Author Topic: [IC]NEO Palette G67 - Gasket, Acrylic, full customize color, 65% - GB on Oct.23  (Read 51496 times)
Offline Patrickwu
Hello GeekHack
This is Patrick at NEO Keys (instagram: neokeys, GIVE AWAY will be done through instagram; Discord https://discord.gg/2MCKpQQ). I'm here to present you our first design Palette G67. The project started back in June and has gone through multiple stages of material test, design and samples and we're quite happy with what we have so far! And we'd love to hear some feedback and input from the community before release.
Case Features
-   Acrylic sandwich structure, with fully isolated, gasket mounted switch plate. Switch plate is supported by 6 silicone and 6 EVA gaskets and completely hidden from sides of the case.
-   Laser cut acrylic case plates
-   Switch plate options: Carbon Fiber, Brass
-   6.5 degree typing angle
-   18 pre-set case color schemes and more to come..
-   Fully customizable case color. 20 colors for each of 11 acrylic layers, total over 409,600,000,000,000 possible combinations. And more to come..
-   Countersink holes only. All mounting screws will be flush with case surface.
PCB Features
-   QMK programmable
-   Hotswap and soldered(ISO, 7U spacebar, split BS compatible)
-   Per-switch SMD RGB light
-   RGB blacklight
-   Center mounted USB-C port
About the group buy
-   What's included in the kit?
Kit comes with 11 layers of acrylic (7 layers of case body, 4 layers feet), PCB, switch plate, silicone and EVA gaskets (with spare), titanium coated M2 screws, brass posts, allen wrenches, USB-C cable, a microfabric cloth
-   How much?
Kit in pre-set color scheme with carbon fiber plate - $140
Full custom color scheme +$10
Brass plate +$10
Shipping is not included. Expected to be $50 for US and Europe. Board will be shipped from Shenzhen China.
-   How to place order?
Custom features are far too complicated to be handled through order forms, so we set up a website for this group buy, link will be posted in the groupbuy thread.
And here is a preview of color customization interface. Sorry for not having a real time rendering page. When GB starts each day I will run a few renders requested by customers and post on IG.
-   MinOQ and MaxOQ?
Groupbuy will be on when order quantity hits 100. Maximum orders will be capped at 200.
First 50 orders will be shipped with a free acrylic lube station in random color.
-   When?
Groupbuy will start within a week or two depending on IC result on Oct. 23 Friday (as my account was registered on Aug. 21 and only 2 months old account is allowed to post in GB) and open for orders for 1-2 weeks depending on order numbers.
Lead time should be somewhere around 60-90 days.
Here are some renders of preset colors schemes.
Some photos of sample boards in Void and Dawn+GMK Cyan color scheme
Here is a sample of Palette in Eternity color scheme, which has 3 layers of frosted clears and 4 layers frosted pink, with a brushed brass plate.
Eternity built up with brass plates, ink red's.
Some buyer's customized color scheme renders:
Here are photos of sample plates, just to give you an preview of the actual colors.
Clear, Frosted Clear, Frosted Black, Red, Purple, Orange, Dark Blue, Light Blue, Cyan, Green, Yellow
Flo Orange, Flo Pink, Flo Yello, Flo Green, Flo Blue, Frosted Orange, Frosted Pink, Frosted Yellow, Frosted Cyan
If you have any questions, suggestions or feedback regarding the product or design, please feel free to post or DM or mail me at support@neokeys.net
I have received some quetions from Discord and via emails, I'm sharing the answers here as well. So here you go Q&A
How does the gasket structure work?
Here are some photos to explain the gasket structure.
Plate locates between second and fifth layer, supported by 12 silicone and EVA gaskets which are taped to the plate itself. The plate is completely hidden from all 4 sides of the case, giving the user the freedom to customize case color scheme.
Dimensions of the case and typing angles?
Here are some drawings and numbers. Opening for USB-C cable is 12mm wide.
By using 3 or all 4 layers of feet, you can have 5.3 or 6.9 typing angle.
Weight?
Complete board with brass plate weight - 810g
Copmlete board with carbon fiber plate weight - 630g
All progress will be posted in this thread.
2020.9.16 IC thread started.
2020.9.16 Updated lead time.
2020.9.17 Updated solder PCB with ISO, 7U space and Splite BS support; Product specs updated; Estimated shipping cost updated; Discord server set up; Eternity sample pic posted.
