Author Topic: [GB] 8008 Inks Preorder Live! | Sept 6-20  (Read 8891 times)
Offline GarrettSucks
  • All project timelines at at timelines.omnitype.com
    • Omnitype
« on: Fri, 04 September 2020, 12:19:12 »
8008 INKS PREORDER
Preorder Information:
Open Sept 6 - 20
Unlimited Availability
Estimated Delivery Jan / Feb 2021
Switch Information:
$0.75 per switch (same cost as regular inks)
Produced by Gateron
PCB Mount
Housing matches GMK 8008 Modifiers
Stem matches GMK 8008 Pink
Gateron Yellow Spring
Linear | 4.0mm travel | 50g Actuation | 60-65g Bottom Out
Ink V2 Molds w/ reworked plastic mixture to achieve opaque housing.
These are different from regular black inks but the goal here was to keep the same experience with an opaque housing.
« Last Edit: Sun, 06 September 2020, 20:11:15 by GarrettSucks »
Re: [GB] 8008 Inks Groupbuy | Sept 6-20
« Reply #1 on: Fri, 04 September 2020, 14:25:54 »
Approved :thumb:
Offline Kokaloo
  • 🤘(• ω •)🤙
« Reply #2 on: Fri, 04 September 2020, 14:33:06 »
neat! inks are def my fav switches, and gat yellows are my fav springs. will be getting me enough to hold me over for the next few builds.
Offline CF73
« Reply #3 on: Fri, 04 September 2020, 18:06:03 »
finally here  :D def in for some!
Offline SxM Designs
  • https://sxmdesigns.com
    • Website
« Reply #4 on: Fri, 04 September 2020, 18:57:08 »
Finally. Looks awesome :)
Offline Domantas
Re: [GB] 8008 Inks Preorder Live! | Sept 6-20
« Reply #5 on: Sun, 06 September 2020, 14:01:48 »
8008 INKS PREORDER
Open Sept 6 - 20
Switch Information:
Produced by Gateron
PCB Mount
Proxy Information:
NA - Dixie Mech
EU - Mykeyboard.eu
Asia - iLumKB
Oceania - Daily Clack
The links above will updated to the store links once they are up.
Why there are no inks in mykeyboard.eu still?
    • Omnitype
« Reply #6 on: Sun, 06 September 2020, 20:11:39 »
All proxy links are up! Sorry for the delay!
