Author Topic: [GB] Panc40 Keyboard R2 (manu phase initiated)  (Read 45070 times)
Offline AlexAtPanc
    • Panc Interactive
« on: Mon, 23 November 2020, 14:06:54 »
Hello Everyone! This is the GB for round 2 of the Panc40 keyboard kit.
This is a 40% keyboard (Minorca: 43 keys, Sebright: 41 keys, Ancona: 47 keys) I designed. Here’s the GB link for the first round’s GB. This is a high profile aluminum milled case, with a PCB supporting hotswap and underglow. The switch plate is going to be top-mounted, with 6 circular tabs for added stability. This will have a left-mounted USB location, and uses USB-C and does support QMK.
UPDATE EDIT: I've received interest in having a new PCB option added, and I've worked with the designer Nasp to have it added as an option for this GB! The PCB is called the Pursuit40, and it is an ortholinear option with some extended bottom row options. It is MX-only and non-hotswap, so it requires soldering. It has a USB-C port and supports QMK. It is perfectly compatible with the Panc40 case, and has been added as an optional accessory. Because of this addition, I've moved the end-date from 12/20 to 1/3. This doesn't negatively impact the delivery date of the final product, so I wanted to give everyone a chance to get in on the GB!
Price is $320 for the below kit:
  • Milled aluminum top frame
  • 4° angle milled aluminum base with Frosted acrylic diffuser
  • Stainless steel topmount switchplate
  • Panc40 PCB
    • Hotswap
    • USB-C PCB terminal
    • QMK firmware
    • RGB underglow
  • 1x 2mm underplate foam
  • 2x 2u PCB stabs
  • Hardware
    • mounting hardware
    • set of rubber feet
  • CONUS shipping and handling
Album with additional prototype images
Ancona layouts
Minorca/Sebright layouts
Pursuit40 layouts
Typing test on a Panc40 Sebright with lubed gateron yellows
video by the inimitable @greenteei89 🙏🙏🙏
Free shipping is for CONUS entrants only. If you are outside of the continental United States, you will be contacted with additional shipping info after the conclusion of the GB.
The Group Buy entry period runs from 11/23 until 12/20 1/3.
Prospective shipping date to customers is Q2 2021. If your shipping address changes between your entry and the ship date, please contact me and I can make adjustments ahead of time.
If anyone has any questions, please feel free to ask.
FAQ section:
Q: Why did you create a new ortholinear PCB when it mimics layouts provided by the planck PCB?
A: The planck PCB has the USB terminal in a different location, so I couldn’t use it with this case configuration. Also, this PCB adds a few more layout options, as I wanted to make sure it was differentiated a bit.
Q: Why is the incline 4° instead of 5° or 7°?
A: After evaluating different configurations and angle options, I felt that 4 degrees was the best option. I did use 5 and felt it was a bit too drastic for this small of a keyboard. The prototype tester group also felt that the 4° was a suitable middle ground.
Q: Is it possible to only get the ortholinear options without buying the staggered options?
A: Yes!
Q: Is there going to be plate foam available for these layouts?
A: Yes!
Q: Is this build going to include a weight option?
A: No, I’ve never been a big fan of weights in my designs, and I think other people do a much better job than I do at that.
Q: Will the plate files be available for this keyboard?
A: Yes, I've made them available for R1 and while I don't explicitly plan on modifying the design for R2, I want to make sure there aren't any small changes, so I'm going to release the files after the GB ships.
« Last Edit: Fri, 22 January 2021, 10:46:56 by AlexAtPanc »
Re: [GB] Panc40 Keyboard R2 (40% layout, staggered and ortho options)
« Reply #1 on: Mon, 23 November 2020, 14:47:13 »
Approved :thumb:
Offline AlexAtPanc
    • Panc Interactive
« Reply #2 on: Mon, 23 November 2020, 15:01:17 »
Reserved  :D
Offline nasp
« Reply #3 on: Tue, 24 November 2020, 13:06:22 »
Too bad this doesn't have blockers. I have R1 so no need to buy another non-blocker one.