2020.9.18 GB date confirmed. It's embarassing but I just realized that my account can't post in GB subforum until Oct 22. But good thing is that it'll give me enough time to finish soldered PCB design.
2020.9.24 Updated with some drawings and numbers to answer questions from discord.
2020.9.26 Updated weight of board. Added some beautiful renders of colors schemes from buyer's customization.
2020.9.29 Updated sample plate photos
2020.10.15 Updated kit content
2020.10.21 Groupbuy starting in 2 days. IC thread locked.
« Last Edit: Wed, 21 October 2020, 05:45:13 by Patrickwu »
NEO Element G67 Kit Groupbuy
Offline darthcapn
Re: [IC]NEO Palette G67 - Gasket, Acrylic, full customize color, 65%
« Reply #1 on: Wed, 16 September 2020, 01:52:04 »
Interested. I'd buy this today lol.
Praxis | Portal | Frog F13 | Vega | Sat75 | F2-84 | Iron 165 | KFE CE | Spring | Pandora | Mr Suit | MGA | Jelly Epoch
Dolice | Glare | Vmax chyuu | W1-AT | Hoshizora | iron 160 | Nazaré | Tomo
Offline Patrickwu
« Reply #2 on: Wed, 16 September 2020, 01:58:09 »
thanks for the support! That means a lot to us.
We'll have a couple more samples arriving by the weekend. Stay tuned!
Offline VagueOrigin
« Reply #3 on: Wed, 16 September 2020, 02:05:43 »
Thought I was done with acrylic cases, nice touch with the "notebook divider" like tabs to see all the layer colors. Im in!
Sent from my SM-G975U using Tapatalk
Offline Patrickwu
« Reply #4 on: Wed, 16 September 2020, 02:14:07 »
Thanks and welcome on board!
Offline ItszBrian
    • GMK Devoted
« Reply #5 on: Wed, 16 September 2020, 02:27:01 »
This is pretty neat, I'm in if I can get a non-hotswap pcb version.
Offline Willtato
  • I like small Keyboards
« Reply #6 on: Wed, 16 September 2020, 02:28:01 »
Hi, loving this.  Just curious, will there be florescent acrylic options?
Sent from my HD1913 using Tapatalk
Offline Drauthius
« Reply #7 on: Wed, 16 September 2020, 02:35:06 »
Looks awesome!
Any plans for an ISO-layout?
Offline Ireojimayo
  • Yo dayo
« Reply #8 on: Wed, 16 September 2020, 02:48:49 »
Very interested in this board.
I love the large range of colour schemes. I know you are allowing customization but I wouldn't be able to think of good colour combos.?
You don't have any other place to keep up with this right? like an disc, insta or email list?
Offline Patrickwu
« Reply #9 on: Wed, 16 September 2020, 02:59:21 »
my team is currently working on that. I dont think it'll be available by the time this groupbuy starts though. Stay tuned with us anyway. thanks!
Offline Patrickwu
« Reply #10 on: Wed, 16 September 2020, 03:00:34 »
yes there will be florescent green, orange, pink and blue. the sample board in Dawn actually has flo orange on 4th and 5th layers.
Offline Patrickwu
« Reply #11 on: Wed, 16 September 2020, 03:01:44 »
Looks awesome!
ISO should come with the soldered version PCB that we're currently working on. Not 100% sure it'll be available with this groupbuy though.
Offline Patrickwu
« Reply #12 on: Wed, 16 September 2020, 03:04:13 »
Insta account is neokeys. I will have a website up soon with the order page for this groupbuy and constantly post updates there as well.
I dont really have time to manage discord at the moment...
Offline Ireojimayo
  • Yo dayo
« Reply #13 on: Wed, 16 September 2020, 03:08:44 »
Some additional questions
What lead time do you expect if this reaches 200 orders?
Where will these ship from?
Offline Patrickwu
« Reply #14 on: Wed, 16 September 2020, 03:20:12 »
Good question. Was about to post that info in the upcoming groupbuy thread.
lead time should be somewhere around 60-90 days.
Ship from Shenzhen China.
