Author Topic: [IC] IBM M2F Conversion Kit  (Read 6453 times)
Offline fricked
« on: Wed, 23 September 2020, 16:58:16 »
This is an interest check for an IBM Model M to F conversion kit.
The purpose of this mod: to replicate the superior Model F internals in the superior layout and availability of the Model M.
The kit would include:
-   (110x) Model F flipper (reproduction; not an original IBM part)
-   (110x) Model F spring (reproduction; not an original IBM part)
-   (1x) M2F PCB
-   (1x) QMK xwhatsit Controller
The process would be fairly straight-forward, though bolt/screw mod experience would be a plus:
1: acquire an IBM Enhanced Keyboard (Model M with the standard 101-105 key layout)
2: disassemble the keyboard including the inner assembly (chopping off remaining rivets)
3: cut away a couple nubs on the underside of the M barrel plate to make room for some of the flippers (no big deal, it will still look and function the same and can always be reverted to an M)
4: put the new springs on the new flippers, put these in the barrel plate, and replace the membrane with the new PCB
5: reassemble the keyboardassembly; bolt/screw mod is necessary, I recommend bolt mod
6: attach the controller to the PCB (will probably need some basic soldering) and screw it into the back plate
The kit would be for the standard layout Model M (101-105 key) only; I will be happy to do a 122-key and SSK version if this project is a success.
Price would be $80 USD + plus shipping & applicable taxes/duties.
Discord server: will make one if there is interest
If you are potentially interested in buying a kit, please fill out this quick survey: https://forms.gle/oz6EXbdKAtyEKZAu7
This is important; I need to know there is enough interest before this project can become a reality.
Original thread is over on Deskthority: https://deskthority.net/viewtopic.php?f=7&t=24559
Offline hvontres
  • Buckling Spring Enthusiast - Full Size Evangelist
Re: [IC] IBM M2F Conversion Kit
« Reply #1 on: Wed, 23 September 2020, 21:25:22 »
You might want to contact the guys over at modelfkeyboards about getting larger quantities of their flippers made for this project : https://www.modelfkeyboards.com/product/flipperspring/
Henry von Tresckow
1986 Model M 1390131, 1987 Model M 1391401 , 1993 Model M2 Modded Reddragon k556(Test Mule) Boston Prototype x2 (Daily Drivers :) )
Offline apastuszak
« Reply #2 on: Sun, 14 August 2022, 20:51:10 »
So, are you planning to sell the kits for $80, or will you be doing the conversion for $80?
Offline dreieck
For 122 key (terminal version) model M?
« Reply #3 on: Tue, 04 October 2022, 08:45:45 »
Interested, survey filled out.
  • (110x) Model F flipper (reproduction; not an original IBM part)
  • (110x) Model F spring (reproduction; not an original IBM part)
  • (1x) M2F PCB
  • (1x) QMK xwhatsit Controller
How easy would it be to mod a 122 key Model M (terminal version)?
