Author Topic: Cherry low profile RED switch  (Read 8012 times)
Offline KPrepublic
  • * Moderator
    • KPrepublic
« on: Wed, 21 October 2020, 02:32:56 »
Key benefits
• Engineered and Made in Germany
• CHERRY MX Low Profile RGB Red switch: Without  pressure point, linear light actuation switching function  with a defined force of approx. 45 cN without contact  feedback
• Designed for use with SMD LEDs  (RGB or single colour)
• More consistent lighting throughout the keycap due to  optimized switch design
• Option to use all 16.8 million RGB colours in high  luminosity (scope of supply does not include LED)
• SMD LEDs directly mounted on the circuit board for  cost-efficient, fully automated production
• High-precision mechanical switch with very low  operating point tolerance
• World exclusive CHERRY Gold Crosspoint technology
• Short bounce time for high switching frequency  (such as for fast typing)
• Self-cleaning contacts
• Switch resistant to dust and dirt
• Over 50 million keystrokes with no loss of quality
Technical Data
Protection class: IP40
Operation characteristics: Low Profile, linear
Switching voltage: 12V AC/DC max.
Dielectric strength: 500V / 50Hz
Durability: > 50 million actuations
Contact configuration: Single-pole contact
Actuator travel: 3.2 ± 0.25 mm
Pretravel: 1.2 ± 0.3 mm
Initial force: 40 cN min.
Actuation force: 45 ± 15 cN
Bounce time: typically 1 ms
Minimum lead spacing: 16 mm
Lighting: SMD LED, mounted directly  on the circuit board
Insulation materials: Thermoplastics
Spring: Stainless steel
Contacts: High-quality gold alloy
Storage Temperature: -40°C to 70°C
Operating Temperature: 5°C to 40°C
Humidity: Storage: average <50% max.​ 3 months / 75% max.15 days,operation: 5% to 95% without condensation
Offline KPrepublic
  • * Moderator
    • KPrepublic
Re: Cherry low profile RED switch
« Reply #1 on: Wed, 21 October 2020, 02:33:44 »
