Author Topic: [IC] Monarch (WKL 65 w/ arrow cluster, knob, interchangeable inserts)  (Read 31305 times)
Offline DoCallMeKing
Monarch by King Boards
Please fill out the Interest Check Form below...
https://forms.gle/vfbGwMvrXM5xK7it8
Background
Welcome everyone and good morning/afternoon/evening wherever you may be!
I'm DoCallMeKing from King Boards.
I've been in the keyboard game for a while and have owned well over 100 boards doing budget builds from the kbdfans 5o all the way to highly sought after collectors items.
Something was lacking inside of me though. I had the yearning to take the knowledge and experience from all those boards I've come across to design something of my own.
I didn't want to create just another rectangle TKL though and slap a logo on it. I wanted to try and do something a little different. Challenge myself to create something that was customizable.
I'm a believer that 65% strikes the best balance for all users due to most people not using the F-row or numpad very often. So I wanted my first public design to start with that layout.
I've got a few other designs already in the hopper but wanted to get this one out first and completed before I start moving along to the other layouts.
All the boards in my series will be fit for a King.
Description
Monarch is a WKL 65% with a separated arrow cluster, rotary encoder knob, and interchangeable inserts.
I wanted the board to be customizable based on the users preference and the keysets they had on hand.
For example if you have been rockin' GMK Striker for a few months and want to change it up, I thought it would be great if you could change the look of your board as well to match GMK 8008 if you're throwin' that on!
The interchangeable inserts is really what I set out to create because I like to switch my keysets frequently and I was too often left with only a couple options that I could ever match to my board.
Simply pop the case open, swap out the insert to a new color, and you've completely changed the look of your board!
The rotary knob has grown to become something I really love on a board because it gives me easy quick control of so many different things.
Monarch deploys a 7.7o typing angle for a comfortable typing position anchored by a o-ring burger mount.
The front lip height has been kept at a low 17.5mm for a smooth transition.
Having a separate arrow cluster not only increases usability but also shows off more of the stunning inserts.
The board will also come with a 2mm custom embossed internal liner for increased sound dampening.
A large brass weight not only is visible from the back of the case but also spans a large portion of the bottom of the case with a beautiful engraving of the King Boards logo.
The PCB has already been designed and prototypes are en-route to me. It is QMK and VIA compatible which should be the de-facto-standard for boards moving forward.
This design also utilizes a daughterboard to enable an excellent looking center-location port.
Plates will be available in Aluminum and Brass.
This board is a beastly beauty weighing in at about 7.5lbs for an all alu version and a whopping 9.4lbs for the Limited Edition versions.
Summary
  • WKL 65% (also available as WK)
  • 7.7o angle
  • Rotary Encoder Knob
  • Interchangeable Insert Pieces
  • O-Ring Burger Mount
  • QMK/VIA compatible
  • 17.5mm Front Lip Height
  • 2mm custom internal liner for sound dampening
  • Roughly 7.5lbs for standard version and 9.4lbs for Limited Edition
  • USB-C Daughterboard
Layout
Renders
Additional Color Renders can be found here...
https://imgur.com/a/p6iJDir
Limited Edition
We will be offering 2 Limited Edition models.
White with a Brass Insert and Black with a Brass Insert
FAQ
  • Any ISO?
    Sorry not at this time. After receiving lots of great feedback, I've decided to modify the PCB to support ISO and will make the plate file public to allow anyone to get their own ISO plate cut.
  • Can I get a custom color?
  • How much is it going to be?
    I'm in talks with a couple manufacturers at the moment but it looks like it'll be somewhere around $500 usd for standard and obviously some more for the Limited Editions.
  • How many units will you be selling?
    I'm planning to do somewhere around 100 but we'll see based on interest.
  • How many Limited Edition units will you be selling?
    Its dependent on the number of responses. Then I'll set the numbers.
  • WKL only?
    Yes at this time there is only 1 layout. We'll see in future iterations. Well that didn't take long haha. Looks like a lot of you really want a WK option so I've decided to make the modifications to allow for WK. Enjoy
  • How long until delivery?
