Author Topic: [IC] Nyaong75  (Read 125301 times)
Offline jmSur
[IC] Nyaong75
« on: Fri, 18 September 2020, 12:33:33 »
GB fulfilled and extra sale just started.
Please visit https://bahmstudio.com/products/nyaong75-extra-sale here for more information.
Nyaong 75
A keyboard of the cat, by the cat, for the cat.
Below are real pics taken recently. These are not renders.
https://imgur.com/gallery/rtUBzTW
[Nyaong75 GB notice]
  •  GB period : from KST 1:00 (1:00 AM) 26th August 2021
                        to KST 23:59 (11:59 PM) 30th September 2021
  •  Estimated fulfilment time : Late April 2022
  •  Max 300 Sets
  •  This GB includes
      Nyaong75 top and bottom case
      Aluminium plate
      Solder PCB
      Semi-transparent acrylic diffusers for both ears
      Bolts, bumpons, grommets etc
      Packaging
  •  FCFS : https://bahmstudio.com/
[Specification]
  •  Typing angle : 6 degrees
  •  Material
      Upper case : Alu 6061
      Bottom case : Alu 6061
      Front face ear : Semi-transparent acryl(acrylic diffuser)
      Bottom engraving : 1.5mm grooves
  •  Weight : 2.60Kg unbuilt
  •  75 Layout - Bottom row(R6) supports only 1.25 1.25 1.25 6.25 1.25 1.25 due to the inside screw holes
  •  Aluminium plate
  •  Burger mounted on top case
  •  Inside screw holes
  •  PCB supports ANSI/ISO, soldering required, screw-In-stabs
  •  5x RGB LED on each ear(total 10 RGB LEDs)
  •  Bottom engraving : Smiling face, Butt
  •  Colour
     Black anodized top and bottom + Black anodized aluminium plate
     Rose Gold anodized top and Gold anodized bottom + Gold anodized aluminium plate
     Rose Gold anodized top and Black anodized bottom + Black anodized aluminium plate
     Silver anodized top and bottom + Silver anodized aluminium plate
Detailed info can be found on below discord server.
  •  Discord : https://discord.gg/akrfNJC
Ask not what your cat can do for you – ask what you can do for your cat.
« Last Edit: Sat, 29 October 2022, 11:48:14 by jmSur »
Offline yoot
    • none
Re: [IC] Nyaong75 - 75% Aluminum Keyboard for Cat Enthusiasts
« Reply #1 on: Fri, 18 September 2020, 12:34:18 »
Images seem to be broken
Offline jmSur
« Reply #2 on: Fri, 18 September 2020, 12:43:18 »
Am not sure why the images are broken...le me fix this.
Offline meowscanttype
  • 65 is bad
« Reply #3 on: Fri, 18 September 2020, 13:15:01 »
This is so good, not bias....
Offline jAngeles
« Reply #4 on: Fri, 18 September 2020, 13:19:11 »
wtf this is dope
Offline Xonuss
« Reply #5 on: Fri, 18 September 2020, 14:11:22 »
I am so happy that the GB doesn't start until January, then I have time to save up. This looks absolutely amazing and I think the LED ears is a fantastic idea!
Offline VagueOrigin
« Reply #6 on: Fri, 18 September 2020, 14:18:32 »
I like your reasons for it, break the mold!
Sent from my SM-G975U using Tapatalk
Offline kawhi
« Reply #7 on: Fri, 18 September 2020, 16:27:16 »
is the cat face a cover that goes over the keyboard? or is it on the bottom of the keyboard?
personally I like the idea of a cover to 1. make the design more visible and 2. to protect against dust and such when not in use
Offline purryoverlord
« Reply #8 on: Fri, 18 September 2020, 16:31:37 »
So adorable
Offline Choobies
« Reply #9 on: Fri, 18 September 2020, 18:22:38 »
Could it be an angle less than 7 degrees?  To improve typing ergonomics and I believe it would help the shape achieve the overall vision of the board.  :)
Offline jmSur
« Reply #10 on: Fri, 18 September 2020, 19:26:33 »
Is the back of the keyboard.