Offline Flexmaster
« Reply #15 on: Wed, 16 September 2020, 03:58:38 »
Interested
Offline violeaf
« Reply #16 on: Wed, 16 September 2020, 04:19:15 »
Love this, and +1 for iso support
Offline jAngeles
« Reply #17 on: Wed, 16 September 2020, 04:29:06 »
consider my interest checked :thumb:
Offline Patrickwu
« Reply #18 on: Wed, 16 September 2020, 04:42:08 »
thanks guys!
Offline tommyamoszhao
« Reply #19 on: Wed, 16 September 2020, 05:19:35 »
Loving it!thunbs up!&& count me in!
Offline SxM Designs
  • https://sxmdesigns.com
    • Website
« Reply #20 on: Wed, 16 September 2020, 05:27:16 »
I have seen quite a few layered board. The issue I have is the misalignment of layers either from the beginning or after a while. How will this board fare in terms of misalignment of the layers?
Also curious to see a few more pics of the bottom side of this board.
Honestly, the board looks quite good. However, I think it will be super light and 140 ish dollars would be a tad too much.
Offline eskimojo
    • KeycapLendar
« Reply #21 on: Wed, 16 September 2020, 05:54:44 »
Looks awesome!
Interested in this if it's available with a soldered PCB and plate with the usual options (ISO, split backspace, 7u space, etc.)  :thumb: Great choice in default plate material too, I love CF  ;)
Offline marshskitow
« Reply #22 on: Wed, 16 September 2020, 06:01:52 »
+1 for iso
Envoyé de mon iPhone en utilisant Tapatalk
Offline Patrickwu
« Reply #23 on: Wed, 16 September 2020, 06:34:46 »
Looks awesome!
yep we're working on that. thanks for the feedback!
Offline Willtato
« Reply #24 on: Wed, 16 September 2020, 06:39:29 »
I was wondering if the top layer on the abyss and nova are clear or frosted.
Thanks
Offline 100 percent horse
« Reply #25 on: Wed, 16 September 2020, 06:39:36 »
Very cool, I'll say I'm interested in this.
Sent from my Pixel 3a using Tapatalk
Offline Patrickwu
« Reply #26 on: Wed, 16 September 2020, 06:43:02 »
Thanks
Abyss top layer is a clear cyan.
Nova top layer is a clear.
I'll have a sample Abyss assembled and posted soon..
Offline atlanticise
« Reply #27 on: Wed, 16 September 2020, 07:25:41 »
this looks so interesting and pretty!! hoping to get my hands on this.
Offline andromache
« Reply #28 on: Wed, 16 September 2020, 08:29:43 »
I will definitely try to buy this when GB opens. Here for all of the custom color options.
Offline lbassett21
  • Plastic and Metal Enthusiast
« Reply #29 on: Wed, 16 September 2020, 09:01:05 »
Isn't this just a slightly different, GB version of the Kayak (A play on the Canoe)? The same materials, almost the same design, and a gasket plate are the only things that differentiate it from the kayak.
https://www.keebtalk.com/t/kayak-a-65-diy-keyboard/2724
Discord: Bassett#0001 | Reddit: /u/lbassett_21 | Instagram: BassettKeebs
Current Collection:
Keyboards:
OTD 360 Corsa | Kira80 | FMJ 80 | Matrix 8xv2.0 | Matrix 8xv1.2og | IBM SSK 1395217 (Stock Trading) | Hiney TKL One PC | Hiney TKL One FNF | G81-3077SAU | G81-3007SAU | G80-9039HAAUS | HHKB Pro 2 Type S | Realforce 84ub |  Lunar 2 |  Sord KB-101 | Percent Canoe | G80-3190HSU | Alps64 | Xerox 6085 Keyboard | IBM 5576-001 | IBM Model M 1390131 | IBM Industrial Model M 1394946 | IBM Model M SSK 1393691 (SABRE) | IBM Model M 1393464 | HHKB Pro Hybrid Type S | Dell AT101 | Leading Edge DC3014 | IBM Model F AT | IBM Model F122 | G80-0693 | G80-0528 | G81-3100SDU | G80-1838HPU | DAS 2 (G80-3485LWNUS-2 | Texas Instruments Keyboard (SKCM Brown) | G80-9002LBBXX
Keycaps:
ESA-3000-HASR0 | G81-3077SAU | G81-3100SAU | BMOL 5206 UP (Desko Color) | BMOL 4000 U (Desko) | GMK Solarized Penumbra | Desko Black (1/10) | GMK Beta JS | IBM APL2 w/Box 1395624
Offline homerowco
    • Homerow.Co
« Reply #30 on: Wed, 16 September 2020, 10:47:22 »
https://imgur.com/a/D6RDxdb
Offline hottrout
  • I'd Hit Dat Key
« Reply #31 on: Wed, 16 September 2020, 11:13:47 »
This makes for an interesting little board.  I would be interested if ISO was to become available.