    This is still an initial IC so I won't commit to a firm timeframe but I would ballpark about 8 weeks based on conversations I've had with my manufacturers.
  • Is there a prototype?
    PCB's are on their way to me currently, and once I finalize with the manu, the case components should only be about 10 days.
  • Is it Hotswap?
  • Will I be able to purchase extra pcb's and plates?
    Yes.
Big shout-out to Ramon Imbao for the PCB work and to Foggy over on discord for some tips and tricks.
I really hope you enjoy the design! I look forward to answering any questions you may have.
« Last Edit: Fri, 02 October 2020, 14:29:40 by DoCallMeKing »
Re: [IC] Monarch (WKL 65 w/ arrow cluster, knob, interchangeable inserts)
« Reply #1 on: Tue, 29 September 2020, 22:01:42 »
Reserved for updates
10/2/20 :
  • Updated to allow for WK insert in addition to WKL
  • Updated the PCB design to support ISO. Will make the plate file public for users to cut their own plate.
10/18/20 :
  • A manufacturer has been selected and the prototype has been ordered.
  • Prices seem to be falling in line with my expectations but I will post final amounts once I receive the prototype and confirm the quality/options.
10/25/20 :
  • Prototype images from the manufacturer while it's being cnc'd
10/27/20 :
  • PCB prototypes have arrived and I will begin testing their functionality over the next day or so. It's QMK as well as VIA compatible. (These were ordered before the modification to allow for WK/ISO. Production ones will have the WK/ISO compatibility)
  • Things are progressing nicely at this point. I will update once I have some new info.
10/28/20 :
11/17/20 :
  • PROTOTYPES HAVE ARRIVED!!
  • Overall the fit was very good. The clearance between the insert and the top case is excellent!
  • I've made a couple very minor modifications to allow for easier insertion/removal of the daughterboard cable.
  • I've ordered another prototype to test a variation of the etching on the weight and to get a color sample of the gray. The next prototype will also be WK so you can see how that looks as well.
  • VIA is working perfectly on the PCB as is the encoder.
  • PCB modifications have been made to allow for ISO and WK.
« Last Edit: Tue, 17 November 2020, 19:46:10 by DoCallMeKing »
Offline Deadlcck
« Reply #2 on: Tue, 29 September 2020, 22:05:12 »
I love the interchange inserts idea. Looks awesome. GLWIC
Offline yoniwolf1202
« Reply #3 on: Tue, 29 September 2020, 22:06:13 »
I like it! GLWIC
Offline Blastoise
« Reply #4 on: Tue, 29 September 2020, 22:06:47 »
Love it. Hope that this one makes it through to production!
Offline dandruff
« Reply #5 on: Tue, 29 September 2020, 22:08:43 »
Love the concept! Looking forward to hearing/seeing the prototype!
Offline KaosJ
« Reply #6 on: Wed, 30 September 2020, 07:34:42 »
Definetely want this, but please standard winkey option as well.
With WKL unfortunatly i have to skip for sure this keyboard, while with a Winkey option it's a sure buy because it has everything i need.
As a suggestion, i would like to see the brass insert (top) in a black/gray color as well (e.g black pvd, black pvd opaque, etc..)
« Last Edit: Wed, 30 September 2020, 07:38:49 by KaosJ »
« Reply #7 on: Wed, 30 September 2020, 10:58:00 »
Thanks mate! Much appreciated.
I like it! GLWIC
Thank you! So far so good.
Thank you for the support. I'm excited about it.
Thanks my friend. Not as much as I am :)
Sorry to disappoint but I won't be offering winkey at this time. I apologize but since I'll already be offering numerous colors for multiple parts, I needed to keep the options as minimal as possible otherwise it spreads everything too thin for manufacturing and costs rise dramatically.
I'll do you a solid though and if I receive enough feedback about wanting WK, I'll consider adding it. :)
Offline Kokaloo
  • 🤘(• ω •)🤙
« Reply #8 on: Wed, 30 September 2020, 11:15:30 »
Offline Jars
« Reply #9 on: Wed, 30 September 2020, 11:28:27 »
FIRE!