Cover with a cat face is also a good idea, but have to think about how to make the sideface, cause it's curved. Bending (like acryl kebb cover) seems not possible. Another options are molding and cnc'ing, but then the production cost will be expensive.
Let me see if there is a way to make the cover easy and cheap.
Offline jmSur
« Reply #11 on: Fri, 18 September 2020, 19:33:35 »
Will make a poll regarding the typing angle.
Join my discord!
Offline packman86
  • Morning Coffee
« Reply #12 on: Fri, 18 September 2020, 20:28:53 »
A keyboard I would love to see at a meetup in the near future!
Keyboard Collection:
TGR Jane V2 | TGR Jane V2 CE | TGR Alice | TGR Dolice | TGR 910 | TGR x Singa UNIKORN 60 | Matrix 8XV 2.0 Korea Version | Matrix 8XV 2.0add | LZ CLS s h x | Duck Jetfire | TX-CP | QXP | Noxary X65 | RAMA M60-A | Model F62 "Kishsaver" | Daji OC 2XL FnF Black
Offline SlipperyPeteED
« Reply #13 on: Fri, 18 September 2020, 23:32:50 »
any chance it will come in garfield colors?
Offline jmSur
« Reply #14 on: Fri, 18 September 2020, 23:38:16 »
Will add yellow colour in the poll
« Reply #15 on: Fri, 18 September 2020, 23:43:33 »
garfield is orange ****
Offline fabijolo
  • I like expensive plastic.
« Reply #16 on: Fri, 18 September 2020, 23:45:42 »
This is actually amazing!!
Offline omnipotions
« Reply #17 on: Sat, 19 September 2020, 02:21:31 »
I am way too hyped for this! Good luck with everything. Will be following closely.
Offline jmSur
« Reply #18 on: Sat, 19 September 2020, 04:07:05 »
Offline VipermanGT2
« Reply #19 on: Sat, 19 September 2020, 04:42:42 »
Plz tell me this is a joke.
Offline Willtato
  • I like small Keyboards
« Reply #20 on: Sat, 19 September 2020, 04:58:54 »
I would totally buy this if I could secure funds lol
Sent from my HD1913 using Tapatalk
Offline manaorme
« Reply #21 on: Sat, 19 September 2020, 05:03:11 »
7 months left til NEXT APRIL :)
Offline mrpetrov
« Reply #22 on: Sat, 19 September 2020, 15:36:36 »
this is so ridiculous it's a must-have
Offline DuellM
  • Keyboard Fatty
« Reply #23 on: Sat, 19 September 2020, 15:37:11 »
I need this
Offline DuellM
  • Keyboard Fatty
« Reply #24 on: Sat, 19 September 2020, 16:10:33 »
Any chance for the black and gray to come with pink acrylic  ear inserts? That would go great with the GMK Pono I preordered  ;)
Offline jmSur
« Reply #25 on: Sat, 19 September 2020, 20:04:34 »
A poll regarding the colour and insert is on-going in my discord. Join and vote!
Offline DuellM
  • Keyboard Fatty
« Reply #26 on: Sat, 19 September 2020, 21:45:34 »
Will Do 😊
Offline raykcy
    • RnCables
« Reply #27 on: Sat, 19 September 2020, 21:48:29 »
wildcat is gonna love this!!
Offline zoo
    • zoo
« Reply #28 on: Sat, 19 September 2020, 23:29:28 »
is it possible for face and tail to be on the board at the same time or are these interchangeable plates?
Offline dom
  • allergic to hypocrisy
« Reply #29 on: Sun, 20 September 2020, 00:50:43 »
Congrats for trying something different, even if this is not for me, I appreciate the effort :) Good luck!
