Author Topic: First custom keyboard, need switch advise  (Read 3824 times)
Offline Joe Mama
« on: Wed, 12 August 2020, 10:12:24 »
Hello! I am currently in the process of my first custom keyboard, but I am unsure of what switches I need. I am buying the GK64XS with the GMK sumi keycaps, but I'm unsure of what switches are compatible, will any switches be fine? Do I need a specific kind of switch if its rgb? I wanted to buy some gateron black inks and not sure if itll all work together. Thank you ahead of time for your assistance!
Link to keyboard:
https://www.banggood.com/Geek-Customized-GK64XS-RGB-Hot-Swappable-60-pencent-Programmable-bluetooth-Wired-Case-Customized-Kit-PCB-Mounting-Plate-Case-with-Replacable-Space-Key-p-1692275.html?akmClientCountry=America&rmmds=cart_middle_products&ID=62878306288382&cur_warehouse=CN
Offline pewpewnii
Re: First custom keyboard, need switch advise
« Reply #1 on: Wed, 12 August 2020, 19:53:19 »
For me, Im using GK64XS with Kailh Box Jade for 2 months. From the requirement you listed, i think gateron black inks is kinda good for this build
Offline treeleaf64
    • treeleaf64
« Reply #2 on: Wed, 12 August 2020, 21:19:02 »
this is keycaps thread but I think I can help~
U need 1u Rshift for keycaps,
Gat ink black will work!
Everyone must pay the cat tax
