Author Topic: das 3 double usb cable?  (Read 1614 times)
Offline typo
« on: Wed, 28 July 2010, 23:41:05 »
did metadot make a das 3 with two usb plugs at the computer side? box says dask3pro. did a das pro s somehow get into that box?
thanks
Offline Jack
« Reply #1 on: Thu, 29 July 2010, 01:49:51 »
The third iteration in 2008 was the first to be offered in both Ultimate (unlabeled) and Professional (labeled) versions. This USB-only keyboard also offered 6-key rollover capability (the maximum for a convential USB HID keyboard), an internal 2-port USB hub and came with a glossy surface. Both 104-key (ANSI) and 105-key layouts (ISO) were offered. [2] This version was not without its problems, however, as it became known that key transposition errors could occur at high typing speeds. [3] [4] In addition, interoperability issues related to the USB hub were noticed with some systems.
http://en.wikipedia.org/wiki/Das_Keyboard#History
It doesn't mention any change from 3 to S in terms of the cable, so I imagine it was a double cable.
