Author Topic: Silicon Graphics RT6856  (Read 4922 times)
Offline Parabellum
« on: Fri, 23 July 2010, 15:36:57 »
http://cgi.ebay.com/Silicon-Graphics-RT6856T-Keyboard-AQ6-CYPRESZ15-/320344890217?cmd=ViewItem&pt=PCA_Mice_Trackballs&hash=item4a960b1b69
These keyboards are rubber-domes, right?
I'm pretty sure only the AT101's are mechanical, but the heck do I know.
Offline washuai
    • http://home.earthlink.net/~haruai/
« Reply #1 on: Fri, 23 July 2010, 15:45:32 »
I'm not sure about that SKU model number, but there are Silicon Graphic ALPS boards out there.
⌨(home)Realforce 87U ⌨(backup) Filco Majestouch 104 Brown ⌨(backup)Cherry G80-8200LPDUS ⌨(work)Leopold FC200RT/AB
☛CST L-Trac-X ☛Logitech Wireless Optical Trackman ☛ Razer 3500 dpi ☛MS Explorer DeathAdder
Lay-a-bouts:  ⌨Full 109 Key Virtually Indestructable  Keyboard ⌨Compaq Radio Quack GYUR84SK
Wishlist: ⌨KBDmania Pure ⌨Déck 82 ice/frost/toxic/royal ⌨Ricercar spos G86-62410EUAGSA ☠ ✞⌨miniGuru(s) ☠
 ✐Intuos or Cintiq
« Reply #2 on: Fri, 23 July 2010, 16:08:30 »
Yes, that one is a rubber dome keyboard, manufactured by NMB.
You had posted a picture of a KeyTronic in a Swedish layout earlier. I have got one of these in Swedish layout, if you are interested ...
It has got a key travel of 3.5 mm. Low resistance, but distinct when you bottom out.
Curved steel back plane with all keys the same size.
However, the keys rattle, and this rattling is quite loud even though the keys are otherwise quite stable. The front edge of the space bar also gets in the way a bit.
« Last Edit: Fri, 23 July 2010, 16:30:25 by Findecanor »
Offline Parabellum
« Reply #3 on: Fri, 23 July 2010, 16:24:07 »
No thanks, I'm looking for a mechanical right now.
« Last Edit: Fri, 23 July 2010, 17:58:44 by Parabellum »
Offline ch_123
« Reply #4 on: Fri, 23 July 2010, 17:54:30 »
Quote from: Parabellum;205662
There are also non-PS/2 SGI Alps keyboards out there.
The catch? They use the same connector as the PS/2, but if you mix them up, bad things happen.
Offline D-EJ915
« Reply #5 on: Fri, 23 July 2010, 18:50:51 »
Quote from: ch_123;205716
Those are pretty easy to spot though. what it looks like (well if you have a decent picture of it lol)
Annoying thing is there was a regular PS/2 one which was also beige here
Offline ch_123
« Reply #6 on: Fri, 23 July 2010, 18:52:48 »
I think there was a granite version of those too?
Either way, you can tell them apart because the Indigo one has a flat surface, whereas the later AT-101 one is curved.
Can always check part number though...
