Author Topic: [IC] Rukia (Alice-style) Wrist Rest in PC and Aluminum  (Read 12667 times)
Offline cbbplanet
« on: Tue, 27 October 2020, 11:27:53 »
Hi everyone, been a long time keyboard enthusiast but a first time IC/GB runner so bear with me.
Introducing...
Rukia Wrist Rest
Rukia has been one of my favorite board for awhile and I decided to make my own wrist rest and share it with the community. I receive permission and the wrist rest file directly from Jaxx already so I'll let pictures do the talking!
Materials: PC / Aluminum
Price: Depending on QTY but PC looking at $70-80 and Alu $62-72 + shipping. This is my estimate for 20 units. Apologies for higher prices than most but I do use a slightly higher price manufacture just because ease of communication/previous transactions
Time: 2-5 weeks
Color: Grayish Light Turquoise (More gray hue than Pantone below)
Details on quality/fitment:
The fit will be perfectly aligned. However, in order for aluminum to anodize, there will need to be holes for it hook and hang. Therefore, there will be 2 drill holes on the back of the wrist rest where it oxidize and liquid will drip down; resulting in tiny bleed spot as pictured below. My solution to this will be putting bump-on that will be included in the purchase.
For alice-style (non Rukia) owners, this will also kind of work for your board but with a caveat.
Rukia is an alice-style board but with slightly different bottom contour. This wristrest will still fit your alice-style board but most likely will have a slight gap. Please refer to picture below for a rukia wrist rest on a Lubrigante
Please share your thoughts and GB should be launching in the coming week! Thank you!
« Last Edit: Tue, 27 October 2020, 11:37:48 by cbbplanet »
Offline Mr.Elli0t
Re: [IC] Rukia (Alice-style) Wrist Rest in PC and Aluminum
« Reply #1 on: Tue, 27 October 2020, 11:34:18 »
1st!
Sent from my Pixel 4 XL using Tapatalk
Offline A.Belousov
« Reply #2 on: Tue, 27 October 2020, 11:38:15 »
Pc wrist rest looks awesome man!
Offline wencan008
« Reply #3 on: Tue, 27 October 2020, 11:39:25 »
Let's go! Been waiting for this. Might even get both...
Offline Scottw
    • ScottW's Boards
« Reply #4 on: Tue, 27 October 2020, 12:11:30 »
Looking forward to this.
Offline KevlarBear
« Reply #5 on: Tue, 27 October 2020, 12:12:05 »
Definitely in for a PC wrist test  :thumb:
Offline sirieous
  • help
« Reply #6 on: Tue, 27 October 2020, 12:15:03 »
May be interested in a PC wrist rest! I love Rukia
Offline evorus5
« Reply #7 on: Tue, 27 October 2020, 12:43:01 »
Lets go Cbb!
Offline KingOfMemes
« Reply #8 on: Tue, 27 October 2020, 12:51:08 »
That green is so sexy. Count me in for that
Offline MilkTea_QAQ
« Reply #9 on: Tue, 27 October 2020, 12:55:05 »
Where can I buy the acrylic Alice board? Been always wanted to try acrylic board. Are there any open source pcb or case so I can laser cut it on my own?
Offline Diamagisk
« Reply #10 on: Tue, 27 October 2020, 14:04:35 »
In for PC 100%!
Offline remdell
« Reply #11 on: Tue, 27 October 2020, 14:14:00 »
Wow, both look great! The alu really defines the upper bevel cut beautifully.
Rukia PC | RF87U Digilog | Norbaforce MKII Palm Desert | Zenith ZKB-2R | Datadesk MAC-101
Offline ZyBeR
« Reply #12 on: Tue, 27 October 2020, 14:34:14 »
Interested in a PC wrist rest.
Offline ReDsNoTDeAd
    • RNDKBD
« Reply #13 on: Tue, 27 October 2020, 15:09:48 »
In for a PC one
Offline Sup
« Reply #14 on: Tue, 27 October 2020, 15:52:26 »
Sign me up. One alu please  :)
current
Coming soon
Offline wcmbk
« Reply #15 on: Tue, 27 October 2020, 16:30:25 »
In for a PC/alu one
Offline rsvnh
  • Sem van Nieuwenhuizen
« Reply #16 on: Tue, 27 October 2020, 17:14:55 »
In for a PC wrist rest!
Offline andrewregal
« Reply #17 on: Tue, 27 October 2020, 17:57:59 »
I'd be interested in one of each PC & Aluminum
Discord: andrewregal#7830
Offline airyimbin
« Reply #18 on: Tue, 27 October 2020, 19:02:29 »
Definitely in for a Aluminum one!
