Author Topic: Durock linears vs alpacas  (Read 12052 times)
Offline Error213
« on: Sat, 19 September 2020, 13:22:11 »
I need help which is better
Offline Rob27shred
  • Insane in the Membrane! 👻
Re: Durock linears vs alpacas
« Reply #1 on: Sat, 19 September 2020, 13:54:12 »
AFAIK Alpacas are just a recolor of Durock linears made under the JWK banner.
Offline Error213
« Reply #2 on: Sat, 19 September 2020, 14:40:56 »
oh uhh ok
Offline Rob27shred
« Reply #3 on: Sat, 19 September 2020, 15:09:29 »
Durock & JWK are one in the same as far as product is concerned. I believe Durock owns the factory & machinery, then JWK contracts them to produce their switches. Some switches have their own molds or use different materials (V2 Tangies as an example), but most are just recolored Durock L series switches on the linear side & T1s on the tactile side.
Offline Sup
« Reply #4 on: Sat, 19 September 2020, 18:52:20 »
Same switch recolored
current
Coming soon
Offline treeleaf64
    • treeleaf64
« Reply #5 on: Sat, 19 September 2020, 22:29:36 »
Do you know this for a fact? Lol  I thought it was the other way around... I thought JWK factory produces the switches and Durock is the store owner.
Everyone must pay the cat tax
Offline Rob27shred
« Reply #6 on: Sun, 20 September 2020, 12:10:13 »
I might have it backwards, I just know for sure they both make their products in the same factory with the same equipment sans molds in certain cases.
Offline treeleaf64
    • treeleaf64
« Reply #7 on: Sun, 20 September 2020, 17:56:57 »
Yes sir this is true ! I like their switches, I just wish they had better sound
Offline diazel
« Reply #8 on: Mon, 21 September 2020, 06:24:44 »
The cheaper one. You won't be able to tell a difference.
Offline treeleaf64
    • treeleaf64
« Reply #9 on: Mon, 21 September 2020, 11:19:44 »
Since yesterday  I have found out from my favorite keyboard man Blacksimon  that Jwk top housing is very thin , and this is why it produces a high pitched sound.
Personally, I've always had the opinion that JWK switches are not good value. Compared to Tealios, they are good, but you can get around 3 Gateron switches for 1 JWK. And they (Gateron) sound a lot better, and feel almost as good as JWK.
Offline Sup
« Reply #10 on: Tue, 22 September 2020, 06:52:35 »
Have you looked at H1 switches? Its also made by JWK but uses a thicker top. H1 has a custom top mold made by JWK.
current
Coming soon
Offline treeleaf64
    • treeleaf64
« Reply #11 on: Tue, 22 September 2020, 15:30:56 »
Yes I've used them. However (to me) the sound is not noticeably different from other JWK.  It still doesn't sound as good as the Milk top black bottom Gateron switch.
« Reply #12 on: Wed, 23 September 2020, 07:59:58 »
I've been out of the loop on linears, seems like there have been a flood of decently smooth switches in the last year or so.
Do the Alpacas sound deeper than lubed vintage MX blacks? Or are Cherry housings still king for sound*?
* for MX style housings, lets not bring Alps into this  :D
« Last Edit: Wed, 23 September 2020, 08:28:56 by directheatedtriode »
Offline treeleaf64
    • treeleaf64
« Reply #13 on: Wed, 23 September 2020, 08:53:31 »
Cherry
