Author Topic: Keyboard foam?  (Read 9331 times)
Offline thestateofmay
Keyboard foam?
« on: Tue, 22 September 2020, 16:55:29 »
I don't feel like buying custom keyboard foams so I'm planning on buying some foams from Amazon and cut them myself. Do the type of foam matter? I'm look at these: https://www.amazon.com/Sheets-Craft-Cosplay-Thickness-1-10mm/dp/B07BSWRCQM
I made some rough measurements, I think the 1mm can fit as stab foams and the 2-5mm foams can fit as PCB or plate foams. Am I right about that? Does anyone have experience with this?
Offline SKx1
Re: Keyboard foam?
« Reply #1 on: Tue, 22 September 2020, 17:24:49 »
I use the 1mm foam from the link you shared and works just fine in my builds. Go for it.
Re: Keyboard foam?
« Reply #2 on: Tue, 22 September 2020, 17:42:38 »
Remember that it doesn't have to lay flat in sheets. You can also fill any configuration of void with strips rolled into cylinders.
- Franklin Roosevelt 1933
Offline ddot
  • Master of Suspense
Re: Keyboard foam?
« Reply #3 on: Tue, 22 September 2020, 18:45:30 »
I've had good luck with shelf liner over the years to dampen the noise.  Similar to this:
https://geekhack.org/index.php?topic=52677.0
Re: Keyboard foam?
« Reply #4 on: Tue, 22 September 2020, 21:00:02 »
Hmm I guess besides the aesthetics, they're mostly the same functionally...?
Offline Leslieann
Re: Keyboard foam?
« Reply #5 on: Tue, 22 September 2020, 21:57:44 »
I'm using that as well.
I've also used the foam that comes with motherboards but I don't think it works as well.
Unless your case is plex you can't see it anyhow.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline treeleaf64
    • treeleaf64
Re: Keyboard foam?
« Reply #6 on: Wed, 23 September 2020, 08:51:49 »
Art foam works. I have 2 mm sheets of it
Everyone must pay the cat tax
Offline hpetrovski
  • Osum
Re: Keyboard foam?
« Reply #7 on: Mon, 12 October 2020, 16:20:00 »
I've found that regular polyurethane foam, usually used for upholstery works great. I bought a couple of 4mm rolls to fix some hollow cases, but usually you'd go with something thinner. Thin sorbothane is also a good option, but I try to use foam as a last resort.
Offline CarnageHimura
Re: Keyboard foam?
« Reply #8 on: Mon, 12 October 2020, 19:48:47 »
Yes that works, I've used that too.
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
Re: Keyboard foam?
« Reply #9 on: Mon, 12 October 2020, 23:01:08 »
shelf liner is the classic option lol
Offline KPreeny1
Re: Keyboard foam?
« Reply #10 on: Tue, 25 January 2022, 05:11:14 »
I use thin sheets of plastazote which works pretty well
Offline c.a.t.
  • All about Keyboards sound...
    • Click and Thock
Re: Keyboard foam?
« Reply #11 on: Fri, 04 February 2022, 21:59:24 »
With my firsts builts, I buy cheap foam and cut it myself! it did the job very well.. but my god the lost of time... Just cut it, try it, cut it....
Now I buy the foam fiting the pcb / plate on kbdfan... Cost a little bit more, but save a lot of time!!
JS - aka Click and Thock
Offline granola bar enthusiast
Re: Keyboard foam?
« Reply #12 on: Sat, 23 April 2022, 22:18:27 »
the standard thickness' for the most common foams used in "enthusiast keyboards' are .5mm for PE foam, 3.5mm for plate foam, and whatever removes the hollowness/ping from the bottom of the case if there is any the best for case foam. completely unrelated but just wanted to put it out there. Not sure if 5mm foam would work for the plate
