Author Topic: Newbie question on Topre keycaps  (Read 5858 times)
Offline gihrenzabi
« on: Wed, 26 August 2020, 18:53:22 »
May I ask a newbie question here..?
I am currently using Realforce 87UD55 - 10th (R1) and want to buy keycap sets to replace the current ones.  I saw many group buys at this forum (mainly GMK etc).  Are those compatible?  Or where can I buy suitable ones?  Thank you all.
Offline Auxo
  • Formerly CJD_Anthony
Re: Newbie question on Topre keycaps
« Reply #1 on: Wed, 26 August 2020, 19:40:23 »
GMK and most popular brands are all what you would call "MX" compatible keycaps. They absolutely will not fit Topre stems.
There are a FEW topre keyset makers, which you can find on kbdfans.com. Another avenue is a brand called Domikey, which has a limited selection of keycaps (not sure if they cover anything outside of HHKB tbh).
The last option is to actually get some MX-compatible sliders and REPLACE yours, which will actually allow GMK and any other MX compatible keycap set to fit onto your realforce :)
(For reference, the Realforce R2 RGB has MX-compatible sliders)
Offline gihrenzabi
« Reply #2 on: Wed, 26 August 2020, 19:48:49 »
Thank you so much for your answers, clear and precise!  And for those HHKB keycaps are they compatible to Topre?
« Last Edit: Wed, 26 August 2020, 19:50:49 by gihrenzabi »
Offline ddrfraser1
  • RIP Neil
« Reply #3 on: Wed, 26 August 2020, 21:55:07 »
Yes
