Author Topic: [IC] GMK YEETI(Final version)  (Read 78504 times)
Offline Fannie_w
« on: Sat, 24 October 2020, 02:53:01 »
UPDATE
2.4 Update the final version.
The GB is coming soon.
Hope u can enjoying it!
VENDORS
NA: Kono.store
CA: DeskHero
SEA: iLumkb
AU: DailyClack
CN: zFrontier
UK:prototypist
Hi,everyone!I'm Fannie.
This time I brought a keycap design about YETI.
I especially like winter.
 The city I live in is very hot all the year round and there is no snow.
So I like blue.
It is not only the color of ice and snow, but also the color of sea and sky.
Yeti is a fluffy little cute in my heart
Although the body is huge, but has a gentle hear.
I hope that this only exists in the ice and snow spirit can stay on my keycap to accompany my daily life.
So I designed this set of keycaps.
COLORS
PLANING KITS
Base Kit
Icon kit
Novelties Kit
Spacebar Kit
40% Kit
Deskmat
Yeeti x Rama
Renders
GMK YEETI+UNI 660
GMK YEETI+SPACE 65 CYBERVOYAGER
GMK YEETI+BLANK60
PACKAGE DESIGN
Collaborations
GMK YEETI+Nerdcables
GoldenStar Keycaps
Meofcaps
Deagcaps
Blank.works
Hello_caps
tinymakethings
Contact Me
INSTAGRAM
DISCORD
« Last Edit: Fri, 19 February 2021, 23:16:01 by Fannie_w »
Offline dandruff
Re: [IC] GMK YEETI
« Reply #1 on: Sat, 24 October 2020, 02:54:52 »
I don't see anything. Is there supposed to be pictures?
Offline Xonuss
Re: [IC] GMK YEETI
« Reply #2 on: Sat, 24 October 2020, 02:56:27 »
Pictures seem broken
Offline YouGotRioted
Re: [IC] GMK YEETI
« Reply #3 on: Sat, 24 October 2020, 02:58:14 »
I see what you did there.
Offline Ustinj
Re: [IC] GMK YEETI
« Reply #4 on: Sat, 24 October 2020, 02:59:07 »
this is epic... because no man has ever seen a yeti, this is as accurate as it gets
Offline L8T
Re: [IC] GMK YEETI
« Reply #5 on: Sat, 24 October 2020, 03:04:44 »
Quality ****post right here.
Offline Fannie_w
Re: [IC] GMK YEETI
« Reply #6 on: Sat, 24 October 2020, 03:10:36 »
This my first time to post....so maybe something wrong with the links :'(
It seems can see now
Offline Ireojimayo
  • Yo dayo
Re: [IC] GMK YEETI
« Reply #7 on: Sat, 24 October 2020, 03:11:44 »
Looks Very cute, I like the way the gradient returns to white, sadly this cant be seen on anything without a numpad, but thats not too big of an issue
The rows in your novelties are confusing though, is it possible to label, profiling for them?
Offline ditheus
Re: [IC] GMK YEETI
« Reply #8 on: Sat, 24 October 2020, 03:25:37 »
its cute!! please take my money :))
Offline SWEE-3PO
Re: [IC] GMK YEETI
« Reply #9 on: Sat, 24 October 2020, 03:49:31 »
Looks great!
Offline FaKe_VirTual
    • Virtual Designworks
Re: [IC] GMK YEETI
« Reply #10 on: Sat, 24 October 2020, 04:11:14 »
I would suggest you looking at GMK's guidelines for the Novelties. The Yeti-faces seem to have some really tiny details which may not be reproducible by GMK.
Guideline
Offline Rebral
Re: [IC] GMK YEETI
« Reply #11 on: Sat, 24 October 2020, 04:13:06 »
These look adorable. GLWIC!
Offline Janoma
  • certified nerd
Re: [IC] GMK YEETI
« Reply #12 on: Sat, 24 October 2020, 05:23:26 »
Extra B please
Offline miaiji
Re: [IC] GMK YEETI
« Reply #13 on: Sat, 24 October 2020, 06:22:30 »
花姐牛逼
Offline sartori24
  • hello
Re: [IC] GMK YEETI
« Reply #14 on: Sat, 24 October 2020, 06:27:46 »
So I like blue.
COLORS
PLANING KITS
Base Kit
Novelties Kit
Spacebars Kit
I don't know what kind of kits you need more.
I'll upload a Google forms for you to choose later ;D
Renders
More renders are coming soon!
Because I do the rendering by myself.
So maybe the update speed will be a little slow
Please wait for a moment.
Thank u so much!!!!! ^-^
can i render this pls
yikes
Offline fanovorc
Re: [IC] GMK YEETI
« Reply #15 on: Sat, 24 October 2020, 09:10:40 »
nice color!
Offline rohitsc
Re: [IC] GMK YEETI
« Reply #16 on: Sat, 24 October 2020, 10:14:13 »
Love the colors but I’m not too crazy about the gradient
Offline henryzhou123
Re: [IC] GMK YEETI
« Reply #17 on: Sat, 24 October 2020, 21:02:21 »
WOW! Love the Novelties!
Offline fabijolo
  • I like expensive plastic.
Re: [IC] GMK YEETI
« Reply #18 on: Sun, 25 October 2020, 01:01:20 »
I'd recommend you to have both system keys with either "code" or "super" and not, as it is right now; with the 1u being "super" and 1.25u being "code".
Also, as op already pointed out, I'd look over the novelties/GMKs Guidelines again, just to make sure that they will actually be able to manufacture them :thumb:
Offline Fannie_w
Re: [IC] GMK YEETI
« Reply #19 on: Sun, 25 October 2020, 04:40:09 »
Thank you for your suggestion. I will check the setting of keys, and I will make the novelties according to GMK guidelines next renders. Thank you for enjoying it!