Good Luck  :thumb:
Offline AlexAtPanc
    • Panc Interactive
« Reply #4 on: Tue, 24 November 2020, 14:28:53 »
Good Luck  :thumb:
Thanks! FYI the Sebright (the layout with blockers) is available in this GB  :thumb:
Offline nasp
« Reply #5 on: Tue, 24 November 2020, 22:32:52 »
What size? 1.5mm blocker?
Offline AlexAtPanc
    • Panc Interactive
« Reply #6 on: Wed, 25 November 2020, 08:19:21 »
Both sides are 1.25u blockers  :thumb:
Offline AlexAtPanc
    • Panc Interactive
« Reply #7 on: Thu, 03 December 2020, 20:12:53 »
Thanks everyone who has joined so far!
I'm going to add "Yellow 1016" as a color option before the end of the week.
If you've already chosen a color and want to change, drop me a PM and we'll work it out :thumb:
« Last Edit: Tue, 08 December 2020, 08:12:27 by AlexAtPanc »
Offline Rumblehotep
« Reply #8 on: Fri, 04 December 2020, 19:18:33 »
Nice, will this be satin finish or gloss?
Offline AlexAtPanc
    • Panc Interactive
« Reply #9 on: Fri, 04 December 2020, 21:16:30 »
That's going to be a satin. Surprisingly it's not very glossy in keyboard form, which I'm surprised by.
Offline D3LTA
« Reply #10 on: Mon, 07 December 2020, 10:31:11 »
Can you provide some more detail on the OPTIONAL 2MM BRASS LAYER? Will this be clear coated?
Offline AlexAtPanc
    • Panc Interactive
« Reply #11 on: Mon, 07 December 2020, 13:24:00 »
Sure! It's a 2mm thick brass mid-layer that can be used either together with the diffuser or instead of it. It adds a bit of heft, and isn't clear-coated unless requested. I've encountered a lot of people who prefer to let it patina naturally, but if you'd rather have it sealed, that's definitely something that can be added to your order. :thumb:
Here are a couple pics of a Minorca with one installed:
Offline AlexAtPanc
    • Panc Interactive
« Reply #12 on: Sat, 12 December 2020, 10:06:00 »
So in love with this render I had to post it here <3
Orthogang
Offline nasp
« Reply #13 on: Sun, 13 December 2020, 07:34:17 »
Orthogang
[/quote
RISE UP!!
What's were the changes made to the case over rd1?
Offline AlexAtPanc
    • Panc Interactive
« Reply #14 on: Sun, 13 December 2020, 07:46:30 »
Orthogang
RISE UP!!
Just some very slight tolerance modifications! Other than that, everything in R2 will fit R1  :thumb:
« Last Edit: Sun, 13 December 2020, 17:32:17 by AlexAtPanc »
Offline Rumblehotep
« Reply #15 on: Sun, 13 December 2020, 13:09:19 »
Orthogang
Blockered Ortho? Oh man
Offline AlexAtPanc
    • Panc Interactive
« Reply #16 on: Sun, 13 December 2020, 14:40:39 »
Orthogang
It's a scene, my friend ;D
Offline AlexAtPanc
    • Panc Interactive
« Reply #17 on: Thu, 17 December 2020, 09:17:19 »
A few updates:
  • I've added a typing test to the OP. It's a Sebright with gateron yellows, lubed with a custom Superlube mix. It was done by the one and only greenteeai89.
  • Nasp has recently designed an alternate ortholinear PCB for the Panc40 case! It's called the Pursuit40, and it is a non-hotswap MX-only PCB. It's really cool and has gotten interest from a lot of folks, and after working with him, we've been able to add it as an option to this GB. He and I are very excited to fold it in. Prototypes have worked perfectly. I've added it as an option to the purchase page, and both it and the OP have had layout links added.