Nice design by the way.
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
Offline HawaiiOahu
« Reply #32 on: Wed, 16 September 2020, 11:32:48 »
Are you guys going to have arctic blue frost acrylic color?
Offline Patrickwu
« Reply #33 on: Wed, 16 September 2020, 11:37:51 »
thanks. working on a soldered PCB design as we speak.
Offline Patrickwu
« Reply #34 on: Wed, 16 September 2020, 11:39:07 »
Not exactly sure if we're thinking the same color but check out the sample photo of Dawn, the first layer is a frost cyan, which might be the one..
Offline norb
« Reply #35 on: Wed, 16 September 2020, 11:40:19 »
this is pretty sweet!
a few questions:
1. can you estimate the shipping costs to germany?
2. the renders seem to have about 7 layers of acrylic, but you write that a kit will come with 11 layers?
3. ISO will definitely be available in a second round of gb a later time?
Offline HawaiiOahu
« Reply #36 on: Wed, 16 September 2020, 11:52:02 »
Is the top supposed to show the layered colors?
Offline super_tu
« Reply #37 on: Wed, 16 September 2020, 11:53:56 »
I'm in. Does this support split backspace?
« Reply #38 on: Wed, 16 September 2020, 12:12:52 »
The GB vs. homemade distinction, case detailing, and mounting type seem like pretty fundamental differences to me. Might as well say that every aluminum 65% is also basically the same - and maybe you'd be right along the same standards, but why nitpick here?
Offline The.Ryan.Gamer
« Reply #39 on: Wed, 16 September 2020, 12:14:05 »
This is very nice! Fast fulfillment too!
Couple of questions tho:
1. Where's the IC?
2. Can i buy 2 boards, if possible 3?
3. Where will this ship from? I'm in Asia, i would like to use DHL Express, would that be possible?
4. Is there a Discord Server?
5. What's the QC/QA process for this boards? Just curious.
Offline NotchBomber
« Reply #40 on: Wed, 16 September 2020, 12:14:59 »
I am in, this is something I have been looking for the past 3 months
Offline Belvin
« Reply #41 on: Wed, 16 September 2020, 12:50:42 »
One day, ICs will be started that remember ISO users exist.
Offline Wonderfool
« Reply #42 on: Wed, 16 September 2020, 14:36:36 »
Very nice.  Hope I can snag one!
Offline Smoothie
« Reply #43 on: Wed, 16 September 2020, 16:29:58 »
Love the Nova render! Will totally be trying to pick one up!
« Last Edit: Wed, 16 September 2020, 16:36:37 by Smoothie »
Offline Freeaboo
« Reply #44 on: Wed, 16 September 2020, 17:17:23 »
I'm in, as long as there will be a solder version or if this works with other 65% PCBs like the KBD67 that I can solder.
Offline Drakenocas
« Reply #45 on: Wed, 16 September 2020, 18:48:07 »
What's the expected price atm?
Offline Smoothie
« Reply #46 on: Wed, 16 September 2020, 18:59:53 »
Price is in the IC $140 for base
Offline sneekypoo
« Reply #47 on: Wed, 16 September 2020, 19:38:05 »
Sign me up!
Offline Patrickwu
« Reply #48 on: Wed, 16 September 2020, 23:05:04 »
a few questions:
hey Norb, good quetions there.
1. I dont have a final packaging yet but if it's somewhere around 1.5-2.0kg, shipping cost should be $40
2. 7 layers for case body, 4 layers for the feet. I just can't seem to find a good camera angle to display them but they're there and you can customize their color.
3. As so many folks are asking for ISO I might push back the GB a little bit and make it available for the first round.
Offline Patrickwu
« Reply #49 on: Wed, 16 September 2020, 23:07:48 »
If you mean the tabs design yes. The board is called Palette, you get to mix and match the colors and appreciate your work  :D