Offline 112227
« Reply #10 on: Wed, 30 September 2020, 15:53:54 »
I'm in.
This looks perfect.
Offline BaconAndRibs
« Reply #11 on: Wed, 30 September 2020, 19:09:54 »
Definitely interested!
Offline walletburner
  • Formerly wokechill
« Reply #12 on: Wed, 30 September 2020, 20:27:02 »
very interesting
Offline EnjoyMyInSec
  • 60% or bust
« Reply #13 on: Wed, 30 September 2020, 20:28:56 »
Look pretty good my friend, GLWGB :)
Offline Clay333
« Reply #14 on: Thu, 01 October 2020, 19:13:08 »
Very nice! I do think that with this type of design it would be important to support it after the initial release though. Maybe you could set up a scheduled group buy for the board owners to purchase the interchangeable bits every 3-6 months for a year or so after initial release. Personally I don't usually have a solid plan for what caps are going on a board when it's first purchased and with so many new things coming out it would be hard to decide what colors to buy initially. I'm sure that the inserts won't be cheap like a badge would be so it would be very hard to justify purchasing them as extras without a solid plan on what you were going to pair them with.
Either way it looks like a great design and is actually something unique without being tacky. Good luck with the group buy.
« Reply #15 on: Fri, 02 October 2020, 07:06:52 »
Hey mate, that's a great idea about having a mini-GB periodically for buyers to purchase new colored inserts. I will 100% be able to provide this capability so no worries. I appreciate the comments and thoughts. Have a good one!
FIRE!
Thanks mate!
Thanks brother. Much appreciated.
Excellent. You won't be disappointed.
very interesting
Hopefully in a good way. Haha.
I'm in.
This looks perfect.
Awesome mate. Glad to have you!
« Reply #16 on: Fri, 02 October 2020, 07:08:50 »
Lots of people have requested WK option as well so your wish has been granted and I'll be offering a WK insert as well!
Offline Techichi
« Reply #17 on: Fri, 02 October 2020, 09:05:20 »
Thick little fella. GLWIC.
« Reply #18 on: Fri, 02 October 2020, 09:56:42 »
Thanks mate. I might need a stronger desk for it :)
Offline 3yatt
« Reply #19 on: Fri, 02 October 2020, 21:42:44 »
This is insane and really creative. I am so in. Pls FCFS not raffle.
Offline menuhin
« Reply #20 on: Sat, 03 October 2020, 06:39:16 »
I believe the construction can fit as well on the bottom row:
1.25u + 1.25u + 1.25u + 6.25u + 1.25u + 1.25u
Would love to have those function keys on the right side of the spacebar.
Would love to know more about the o-ring burger mount.
GL for the nice design!
IBM M13 black
NeXT non-ADB keyboard (AAE)
HHKB Pro 2 HasuBT
Offline duynguyenle
  • Personal text? What personal text???
« Reply #21 on: Mon, 05 October 2020, 14:47:33 »
My heart skipped a beat when I read the thread title and thought the original Monarch Alps keyboard was coming back for a second round: https://geekhack.org/index.php?topic=75786.0
Alas, no such luck. Some decent design ideas here though. GLWIC!
| QFR            | Leeku 1800    | Raptor K1      | Dolch Pac
Offline treeleaf64
    • treeleaf64
« Reply #22 on: Mon, 05 October 2020, 15:51:27 »
Reminds me of keycult side but good job anyway. I'm really liking it. And the knob is nice
Everyone must pay the cat tax
Offline olsen34
« Reply #23 on: Mon, 19 October 2020, 08:01:11 »
Interchangeable insert is revolutionary, consider me interested. Would insta-buy if there is teal colored one.
Btw that 8 weeks of estimated production time... Highly doubt these will be finished in just 2 months.
