56:27 »
The colors will likely stay as they are seen here. At least for the first round. Future rounds may see a change in colors.
Offline dallman5
Re: [IC] Meridian
« Reply #43 on: Fri, 07 August 2020, 12:05:05 »
Looks really clean, I like the changes you have made from the standard fare alice layout. Looking forward to hearing more  :thumb:
LF: OG Cherry APL (lasered), Artisans
Current collection:
Norbatouch (Galaxy Blue) | Mira SE (Lunar Grey, WKL) | HHKB Pro 1 (KB300BN) | Noxary X60 (Grey, HHKB) | KBDFans 5 Degree (Silver) | AEK64 (Grey) | Norbaforce (Tactical Black, WKL)) | Realforce 86U (White) | TGR 910 RE (Polycarbonate) | LZ-SQ (Black) | LZ-CLS (Grey, WKL) | Duck Orion v1 (Silver, WK)) | Nissho KB106DE | HHKB Pro 1 (KB300B) | LZ CLS-S (Blue, Poker) | Realforce 87U 10th Anniversary) | Realforce 104UK | TGR Alice (Grey on Pink) | Singa (Blue, WKL)  | Quantrik QXP (Blue Grey, WKL) | LZ-GH v2 (Black, WK) | KMAC Happy (Red, Poker)) | IBM Model M SSK (APL) | TGR 910 SE (Pink on Blue) | GSKT-00 (Silver, Poker) | OTD Koala (Silver, WKL) | Realforce R2 PFU Edition (Ivory) | IBM 3279 Beamspring (APL) | TGR Tris (Blue) | LZ-GH v2 (Blue, WKL)) | TGR Jane v2 (Blue-grey, WKL) | LZ-MP (Shine Grey, WKL)  | TGR x Singa Unikorn (Purple) | Justsystems x Realforce 108UG) | IBM Model F Unsaver (APL) | TGR Jane V2 CE (Multicolor, WKL) | Realforce 87U (Blank Black) | Lin Montage (Light Blue, WKL) | GSKT-00 AEK R2 (Grey, HHKB) | Leopold FC660C (Blank Black) | Duck Viper v3 (Grey on Black) | Rama Works M6-C RWxRW | LZ-GH v1 (Black, WKL) | Gok 7v (Grey) | biso x beaming Kei (SS, HHKB) | zacheadams x bisoromi little z | Matrix Noah (Silver/Grey, WKL) | Lin Whale (Pink, WKL) | TGR Alice (Polycarbonate) | Rama Kara (Noct) | Lin Whale75 (Burgundy, F13) | Realforce 89 (Ivory) | Hand Engineering Haus (Bluegrey) | Haytco CAKE60_R1 (Pantone 4167C) | LZ-XE (Grey, WKL) | Noxary X60 V2 (Grey, WK) | Daji Ochocuatro (Grey, WKL) | HHKB Hybird Type-S 25th Anniversary (Snow) | LZ-REs (Grey, WKL) | Matrix 8xv 3.0 (Blue-Black/Deep Grey, WKL) | Realforce 23UB | Biso RS60 (Black, WK) | TGR x MXF Koala (Grey/Black, WKL)
Italics = Incoming, Black = Gone
Offline dankpupdaddy
    • Twitch
Re: [IC] Meridian
« Reply #44 on: Fri, 07 August 2020, 12:06:43 »
Looking 👌
Offline d4vid4f
Re: [IC] Meridian
« Reply #45 on: Fri, 07 August 2020, 12:11:26 »
Cant wait!  :eek:
Offline FredBananaz
Re: [IC] Meridian
« Reply #46 on: Fri, 07 August 2020, 12:30:41 »
Following
Offline myflowsocold
Re: [IC] Meridian
« Reply #47 on: Fri, 07 August 2020, 12:38:22 »
this is hype. Nice work on the IC!
Nunu | Lyn Whale R2 | Bauer | Satisfaction75 | WKL Polaris | TGR x Singa Unikorn
Offline HypeSloth
Re: [IC] Meridian
« Reply #48 on: Fri, 07 August 2020, 12:55:37 »
Finally an alice layout without the nav cluster, also a more traditional bottom row so I don't have to relearn mac shortcuts and in stock? Looks like a really solid board, great work guys.
Offline landosike
  • live from senegal
Re: [IC] Meridian
« Reply #49 on: Fri, 07 August 2020, 13:11:17 »
o god This is kinda sick bro
« Last Edit: Fri, 07 August 2020, 13:20:56 by landosike »
yoo yoooo yooo
