Author Topic: [IC] GMK Lazurite | GB Ends June 6, 2021  (Read 249914 times)
Offline zionsped
    • Simbusped
Re: [IC] GMK Lazurite | Added Renders with Novelties
« Reply #100 on: Tue, 01 December 2020, 02:15:20 »
Update 11/30/20
-added renders on Reasonable65 with Calcite kit and High Renaissance (GoBl) Novelties
-added renders on a TKL board: RAMA U80-A by RAMA Works with High Renaissance Novelties
Ultramarine with High Renaissance Novelties on RAMA U80-A (Brass ANSI Enter?)
Calcite with High Renaissance Novelties on RAMA U80-A
NOVELTIES!  :eek::eek::eek::eek::eek::eek::eek::eek::eek::eek::eek:
Offline RUN_GMSEE
« Reply #101 on: Tue, 01 December 2020, 02:29:24 »
PH GANG!!!! 🇵🇭
« Last Edit: Tue, 01 December 2020, 02:32:06 by RUN_GMSEE »
Offline jaekid
    • Instagram
« Reply #102 on: Tue, 01 December 2020, 02:51:13 »
Salamat brother!🙏🏼
PH GANG!!!! 🇵🇭
Maraming salamat sa suporta! ;D
Offline jaekid
    • Instagram
Re: [IC] GMK Lazurite (Update: Primecaps Artisans Collab)
« Reply #103 on: Tue, 01 December 2020, 11:33:04 »
Apologies for not being able to get back to your comments as I have been trying to multi-task while I work on this very special project  ;) Now, I have the time to at least reply to your concerns.
Can GMK actually to designs as complex, and with as many minute details as the renaissance novelties for this set? The dies are going to be an itch.. might cost more?
I won’t have the exact details unless there’s a final call between vendors and GMK. The only info I have right now is that GMK’s design team has confirmed that the novelties can be made, which also blew my mind! I tried to follow the tolerance guidelines and hoped for the best. I think I was just lucky enough. Hopefully, it won’t get too expensive tho.
Yes a BlOW/Calcite base kit please!
I am seriously considering this - split the base kit into two, an Ultramarine (White on Blue) and a full Calcite base kit, both with less keys, maybe split the numpad I guess? To cut the price point for each base kit
Great work, I am definitely in for this.
Thank you very much! ;D
I'd be curious about how the Gold on Blue novelties look on more boards
I’m working on renders of Lazurite on Mekanisk’s Tind, Melody65, and hopefully one of Geon’s boards
Yes a blue-on-white ("BloW") base kit plus the BloW high renaissance accent kit, for the "classic porcelain" look would be my preference if I can get this set within my budget.
As stated above, I would most likely split the base kits. Hopefully this decision would be for the best, as answers on the IC form tends to go inline with this kind of kitting
I'd make all the base kits monochrome. I'd imagine most people will be using the novelties in place of opposite colored modifiers. (The ones with good taste anyway..)
Same with the one I’ve mentioned above. This hopefully goes well.
Any chance of a 40s kit and a short enter novelty?
I am seriously considering if I will still make a 40s kit as the demand looks to be too small as of the moment, hope you could help me know if there is enough interest with the 40s/ortho community
Would you be requesting a sample keycap in the final/matched blue from GMK?
I believe this is a standard process during color matching stage. If it is, I definitely will.
The blue on white keys have an interesting old fashioned porcelain look to them
I think so, but the whole idea is just Lazurite being a main component of Lapis Lazuli’s blue color commonly seen on calcite marbles hence the BloW colorway.
Offline kidpid
« Reply #104 on: Tue, 01 December 2020, 15:35:55 »
You could stop on by in the 40% Discord Server (discord.gg/40percent) and head to the #keyset-design channel to get an idea whether or not people would be interested in a 40s kit, and what that kit would look like. Personally, I am interested in this set, but without a 40s kit I would have to pass.
Offline Julia
Re: [IC] GMK Lazurite | More Renders, WIP: Final Kitting
« Reply #105 on: Tue, 01 December 2020, 16:10:41 »
plans for a gold and blue deskmat?
Offline onceforever
« Reply #106 on: Tue, 01 December 2020, 17:57:06 »
GB when???
Offline jaekid
    • Instagram
« Reply #107 on: Tue, 01 December 2020, 21:37:47 »
I will have to go over the IC form responses and see if I’d still offer a gold on blue version of the Ultramarine colorways
GB when???
No dates yet as I am still in negotiation with a US vendor
Thank you for this advice! Let me try to check on this. Would definitely be happy to see a 40s kit of the set as well.
