Author Topic: [IC] GMK Lemon Lime  (Read 9059 times)
Offline Millionarc
[IC] GMK Lemon Lime
« on: Tue, 29 September 2020, 12:52:41 »
this is in very VERY early production and i want to post it some where to get it all setup
Details:
Keycap type: cherry
material: abs
manufacture:GMK
these will be double shot
to do list:
get colors matched or tuned to RAL
Novelties
Better Renders
Vendors
Finalize kits
Finding Vendors
Pricing
Deskmats?
« Last Edit: Tue, 29 September 2020, 13:10:18 by Millionarc »
Offline pngu
  • send noots
Re: [IC] GMK Lemon Lime
« Reply #1 on: Tue, 29 September 2020, 12:54:04 »
reserved
Offline TheInverseKey
  • You can run but you cannot hide!
« Reply #2 on: Tue, 29 September 2020, 12:56:02 »
I really like the sour taste I get from this set
Offline GaNeBaL
« Reply #3 on: Tue, 29 September 2020, 12:57:59 »
you could have at least clicked the render button in blender....
Obsessed with 60%TKLs
Offline Kokaloo
  • 🤘(• ω •)🤙
« Reply #4 on: Tue, 29 September 2020, 13:09:05 »
yo are you downloading borderlands 3 in the epic launcher? wanna team up?
Offline Bachoo
« Reply #5 on: Tue, 29 September 2020, 13:09:29 »
A tad too early to post i'd say, delete the post and go refine the set.
Offline MacSurfy
  • Designer & 3D artist
« Reply #6 on: Tue, 29 September 2020, 13:15:03 »
Add a plain background instead of a HDRI image. They are not meant to be visible in the render. Lower the reflection on your plastic material, GMK does not reflect that much (you can tell by the green reflections on the yellow caps). Add some KLE images to show off your kits.
GL!
Offline hark
« Reply #7 on: Tue, 29 September 2020, 13:23:41 »
uh oh, I'd reccomend you put some more work into this set before posting this
Offline illusixn
  • Formerly illusixn
« Reply #8 on: Tue, 29 September 2020, 13:27:56 »
Is this the drink that comes with the Travis Scott meal?
Offline CastleKeyboards
  • UK Vendor
    • Castle Keyboards Website
« Reply #9 on: Tue, 29 September 2020, 14:13:59 »
Juicy!
Offline lush_bunny
« Reply #10 on: Tue, 29 September 2020, 14:21:16 »
Surprised nobody dropped the pasta yet.
« Reply #11 on: Tue, 29 September 2020, 14:24:16 »
Spaget has not fallen out of someone's pocket yet.
Offline Poesjuh
« Reply #12 on: Tue, 29 September 2020, 17:01:05 »
DCS Turtle Power is saying hello to this set.
Offline EURA
« Reply #13 on: Tue, 29 September 2020, 17:37:52 »
This seems way too rushed. You might want to look at other ICs and what they have included before you go around posting a draft like this. At least have a start to proper kitting and some actual renders. To add, it seems like you put this out to just "claim colors." Whether that was your intention or not, that is still what I read from your wording. You should consider starting over with the post, but good luck with the process.
Offline Owl
« Reply #14 on: Tue, 29 September 2020, 18:23:53 »
I don't know. I am not normally the one to throw the copy pasta around for "low effort" IC's. I was typically the person to say that IC's are meant to just be that. Rough drafts of ideas. I mean that's how a lot of the early stuff started out. But yeah this feels really, useless?
I am probably going to come off as a gatekeeper or rude here but, like everyone knows GMK is ABS doubleshot. Adding that to your IC seems like fluff and like you JUST learned that yourself lol. Which makes me think you really aren't someone who's been around in keyboards for more than a couple of weeks. If you are a designer and you want to share that skill with different communities, I think that's great. But this is kind of a forgettable post. It doesn't provide any sort of information that a customer would need or want in order to gauge actual interest. I still don't think and IC needs to be a fleshed out product page. But I mean this shows VERY little thought process or intention. Like what am I supposed to tell you? That I like the colors? Because the colors could change drastically since it doesn't look rendered right. And I can't tell you if I like the kitting because, there isn't any. The most I can tell you is, "yeah I think a green and yellow set would look cool". And then I would forget this was ever posted. Like you could have at LEAST spent the extra, what, 60 minutes, picking out some RAL codes on the RAL website. You even mention that you want to RAL match so why not just pick on out before posting this so that I can at least say to myself, "hmmm yeah those colors could look good. I wonder how this person will use them?"
So yeah the post isn't very aware at all. No theme or goal. No concrete detail for me to latch on to. It's kind of a terrible post lol. I apologize for being so blunt but, it has to be said.
I don't want to discourage you. I think you should still work on it and develop it. Every set has the potential to be great! So don't stop here. But do a lot of research, work on it a little harder, and then update the thread. Give us something concrete instead of, this.
Offline dom
  • allergic to hypocrisy
« Reply #15 on: Tue, 29 September 2020, 19:07:24 »
This tool is excellent for testing and sharing ideas:  https://keyboardsimulator.xyz/
We'll see more and more people using it in the near future (assume).
Good luck with your future projects 🙂  Don't give up!
Offline Pyk_
« Reply #16 on: Wed, 30 September 2020, 10:03:45 »
I love that you didn’t even bother to crop out the taskbar. I thought for sure this post was a joke. However, if you are serious, probably spend some more time in the community looking at how others run their projects. Also, check out the keycap design discord if you haven’t already.
Offline Wangson
« Reply #17 on: Tue, 18 May 2021, 20:52:02 »
This is the most half assed ic ive ever seen.
Offline NovaRMK
« Reply #18 on: Tue, 18 May 2021, 20:54:08 »
can we please stop with these under-developed ICs
Offline convoliution
« Reply #19 on: Tue, 18 May 2021, 21:01:56 »
We should also do something about people resurrecting months-old ICs just to point out how lackluster they appear.
Offline azzipa
« Reply #20 on: Tue, 18 May 2021, 21:02:19 »
i’m in?
Offline brunosan_.
« Reply #21 on: Tue, 18 May 2021, 21:32:55 »
tas bien?
Offline ID99
« Reply #22 on: Tue, 18 May 2021, 21:52:00 »
instacop
Offline Laur
  • Formerly dudeship
  • gmk retro runic
    • wip
« Reply #23 on: Wed, 19 May 2021, 06:09:15 »
GTFO and don't come back. Click on most other ICs and you'll see the quality expected of an IC.
Offline Fraaaan
« Reply #24 on: Wed, 19 May 2021, 06:55:35 »
Please take a look at other interest checks and compare those to yours. The amount of effort you put into this IC reflects how much you care about it and what your standards are.
Offline hali
  • OHHHH MY GODDDDDD
  • please buy cat ears alice
    • hali.studio
« Reply #25 on: Wed, 19 May 2021, 08:26:28 »
wow thanks for necro wangson
anyways this set is old news and iirc the designer was actually booted from kdd because of it
Offline Baka Bot
« Reply #26 on: Wed, 19 May 2021, 10:09:58 »
This seems like the equivalent to just writing your name on a research paper then asking for constructive criticism. Back to the drawing board you go
Offline harlekein
« Reply #27 on: Wed, 19 May 2021, 11:01:53 »
twentyseventh!
Offline Kokaloo
  • 🤘(• ω •)🤙
« Reply #28 on: Wed, 19 May 2021, 11:49:11 »
why on earth was this bumped