  • Because of the addition and some requests from others, the end date has been extended past the holidays, from 12/20 to 1/3. After discussing with my manu, we're confident this will not extend the delivery period of the product!
« Last Edit: Sun, 03 January 2021, 16:47:00 by AlexAtPanc »
Offline littlesmall
« Reply #18 on: Mon, 21 December 2020, 09:17:24 »
Interesting
Offline yuejia
« Reply #19 on: Wed, 23 December 2020, 01:54:39 »
It’s really Nice!! That is so beautiful!!
Offline yuejia
Re: [GB] Panc40 Keyboard R2 (40% layout, end date extended to 1/3)
« Reply #20 on: Fri, 25 December 2020, 01:28:15 »
That’s what I want!!! Amazing stuff!!!
Offline yuejia
« Reply #21 on: Sun, 27 December 2020, 19:30:08 »
That’s what I want!!! Amazing stuff!!! :) :)
Offline nasp
« Reply #22 on: Tue, 29 December 2020, 09:01:34 »
Panc40 with Pursuit40 pics should be coming soon(ish). Stay tuned  :thumb:
Offline AlexAtPanc
    • Panc Interactive
« Reply #23 on: Wed, 30 December 2020, 12:52:01 »
It's here!!  :thumb:
This PCB has some really cool layouts available, and I'm super excited that Nasp designed it around the Panc40 case 🙏🙏
« Last Edit: Thu, 31 December 2020, 10:02:44 by AlexAtPanc »
Offline AlexAtPanc
    • Panc Interactive
« Reply #24 on: Mon, 04 January 2021, 16:49:34 »
The Panc40 R2 group buy has wrapped! Thanks to everyone who joined, I will be in touch shortly with additional details! :thumb:
Offline AlexAtPanc
    • Panc Interactive
Re: [GB] Panc40 Keyboard R2 (manu phase initiated)
« Reply #25 on: Fri, 22 January 2021, 10:46:28 »
All parts and packing supplies have been ordered, and are either en route or being machined currently!
Here's a pic of the Pursuit40 PCB in a Panc40 blockered case:
« Last Edit: Fri, 22 January 2021, 10:48:23 by AlexAtPanc »
Offline nasp
« Reply #26 on: Sun, 24 January 2021, 16:11:59 »
My PCB and plate are ready!
Offline AlexAtPanc
    • Panc Interactive
« Reply #27 on: Sun, 24 January 2021, 19:40:14 »
Looking great!
All parts are ordered and packing supplies are on hand  :thumb:
We're sitting pretty thus far. Thanks again to everyone who has been a part of the GB!
Offline AlexAtPanc
    • Panc Interactive
« Reply #28 on: Tue, 06 April 2021, 08:59:14 »
Switchplates and bronze midlayers have arrived!
I expect the production sample to arrive shortly, and will take pics with the acrylic diffuser production sample.
Thanks to all for joining!
Offline munepi
« Reply #29 on: Wed, 03 November 2021, 02:59:15 »
Any updates?
I'm excited for the package to be shipped. :D
Offline dededecline
    • Linktree
« Reply #30 on: Fri, 01 April 2022, 08:52:43 »
You should pull a wacky April Fools Day prank and actually ship our boards after months of ghosting and lying
Offline giacombum
« Reply #31 on: Fri, 01 April 2022, 09:45:59 »
We should try to make public all his mails, with stupid excuses, lies and false promises.
Offline cigs_coffee
« Reply #32 on: Sat, 02 April 2022, 07:53:41 »
anyone received that promised shipping notification which should have taken place a month ago as has been announced in update 11?
Offline Blind_Panda
« Reply #33 on: Sat, 02 April 2022, 13:38:24 »
As a GB participant, I too would appreciate transparency with regard to the state of this project. It's been nothing but false promises for months and I'd just like to know what's going on.
Are these boards going to ship? Do they exist?