« Last Edit: Sun, 13 December 2020, 04:55:11 by jaekid »
Offline yukitoki
« Reply #108 on: Tue, 01 December 2020, 22:32:59 »
Gold on BLue kit!!! :thumb:
Offline jaekid
    • Instagram
« Reply #109 on: Wed, 02 December 2020, 08:30:13 »
This has been a double-edged sword with my kitting. :'( As I want to offer this Gold on Blue kit as well, it all depends on the community’s feedback. Let me work on the kitting and take everything into consideration. :D
Offline Jaay
Re: [IC] GMK Lazurite | Kitting in Progress
« Reply #110 on: Thu, 03 December 2020, 21:20:25 »
Loving the set design!
Would there be any chance you offer a full BoW base instead of having the base and alpha sets, or this is set in stone?
« Last Edit: Thu, 03 December 2020, 21:22:24 by Jaay »
Offline jaekid
    • Instagram
« Reply #111 on: Fri, 04 December 2020, 08:30:48 »
Nothing’s set in stone I guess until I’ve talked to the vendors re the pricing of the kits. I would like to offer everything with the lowest price possible. Will take everything into consideration. 😊
Offline jaekid
    • Instagram
Re: [IC] GMK Lazurite | New Artisan Collab
« Reply #112 on: Sat, 05 December 2020, 11:58:49 »
Update 12/05/20
-added DEAGcaps as collaborator for artisan keycaps  :D
You can check deag’s works here.
Offline Curin Derwin
« Reply #113 on: Sat, 05 December 2020, 12:44:14 »
Update 12/05/20
Gosh I am so in for 2 or 3 sets.
Offline jaekid
    • Instagram
Re: [IC] GMK Lazurite | Local Artisan Collab!
« Reply #114 on: Sat, 05 December 2020, 21:29:10 »
Update 12/05/20
I'm proud to announce a collaboration with Buckeys!, a local artisan maker from PH. ;D
Check their works here.
Offline yukitoki
« Reply #115 on: Sat, 05 December 2020, 22:03:32 »
did someone say gold blue deskmat? O.O
Offline jaekid
    • Instagram
« Reply #116 on: Sun, 06 December 2020, 00:50:41 »
Might be offering this, let’s see the progress of the set and it would most probably be a blue base version of the Paint Frame Calcite
Wow! Thank you!
There I said it above. ;)
To everyone who has been very supportive for this set:
Really appreciate you checking back on this thread. More progress to come. Stay safe as always everyone!
Offline jaekid
    • Instagram
Re: [IC] GMK Lazurite | Updated Vendors List
« Reply #117 on: Sun, 06 December 2020, 11:40:31 »
Updates 12/06/20
Glad to announce that I have already confirmed a US vendor for Lazurite, Mechs & Co.; and confirmed Swag Keys as South Korea vendor.
Currently in talks with Fancy Customs to get them as proxy for South America. :D
Will now focus on designing the RAMA metal artisan keycaps and reviewing responses for possible kit revisions.
Offline RIFT
    • RiftKeys
« Reply #118 on: Sun, 06 December 2020, 16:27:37 »
My favorite set of 2020
Offline jaekid
    • Instagram
« Reply #119 on: Sun, 06 December 2020, 19:54:08 »
That is a huge compliment brother.  :eek: Thank you!
Offline Ram
« Reply #120 on: Mon, 07 December 2020, 00:13:12 »
Doesn't fit with my keebs but great design nonetheless
Offline jaekid
    • Instagram
« Reply #121 on: Mon, 07 December 2020, 05:23:46 »
Fair feedback there brother. Thank you! GL with your IC  :D
Offline jaekid
    • Instagram
Re: [IC] GMK Lazurite | MAJOR UPDATES
« Reply #122 on: Mon, 07 December 2020, 12:18:01 »
Hi everyone,
As I highly respect zambumon and his works as a designer, I did a major overhaul with my IC post for Lazurite. I will be doing more renders asap to showcase how the set and kit combinations will look like on a few more keyboards.
Updates 12/07/20
-tentative schedule for Lazurite's group buy is February 2021
-removed the special White on Blue Ultramarine kit choice to give respect to zambumon's Striker R2 run
-updated renders (removed renders with blue mods)
-renamed the Gold on Blue special base kit to Ultramarine x Gold
-added High Renaissance - BloG (Blue on Gold) novelties
-confirmed Chile/South America vendor: Fancy Customs
-added Keebsake (Philippines) as collaborator for artisan keycaps
« Last Edit: Tue, 08 December 2020, 12:54:38 by jaekid »
Offline konstantin
  • Formerly constexpr
« Reply #123 on: Mon, 07 December 2020, 12:44:42 »
Small note on the Ultramarine × Gold base kit: since this kit only uses two colors, the extra R1 1u `~ and R2 1.5u \| keys are redundant and can be removed.