Offline gbenz
« Reply #30 on: Sun, 20 September 2020, 02:04:44 »
Absolutely adorable
Offline jmSur
« Reply #31 on: Sun, 20 September 2020, 06:17:05 »
No for both questions. You have to choose between face or butt. Or you can buy both. Hmmm, but I will consider to sell  the bottom case only as an option(have to talk with the company and cnc factory first).
Offline Emir
  • icon mods
  • Bandit
    • Discord
« Reply #32 on: Sun, 20 September 2020, 14:00:12 »
Is there a full brass version?
Offline jmSur
« Reply #33 on: Sun, 20 September 2020, 19:33:34 »
Sorry, no. Only aluminum version is available.
Offline tonyjones
  • I like big butts and I cannot lie.
« Reply #34 on: Sun, 20 September 2020, 23:34:37 »
This is endgame. Count me in.
Offline Ramen Champ
« Reply #35 on: Mon, 21 September 2020, 01:52:01 »
love the originality! High preference for 6063. I look forward to seeing this progress into the GB phase :)
edit: Do you think it would be possible to see this rendered with some keycaps?
twitch.tv/ramenchamp_
Offline jmSur
« Reply #36 on: Mon, 21 September 2020, 04:48:43 »
I also want to make it with 6063. I have to discuss with the factory more. Will make renders with keycaps too. Will take couple of days.
« Last Edit: Wed, 23 September 2020, 20:14:30 by jmSur »
Offline ben56k
« Reply #37 on: Mon, 21 September 2020, 10:18:43 »
really interested as an ISO user.
Offline Crazy Designers
    • Angry Miao Official Website
« Reply #38 on: Wed, 23 September 2020, 04:15:10 »
nice kit :thumb: :thumb: :thumb:
Angry Miao Team. Future Art Community.
Offline yui
« Reply #39 on: Wed, 23 September 2020, 05:24:20 »
well it is nice but very expensive for a joke... tbh would it have been sub 100 i would have grabbed one but i know it is not possible with machined aluminum, if you plan to make a much cheaper plastic version i would be in for sure.
Offline VagueOrigin
« Reply #40 on: Wed, 23 September 2020, 07:10:08 »
PC version would be nice
Offline jmSur
« Reply #41 on: Wed, 23 September 2020, 20:13:43 »
No, it's not a joke. If you don't like the style of Nyaong75, should better buy more conventional styled keyboard.
And to make a plastic version under 100usd, moq should be more than 50K. Therefore, am not going to make a plastic version. Sorry.
Offline jmSur
« Reply #42 on: Wed, 23 September 2020, 20:15:36 »
PC version is more expensive than alu version. CNC costs more.
Offline Ashen_21
« Reply #43 on: Wed, 23 September 2020, 20:19:50 »
I love this so much! It's so adorable!!!
Offline o3okevin
« Reply #44 on: Thu, 24 September 2020, 12:08:21 »
yeeesssss
Offline noodleman
« Reply #45 on: Thu, 24 September 2020, 12:16:23 »
the fact that this board hasn't been rendered with GMK Greg yet is a travesty.
Offline jmSur
« Reply #46 on: Thu, 24 September 2020, 12:30:46 »
Sorry, give me some more time. Am currently busy with other works. I will make a render with GMK Greg. But Greg is a dog, isn't it?
Offline gbenz
« Reply #47 on: Thu, 24 September 2020, 12:39:00 »
That is actually a genius idea. Greg might be a dog but he has the pointy ears.
Now I really want one that matches the colors of GMK Greg! Maybe not this run, but in the future along with the powder white?
Offline Drakenocas
« Reply #48 on: Fri, 25 September 2020, 18:52:15 »
I down to build one of these for niece.  She'll one day reflect on when Uncle Drake gave her 600 dollar keyboard that looked like a cat when she was 11, and never realize I had 600 bucks tied up in it.
Offline bl1978
« Reply #49 on: Sun, 27 September 2020, 23:29:10 »
I think your design will have problems in manufacturing.
Topre Realforce 103 (PBT Keycap)
Topre Realforce HiPro
KBC Poker 60% (PBT Keycap)
