Author Topic: IBM Model M2 (1395721) ?  (Read 1871 times)
Offline ensigh88
« on: Thu, 05 November 2020, 02:13:25 »
Hello everyone. Please rate the find.
Bought for "pennies" IBM Model M2.
The keyboard has rather strange symbols, I cannot determine what version it is and what kind of connector it had in the original. As I understand it, the previous owner replaced the original DIN connector.
Also, I cannot find any information on the number 1395721. What is this version and for which country it was intended. I would be grateful for any information.
Offline yui
Re: IBM Model M2 (1395721) ?
« Reply #1 on: Thu, 05 November 2020, 02:43:49 »
the M2 was the keyboard for the PS/1, it was for a cheaper version of the PS/2 and so is also a cheaper keyboard, but as far as i know it should use the same protocol and have a PS/2 connector (and the PS/2 came before the PS/1). one very common problem with those is bad capacitors on the control board.
as far as the layout go i do agree it is quite strange, especially if you are in the US, to me it looks European, but it does not like to be any standard national layout, although the M and i think M2 could be made to use any layout you liked just by switching keys around, so likely that is what happened here, especially with the french legends on a qwerty layout.
TL:DR to me this is a french or Canadian board with a custom layout and likely buckling springs
