Author Topic: [GB] Melody65 - extra units in stock 29/12 - 9 PM EST  (Read 77405 times)
Offline Liub
Re: [GB] Melody65 - Shipping started for part of the batch
« Reply #100 on: Tue, 27 July 2021, 11:53:34 »
[quote author=KaosJ
Damn that look bad, seems external from the photo or is it really inside the PC?
Anyway glad you sorted it out with KBDFans already, sorry that you might need to wait for replacement but we are still missing some PC bottom and E-white for GB user.
[/quote]
Both external surfaces are smooth to the touch so I guess it's internal. I'm not a material science guy so that's all I know.
KBDf offered me $5, $10 for this defect instead of replacement... no thanks.
Offline KaosJ
« Reply #101 on: Tue, 27 July 2021, 18:11:20 »
Weird issue, let me know if there is anything wrong with the replacement
Offline KaosJ
« Reply #102 on: Thu, 02 September 2021, 16:03:15 »
Here is mine!
Fulll album here with white and purple: https://imgur.com/a/70ceWcq
« Last Edit: Thu, 02 September 2021, 16:05:13 by KaosJ »
Offline karateyes
Re: [GB] Melody65 - GB Ended
« Reply #103 on: Fri, 15 October 2021, 15:22:32 »
anyone else received 3 sets of screws and spacers(?) in sealed plastic bags are for? did the factory just out of convenience throw it in there and didn't want to separate from the rest of the tools?
Offline KaosJ
« Reply #104 on: Mon, 18 October 2021, 19:07:30 »
The spacers/standoffs are in case of hotswap pcb, to make these people hotswap without opening the case (otherwise the pcb would fall)
Yes people with solder pcb got these tools as well, to avoid mistakes or to avoid that anyone with a HS melody65 could end up without these parts somehow :)
Offline ktrezzi
« Reply #105 on: Thu, 23 December 2021, 05:39:24 »
I'm a little bit late to the party...Is there any way to buy a set? :D Or is a R2 or something planned?
Offline KaosJ
« Reply #106 on: Wed, 29 December 2021, 11:51:56 »
You are pretty much lucky, no R2 planned sorry, but there will be 100 extras in stock, ready to ship, in about 8 hours.
Info here: https://www.reddit.com/r/mechmarket/comments/rrdlql/gb_melody65_extras_in_stock_in_about_8_hours_and/