Offline NDL00Z
  • ID my_ids[2] = {PrimateRed#4718, u/RicemanRed}
« Reply #19 on: Tue, 27 October 2020, 19:48:14 »
I will simp both
Offline asury
  • /u/adsury/
« Reply #20 on: Tue, 27 October 2020, 20:08:15 »
So count me in for PC, or Alu 🤔  I haven't decided but definitely will take one.
I heard that there's a possibility for PC to wrap? is it true? since in that case, I might just go with Alu just to be safe.
Grey Duck Sidewinder/GMK Hyperfuse Origins/MX Black retooled | Sage M60-A/GMK Camping/Holy Sky | LFK68/DSA Granite Alps/SKCM Orange Alps
Offline Arithmetics
« Reply #21 on: Tue, 27 October 2020, 21:08:16 »
Def in for PC
Offline cbbplanet
« Reply #22 on: Tue, 27 October 2020, 21:38:53 »
Hi! Glad to see someone followed my proto journey on Rukia discord. Yes, the first PC wrist rest they made warped slightly so I had them redo it. Hence, the PC is more expensive because the extra time factory need to ensure it'll NOT warp. PC is more prone to warping (compare to aluminum) during the process but thank god manufacture found a way to make it flat.
Offline keyboardkrill
« Reply #23 on: Tue, 27 October 2020, 22:59:21 »
I'd be in for that PC. Does level of frosting on the wrist rest match that of the rukia?
Looks really close, if not spot on!
Offline dyrdevil
« Reply #24 on: Wed, 28 October 2020, 00:08:38 »
interested in pc!  it's a bit expensive, so I'd have to think twice, but I understand and appreciate your reasoning for it.
Offline MOON
« Reply #25 on: Wed, 28 October 2020, 01:38:57 »
I'm 100% in for the PC. I have an R1 Rukia that has been craving this.
Offline cbbplanet
« Reply #26 on: Wed, 28 October 2020, 08:35:37 »
Yep the frost color is very very similar. The difference is in how it was sanded. The texture of the Rukia is very smooth while the wrist rest is less so. closest comparison would be shined gmk caps vs brand new.
Offline jayiskuhl
« Reply #27 on: Wed, 28 October 2020, 11:04:26 »
Looks sick! In for the PC for sure!
Rukia (?) | gaff. 60 | Pandora | Praxis | Bauer 2
Offline Aznattack
« Reply #28 on: Wed, 28 October 2020, 11:23:53 »
In for PC  :D
Offline Bachoo
« Reply #29 on: Wed, 28 October 2020, 13:08:08 »
yes yes yes
Offline wavv
    • mattl.ink
« Reply #30 on: Wed, 28 October 2020, 20:28:37 »
Count me in for PC.  :cool:
Offline cuongcan2020
« Reply #31 on: Thu, 29 October 2020, 09:51:08 »
PC FTW  ;D
Offline MajorKoos
  • 1 life please. Extra large.
« Reply #32 on: Thu, 29 October 2020, 10:37:54 »
Count me in for PC  :thumb:
Offline cbbplanet
« Reply #33 on: Thu, 29 October 2020, 15:54:09 »
Thanks for all the support.
... and I just realized I have forgotten about shipping/logistics issue for all the non-US. This might be US only w/ USPS shipping (I believe shipping to Canada will be easily $20+)
Offline Rawcco
« Reply #34 on: Fri, 30 October 2020, 04:50:22 »
one pc for me please !
Offline Lillenne
« Reply #35 on: Fri, 30 October 2020, 06:14:06 »
Definitely in for a PC one!
Offline Diamagisk
« Reply #36 on: Fri, 30 October 2020, 15:21:54 »
Oh well that's unfortunate, guess I wont be able to buy since I'm in the UK not the US.
Offline cbbplanet
« Reply #37 on: Fri, 30 October 2020, 17:50:00 »
Apologies for that! However, I will be buying some extras and may open that up to international so please keep an eye out in the near future still. thank you for the interest nevertheless
Offline baoduy23
« Reply #38 on: Sun, 01 November 2020, 06:50:43 »
I'm in gogo
Offline rmendis
  • Artisan addict
« Reply #39 on: Tue, 03 November 2020, 02:47:33 »
In 4 PC
Offline cbbplanet
« Last Edit: Tue, 03 November 2020, 12:03:09 by cbbplanet »