Offline Fannie_w
Re: [IC] GMK YEETI
« Reply #20 on: Sun, 25 October 2020, 04:44:29 »
Guideline
Thanks for your suggestion.I'll modify these details in the next renderings ;D
Offline Fannie_w
Re: [IC] GMK YEETI
« Reply #21 on: Sun, 25 October 2020, 04:45:29 »
Offline Fannie_w
Re: [IC] GMK YEETI
« Reply #22 on: Sun, 25 October 2020, 09:01:35 »
I will take a tag in next rending,thans for your suggestion :D
Offline Fannie_w
Re: [IC] GMK YEETI
« Reply #23 on: Sun, 25 October 2020, 09:03:58 »
Extra B please
Yep!!!!I will add the extra B in next rending :cool:
Offline Fannie_w
Re: [IC] GMK YEETI
« Reply #24 on: Sun, 25 October 2020, 09:05:26 »
I imagine the Yeti has a huge body but a pure heart :)
Offline Fannie_w
Re: [IC] GMK YEETI
« Reply #25 on: Sun, 25 October 2020, 09:07:18 »
Thanks for love it!But the bad news is the novelties will change some.
Becoz some lines of Yeti are too thin to make  :(
Offline Fannie_w
Re: [IC] GMK YEETI
« Reply #26 on: Sun, 25 October 2020, 09:32:32 »
Thanks for u love it.
I want to take your money too XDDD
Offline andromache
Re: [IC] GMK YEETI
« Reply #27 on: Sun, 25 October 2020, 10:32:51 »
This is an insta-cop for me. I love the novelties and the gradient.
Offline qwe59qwe59
Re: [IC] GMK YEETI
« Reply #28 on: Sun, 25 October 2020, 15:27:33 »
love this color, can't wait for the GB :)
Offline polarhanakan
Re: [IC] GMK YEETI
« Reply #29 on: Sun, 25 October 2020, 16:52:07 »
Love the colors!!!! Will definitely join the GB!
Offline GaNeBaL
Re: [IC] GMK YEETI
« Reply #30 on: Mon, 26 October 2020, 02:27:34 »
ne 2nd b avail
Obsessed with 60%TKLs
Offline Fannie_w
Re: [IC] GMK YEETI(11.15 update)
« Reply #31 on: Sun, 15 November 2020, 09:46:05 »
11.15 update
Offline treeleaf64
    • treeleaf64
« Reply #32 on: Sun, 15 November 2020, 14:47:49 »
Need better kitting for the poor souls who have to use numpad
Everyone must pay the cat tax
Offline Fannie_w
« Reply #33 on: Sun, 15 November 2020, 19:27:30 »
Yes yes,I update a pad kit :))
Offline treeleaf64
    • treeleaf64
« Reply #34 on: Tue, 17 November 2020, 14:45:07 »
I mean in the base kit. This is an example of good kitting
https://geekhack.org/index.php?topic=108890.0
Offline Space_Case88
  • keebs, anime, video games and coffee
« Reply #35 on: Tue, 17 November 2020, 14:47:32 »
That Space65 render looks great :) I'm in.
Offline Twigler
« Reply #36 on: Tue, 17 November 2020, 16:40:41 »
Is there a chance for the gradient effect to be elongated? There is too much blue on the right side!
Offline Afresh
« Reply #37 on: Tue, 17 November 2020, 18:23:51 »
Interested
« Last Edit: Tue, 17 November 2020, 18:25:31 by Afresh »
Offline bowljob
« Reply #38 on: Wed, 18 November 2020, 00:06:04 »
Big Interest
Love the colors  :thumb:
Offline bt2108
« Reply #39 on: Wed, 18 November 2020, 02:33:41 »
I would like to see more RAL 210 90 10 and jap sub legend as well?
Offline Marcus_Neistat
  • KeK
« Reply #40 on: Wed, 18 November 2020, 07:24:40 »
TAKE MY WALLET AND KEEP THE CHANGE
Offline UberPlatypus
« Reply #41 on: Wed, 18 November 2020, 22:32:24 »
Adore the gradient!
Sent from my HD1925 using Tapatalk
Offline Inphinity
« Reply #42 on: Thu, 19 November 2020, 14:02:54 »
LOVE this! Please DO NOT ruin this for me by adding any Hiragana to the legends or any other alphabet.
Offline ditheus
« Reply #43 on: Fri, 20 November 2020, 22:02:07 »
I would like to know the gb date:)
Offline Digmo
    • keebit.studio
« Reply #44 on: Sat, 21 November 2020, 07:05:14 »
Yes Please!
Offline AdeelDante
« Reply #45 on: Sun, 22 November 2020, 04:22:53 »
Wow this keycap set would be amazing on Southpaw. Can we get a render of that please with the numpad.  :thumb:
Edit: just seen this set on Aliexpress for sale quite cheap.
Are you aware of this? Seems to be the exact same design as yours.
« Last Edit: Sat, 05 December 2020, 19:22:27 by AdeelDante »
Offline neutralstate
« Reply #46 on: Sun, 22 November 2020, 07:50:02 »
since most of us would likely only be able to get an ewhite board to match with this (not that many baby blue boards to go about!), would be great if there was a render on one!
Offline oldcat
  • 65% is Life
« Reply #47 on: Sun, 06 December 2020, 20:49:14 »
Love this colorway!
Offline iinko_mk
  • Status: broke
« Reply #48 on: Sun, 06 December 2020, 22:43:38 »
That gradient looks soo cool!
Offline Ram
« Reply #49 on: Mon, 07 December 2020, 00:15:44 »
Really nice Gradient, I love it!
