Author Topic: [HELP] - TX87 - SUO 87L V.1 PCB ISO configuration  (Read 3460 times)
Offline Adelscott
« on: Sun, 09 August 2020, 10:14:27 »
Does anyone own this SUO PCB and managed to configure it for ISO ? When the left shift is splitted, the 1U key is by default mapped to "SHIFT_L" (same as the actual shift) although it shows " < > |"  and it seems there's no way to select the right key.
Tried the TX_Device program in 4 versions : 2.2, 2.3, 3.2 and 3.6. None gives the ability to select the key.
« Last Edit: Sun, 09 August 2020, 10:39:16 by Adelscott »
Please think about ISO users, add a split left shift to your "alice style" keyboards
Offline Adelscott
Re: [HELP] - TX87 - SUO 87L V.1 PCB ISO configuration
« Reply #1 on: Tue, 11 August 2020, 12:06:26 »
I'm gonna reply to miself as TX just delivered a new version of the application and a new firmware, everything is OK now.
Here if it helps somebody in the same situation !
« Reply #2 on: Tue, 11 August 2020, 12:23:09 »
Thanks for the link - I'm sure it will help someone :thumb:
For the record version v4.1 has been added so that's the one that works.  Hopefully they won't break it in future versions but you never know...
Offline Adelscott
« Reply #3 on: Tue, 11 August 2020, 12:38:52 »
Yes 4.1 for the application with the firmware 1.05, thanks :)
