Author Topic: Looking for a new Mac specific keyboard  (Read 2898 times)
Offline kelchm
« on: Mon, 26 July 2010, 00:27:32 »
Hey guys.  I'm in search of a new keyboard to replace a failing apple aluminum keyboard.  I actually kind of like the aluminum keyboard, though its feel / durability leave a lot to be desired.
My ideal keyboard would be similar in layout to the aluminum keyboard, be backlit and be tactile without being overly noisy.  Anyone know of anything that might meet those qualifications?
Offline hyperlinked
« Reply #1 on: Mon, 26 July 2010, 00:50:31 »
Which aluminum are you talking about? There's more than one.
Topre: Realforce 103U Cherry: Filco Majestouch 104 (Brown), Ione Scorpius M10 (Blue)
Buckling Spring: IBM Model M1391401 ALPS: Apple Extended Keyboard II (Cream), ABS M1 (Fukka/Black), MicroConnectors Flavored USB (Black)
Domes: Matias Optimizer, Kensington ComfortType, Microsoft Internet Keyboard
Scissors: Apple Full Sized Aluminum
Pointy Stuff: Razer Imperator, Razer Copperhead, DT225 Trackball, Apple Magic Mouse, Logitech MX1000, Apple Mighty Mouse
Systems: MacPro, MacBook Pro, ASUS eeePC netbook, Dell D600 laptop, a small cluster of Linux Web servers
Displays: Apple Cinema Display 30", Apple Cinema Display 23"
Ergo Devices: Zody Chair, Nightingale CXO, Somaform, Theraball, 3M AKT180LE Keyboard Tray
Offline Brodie337
« Reply #2 on: Mon, 26 July 2010, 03:24:47 »
The only backlit mechanicals that are readily available are deck:
http://www.deckkeyboards.com/
Offline Pylon
« Reply #3 on: Mon, 26 July 2010, 09:54:16 »
Tactile Pro? No backlit though.
Offline ch_123
« Reply #4 on: Mon, 26 July 2010, 10:38:02 »
Depends on what sort of Apple layout the OP is trying to emulate. Fullsize? Just about any keyboard. Compact layout? Compromises will have to be made.
Offline itlnstln
« Reply #5 on: Mon, 26 July 2010, 10:39:15 »
DSI has some Mac-specific stuff; nothing backlit, though.
Offline kelchm
« Reply #6 on: Tue, 27 July 2010, 22:09:20 »
Quote from: hyperlinked;206483
Quote from: ch_123;206597
Quote from: Brodie337;206497
I know I've heard some bad things about Deck in the past.  Anyone have any input about them?
Quote from: Pylon;206585
Quote from: itlnstln;206598
Thanks for the suggestions.
Offline hyperlinked
« Reply #7 on: Wed, 28 July 2010, 02:17:26 »
This doesn't have backlighting, but it might be close to what you're looking for if you're not looking to stray too far from the aluminiums:
http://www.amazon.com/Macally-BTKey-Wireless-Bluetooth-Keyboard/dp/B000A0C6OS
My wife has an old MacAlly that appears to be some kind of rubber domes with sliders. It's too stiff for me, but it's worn well. I've played with some of their keyboards at electronics stores before and find them generally favorable though they don't top my list. That's where the Apple Aluminums sit with me too though. They're generally favorable once you get used to them, but they're not my first pick if I have a choice.
« Last Edit: Wed, 28 July 2010, 02:21:27 by hyperlinked »
Offline hyperlinked
« Reply #8 on: Wed, 28 July 2010, 02:52:07 »
Someone else just posted this keyboard in another thread. It's not low profile, but it's a similar layout and  has backlighting:
http://www.xarmor-usa.com/index.php?dispatch=products.view&product_id=1
There is one thing I like better about the keyboards that are billed as actual Mac keyboards and it's the layout of the keypad. I'm not a fan of the "+" key being a double height key. The + key isn't that hard to find and having the * key in the corner makes it really easy to hit.