« Last Edit: Mon, 19 October 2020, 08:09:28 by olsen34 »
Offline rpiguy9907
« Reply #24 on: Mon, 19 October 2020, 18:29:35 »
I thought the same thing thought this was round 2 of the original Monarch!
Offline fluxlab
« Reply #25 on: Tue, 20 October 2020, 13:14:07 »
I’m curious how tight the tolerances would be between the bezel and insert
Offline kohalified
« Reply #26 on: Tue, 20 October 2020, 18:37:13 »
This thing looks pretty good. Interested to see some renders with keycaps.
Offline Dunne
    • Dunne
« Reply #27 on: Thu, 29 October 2020, 12:39:54 »
This board has a bit of everything that I really like! Hope this works out & look forward to the progress/the journey  ^-^
« Reply #28 on: Thu, 12 November 2020, 11:26:45 »
Prototype should be arriving today!!
Offline Hellenic94
« Reply #29 on: Sun, 15 November 2020, 16:01:19 »
Nice! Things are developing very quickly!
Offline spamnyams
  • Potato
« Reply #30 on: Sun, 15 November 2020, 16:31:30 »
Yesssss, looking forward to more pics!
« Reply #31 on: Tue, 17 November 2020, 19:47:26 »
Yes they are. And so far so good :)
« Reply #32 on: Tue, 17 November 2020, 19:47:58 »
They're now live! Check em out and let me know what you think. :)
« Reply #33 on: Tue, 17 November 2020, 19:50:52 »
Thanks for the kind words.
Be sure to check out the prototypes and let me know your thoughts!
« Reply #34 on: Tue, 17 November 2020, 19:51:59 »
The tolerance is excellent. There will be no crumbs getting in between the pieces, don't worry :)
Check out the protos!
Thanks again!
Offline Demagine
« Reply #35 on: Tue, 17 November 2020, 20:08:00 »
Wow, I'm loving the prototype - looks super clean! Are you planning to include any unique knobs in the GB? Also, is there a Discord for this yet?
« Reply #36 on: Tue, 17 November 2020, 20:39:39 »
Thanks so much!
I inquired about custom knobs but unfortunately I wasn't satisfied with the results a couple suppliers were offering so I'll be going with Silver, Black, Gold, and a Carbon color.
No discord at this time. I don't have the time to manage it at the moment.
Once this goes live, I will turn my focus to that as it will be a great place for my upcoming designs as well.
Offline Demagine
« Reply #37 on: Tue, 17 November 2020, 21:02:27 »
Thanks so much!
Ah gotcha, sounds good! Nice to hear that there are a few knob colors to choose from. Do you have GB dates or formats in mind yet?
« Reply #38 on: Tue, 17 November 2020, 21:42:04 »
Thanks so much!
No official date as of yet. I'm hoping to have it in the works very shortly though.
Offline CarcWithanM
« Reply #39 on: Thu, 19 November 2020, 22:49:50 »
Bro this keyboard looks amazing.  Cant wait till the GB goes live
« Reply #40 on: Fri, 20 November 2020, 08:36:17 »
Thanks mate!
I'm doing my best to get it up and running ASAP.
Offline hyppialonso
« Reply #41 on: Fri, 20 November 2020, 09:28:05 »
Hope it is under 500 such that my poor wallet can afford it
Offline spicysol
« Reply #42 on: Sun, 22 November 2020, 20:47:35 »
absolute banger of a board; if i can get in on this, ill be sure to get the black board with the red, navy, and brass insert.
Offline UberPlatypus
« Reply #43 on: Mon, 23 November 2020, 07:45:47 »
She chunky
Sent from my HD1925 using Tapatalk
Offline donny_pete
« Reply #44 on: Mon, 23 November 2020, 11:49:22 »
I love the idea of separated arrow cluster with a 65% layout. I dig it
« Reply #45 on: Wed, 02 December 2020, 08:29:08 »
GB is going live on December 5th!!
Here is the link to GB page with all the information, please make all comments/questions there from now on.
https://geekhack.org/index.php?topic=109943
« Last Edit: Wed, 02 December 2020, 09:44:15 by DoCallMeKing »
