Author Topic: Das 3 professional keyboard key sticky  (Read 2648 times)
Offline SirClickAlot
    • http://www.mrinterface.com
« on: Mon, 19 July 2010, 06:40:11 »
This happens to my '-' key I almost never use on my DAS K3 Pro. Sometimes it sticks and doesn't produce a click. It registers properly though, but somehow I find this very annoying for such an expensive keyboard.
I wonder if this is a quality issue with DAS or Cherry?
[Succes is when you get what you want
Happiness is when you want what you get]
Optimize your interfaces : http://www.mrinterface.com
Currently using( not necessarily my favorite : I iterate over my collection many times ):
Filco White Majestouch Mx Brown DS White on Black.
Looking for : New and interesting interfaces. Working on :www.deskthority.net
Offline wellington1869
« Reply #1 on: Mon, 19 July 2010, 11:03:14 »
Quote from: SirClickAlot;204041
metadot would no doubt honor a free exchange if you're having an issue with a key. you should simply contact their support line on their website.
my das S didnt have any sticky or problematic keys, fwiw.
but i will say that i do think cherry switches in general are a bit flakey; of the two scorpius m10's i owned, one did have sticky key (keyb replaced by the seller for free). So long as the customer support is 'full-service' i dont think you need to worry.
but it just goes to show that cherries are not, after all, buckling springs ;)
« Last Edit: Mon, 19 July 2010, 11:05:26 by wellington1869 »
using: ms 7000/Das 3
Offline gr1m
« Reply #2 on: Mon, 19 July 2010, 15:31:34 »
Is it the - key from the numpad? If so, high five, I have the same problem! It sticks to the bottom side of the switch.
Offline instantkamera
« Reply #3 on: Mon, 19 July 2010, 19:32:28 »
yeah I was thinking to myself, is this the same thread. Very strange, good thing you didn't get a DAS from NCIX ;)
Realforce 86UB - Razer Blackwidow - Dell AT101W - IBM model MCST  LtracX - Kensington Orbit - Logitech Trackman wheel opticalAMD PhenomII x6 - 16GB RAM - SSD - RAIDDell U2211H - Spyder3 - Eye One Display 2
