Author Topic: [IC] GMK STORM l Running from 12th January until 12th February  (Read 78207 times)
Offline cs
Re: [IC] GMK STORM l Update: Metal Novelties Added
« Reply #50 on: Fri, 11 December 2020, 13:05:10 »
This kit has a narrower color spectrum compare to KAT iron. R2 and R3 color matching will be the key here, getting the saturation and hue is really crucial, and the slightest mismatch, say in R3, will set you back to redo the color match for R2, and vice-versa. Is it possible to get a color match before GB?
If this is done properly, this is going to an amazing kit.
Offline whezil
« Reply #51 on: Tue, 12 January 2021, 02:42:16 »
This is a beautiful colorway. The novelties remind me of storm chaser, really neat.
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #52 on: Sun, 17 January 2021, 16:44:51 »
Are you planning to open a GB thread on Geekhack?
Offline IOVERCALLHISTIOCYTES
Re: [IC] GMK STORM l Running from 12th January until 12th February
« Reply #53 on: Thu, 28 January 2021, 17:31:31 »
Since you dont have a GB thread, you wanna post the current sales numbers here?
Offline dvorcol
« Reply #54 on: Fri, 29 January 2021, 17:34:56 »
GB page is open!