Would you consider adding white on blue accent arrow keys to the Pyrite accent kit? This would complement both the Lazurite and Calcite colorways nicely. I believe you already have these arrow keys shown in some of your renders.
Alternatively, you could add them back to the Lazurite base kit, which is where I believe they were originally located. Since this kit uses two colors (one of which might be a stock GMK color, I'm not sure), I think you could squeeze these in without making the price of the kit too high. Either way, you can decide whether to keep them or not once you get your first quotes from GMK.
I recommend removing numpad 00 from all of the kits, as it's not a very commonly used key. It's practically only useful for standalone numpads; however, this set doesn't have all of the keys needed for standalone numpads in the first place, which is why I think it's okay to remove the 00 keys.
Finally, you should probably update the \¦ keys in the Calcite kit to use full pipe | legends, so that they match the legends in the rest of the kits.
« Last Edit: Mon, 07 December 2020, 14:50:01 by konstantin »
Offline yukitoki
« Reply #124 on: Mon, 07 December 2020, 12:48:15 »
Ty for the great news  :thumb:
Ultramarine X Gold!!
Offline jaekid
    • Instagram
« Reply #125 on: Mon, 07 December 2020, 14:51:34 »
Alternatively, you could add them back to the Lazurite base kit, which is where I believe they originally were. Since this kit uses two colors (one of which might be a stock GMK color, I'm not sure), I think you could squeeze these in without making the price of the kit too high.
Finally, you should probably update the \¦ keys in the Calcite kit to use full pipe | legends, so that they match the rest of the kits.
Thank you for the advices konstantin. Noted, will surely do the revision and work on more renders. Always a pleasure to see your comments on geekhack threads. Thank you!  :D
Offline ianmvs
« Reply #126 on: Tue, 08 December 2020, 12:36:10 »
I really like how the blue on gold set looks, very interested
Offline jaekid
    • Instagram
Re: [IC] GMK Lazurite | 1st Artisan Keycap Sample + MAJOR UPDATES
« Reply #127 on: Tue, 08 December 2020, 12:52:51 »
Update
12/08/20
-1st artisan keycap collab with Buckeys! (Philippines) sample revealed
Introducing... GMK Lazurite x Buckeys! Rogue Lazurite
Rogue Lazurite will be available during GMK Lazurite's group buy period
Offline Silk
« Reply #128 on: Tue, 08 December 2020, 16:20:56 »
Will you be getting/showing a prototype of the novelties? That will be great to see if possible given that this is a step change but also a huge step forward if they manage to capture all the intricacies. Definite cop for novelties if it turns out well.
Offline jaekid
    • Instagram
« Reply #129 on: Tue, 08 December 2020, 21:21:16 »
Hopefully I can request for atleast 1 sample of any of the ornamental novelties
Glad you liked it! :D
Thanks yukitoki! Lazurite x Pyrite ftw
Offline Havattack
« Reply #130 on: Tue, 08 December 2020, 23:40:27 »
Pretty indifferent to the 1st artist keycaps.. just kind of ...meh... Sorry. Looks to be high quality though, just an uninteresting design.
Offline jaekid
    • Instagram
Re: [IC] GMK Lazurite | 3 Artisan Keycaps Revealed + MAJOR UPDATES
« Reply #131 on: Wed, 09 December 2020, 07:02:19 »
Updates:
12/09/20
-all 3 artisan keycaps in collaboration with Buckeys! (Philippines) revealed
Offline jaekid
    • Instagram
« Reply #132 on: Wed, 09 December 2020, 07:03:28 »
That's okay brother. There are still other artisan keycaps that might excite you. :D
Offline Havattack
« Reply #133 on: Wed, 09 December 2020, 20:12:46 »
Those demon/oni ones are dope!
Offline Bobatype
  • formerly bobasweatandtears
    • discord: bobatype
« Reply #134 on: Thu, 10 December 2020, 01:36:04 »
I agree. Sure they might not appeal to everyone (artisans are very subjective), but they look likel good quality from those photos and it's always great to bring a local less known artisan maker to the forefront of the global community via a keycap set collab.
Offline jaekid
    • Instagram
« Reply #135 on: Thu, 10 December 2020, 04:56:19 »
Spot on! I picked a number of collaborations that I think would highlight the craftsmanship of artisans from the Asian community. Overall, I’m really amazed with the amount of dedication this community’s artisan makers commit to each of their masterpiece.
Offline jaekid
    • Instagram
Re: [IC] GMK Lazurite | Desk Mat Sample Photos & Tentative GB Schedule
« Reply #136 on: Thu, 10 December 2020, 08:37:14 »
Updates 12/10/20
-3 desk mats actual sample photos shown (colors will still be matched and stitching for review)
-Renaissance Ornament Calcite sample photos to follow
  • Paint Frame Ultramarine
  • Paint Frame Calcite
  • Renaissance Ornament Ultramarine
Specifications:
-900mm x 400mm
-microfiber top
-stitched edges
-rubber base
« Last Edit: Thu, 10 December 2020, 08:49:24 by jaekid »
Offline jaekid
    • Instagram
Re: [IC] GMK Lazurite | KEYFORGE Collab and Desk Mat Sample Photos
« Reply #137 on: Thu, 10 December 2020, 13:49:05 »
12/10/20
-confirmed collaboration with KEYFORGE (Salt Lake City, Utah) for artisan keycaps
Offline jaekid
    • Instagram
« Reply #138 on: Fri, 11 December 2020, 01:06:58 »
RAMA WORKS metal artisan designs soon. :D
Offline Julia
« Reply #139 on: Fri, 11 December 2020, 17:30:02 »
do you plan to make a blue and gold deskmat? the three you have now are more inclined to match with white and gold or blue and white.
Offline jaekid
    • Instagram
« Reply #140 on: Sat, 12 December 2020, 17:29:52 »
Let me consider this. :D If I design another desk mat I will have to ommit Renaissance Ornament Calcite (image below)
Offline jaekid
    • Instagram
Re: [IC] GMK Lazurite | RAMA Brass PVD Soon
« Reply #141 on: Sat, 12 December 2020, 17:32:08 »
Updates 12/12/20
-added a new signature banner
-confirmed collaboration with RAMA WORKS for metal artisan keycaps
Offline Grandfunk
    • zzz
« Reply #142 on: Sat, 12 December 2020, 18:06:50 »
In for at least the calcite frame mat. Whole sets looks amazing, love the theme.
Gl
Sent from my Pixel 3a using Tapatalk
Offline jaekid
    • Instagram
« Reply #143 on: Sat, 12 December 2020, 19:27:48 »
Gl
Thank you for that nice feedback! Have a great weekend and stay safe!
Offline Emasterbro
« Reply #144 on: Sun, 13 December 2020, 01:25:13 »
this set looks so sick!!! I would cop instantly! any chance for a matching custom cable?
« Last Edit: Sun, 13 December 2020, 01:31:09 by Emasterbro »
Offline jaekid
    • Instagram
« Reply #145 on: Sun, 13 December 2020, 05:00:35 »
Thank you for showing your support brother! Yes there is a matching custom cable by Switch Cables and I’m really excited to show it to everyone who’s been following Lazurite! ;D
Offline jaekid
    • Instagram
Re: [IC] GMK Lazurite | RAMA Brass PVD Soon | Krapshop Artisan Revealed
« Reply #146 on: Sun, 13 December 2020, 08:17:53 »
Updates 12/13/20
-artisan keycaps in collaboration with Krapshop (Malaysia) revealed
Krapshop x Lazurite Artisan Keycaps
collaboration keycaps available before Lazurite's Group Buy schedule (2021)
Lapis Lazuli Catto19
Calcite Catto19
Offline herfalerf
« Reply #147 on: Sun, 13 December 2020, 11:16:41 »
The gold on blue is looking super nice. Really sets this set apart IMO.
Offline jaekid
    • Instagram
Re: [IC] GMK Lazurite | Artisan Labs Wrist Rest Collab
« Reply #148 on: Sun, 13 December 2020, 15:33:52 »
Update 12/13/20
-added Artisan Labs (South Carolina, US) as collaborator for another artisan wrist rest
« Last Edit: Mon, 21 December 2020, 09:41:21 by jaekid »
Offline jaekid
    • Instagram
Re: [IC] GMK Lazurite | Resin Wrist Rest Teaser (WIP)
« Reply #149 on: Mon, 14 December 2020, 09:08:27 »
Updates 12/14/20
Resin Boy Project (Philippines) Lazurite Wrist Rest Teaser
Resin Boy Project x Lazurite Resin Wrist Rest (WIP)