Offline Rumblehotep
« Reply #34 on: Sat, 02 April 2022, 14:29:38 »
I got emailed a shipping notification a month ago, but when I check the given USPS tracking it comes up as Not Trackable?
It gets here when it gets here I guess? (I hope!)
Offline giacombum
« Reply #35 on: Sat, 02 April 2022, 15:03:01 »
I never received tracking. I also sent a couple of mails, without reply. I asked to him truth and transparency, got nothing.
Offline dededecline
    • Linktree
« Reply #36 on: Sat, 02 April 2022, 16:15:44 »
A Timeline of the Panc40 R2 Group Buy
January 4th, 2021
Group buy closes officially.
Even now, the estimated shipping date is advertised as Q2 2021. It is now Q2 2022.
January 5th, 2021
The first update email goes out to group buy participants. Alex claims that the orders should be in the manufacturers' queue before Chinese New Year starts (February 12th, 2021). He also says that updates will be given on Geekhack and email, and he will be available on Discord.
January 22nd, 2021
On Geekhack, Alex says that everything has been ordered and is either actively shipping to him or being worked on. So nothing should be pending a manufacturer starting work on it.
April 13th, 2021
Alex sends out email update #02 to GB participants. Apparently we're waiting on a production sample to ship to him before starting machining of the full group buy order. He links to the Geekhack picture showing plates and brass midlayers. This will be the last time Alex updates the Geekhack GB thread.
May 22nd, 2021
Alex says we're looking at shipping to buyers around June 14th - 28th.
July 1st - 7th, 2021
Apparently MCU shortages have pushed shipping back to end of July. On Discord, he says that the issue is now resolved, but it's caused delay. To my knowledge, this is the first time he's said anything about PCBs being stuck in manufacturing.
August 2nd, 2021
Alex says something abourt working hard to finish PCBs quickly. Not sure if this means that he ordered them without components pre-soldered or what, this is the first time any "work" on the PCBs has been mentioned. No pictures of the PCBs are shown anywhere.
September 13th, 2021
Alex has been absolutely absent on all platforms for the last five weeks. This is one of the weirdest, most bizarre, incomprehensible GB updates I've ever received in my life. For some reason, all participants are cc'd instead of bcc'd. Here's the email sent out, in full:
I don't know where to begin with this. The fact that this is the first anyone's heard about this, the fact that he allegedly made drastic changes to the GB without informing its participants... there are a litany of questionable ethical business decisions on display here. And finally, he says that we should all receive our orders on October 14th. Also this is the last time he posts at all in the 40% server.
October 19th, 2021
October 14th, the promised shipping date, comes and goes with no news on any platform. On October 19th, an email goes out to GB participants that QC is taking longer than expected, and the new shipping date is November 2nd. No pictures or proof have been shared to demonstrate that any of this is true.
November 6th - 17th 2021
This update is deja vu from the previous month. Shipping deadline comes and goes with no messages, a few days later we're told QC and packing are taking longer than expected. We will get an update on Nov. 14th and expect shipping around December 16th.
The update on the 14th comes in on the 17th and once again blames QC with absolutely no additional pictures or information.
Requests for pictures go ignored.
December 28th - 31st, 2021
Mid-December passes with no shipping, no updates from Alex. Yet again, on the 28th he blames QC again and says shipping will happen end of January to beginning of February. At this point QC for a ~20 board GB has taken two months and is anticipated to take 1-2 more months.
On December 31st, after multiple participants request refunds or else they will be calling their banks for chargebacks, he finally shares pictures. He ignores the requests to include timestamps in them. You can see those pictures here.
February 22nd, 2022
Of course, beginning of February passes with no news, no shipping. People start discussing chargebacks in Discord again, I believe a few have started the process. Alex sends out an email very specifically saying that everything is ready to go and we will have tracking by 9:00 PM on February 23rd.
From this point, some people get tracking numbers, but not everyone. Those that did receive tracking numbers either see that the tracking number is invalid or that the item is in pre-transit. Nobody has seen any of the boards, not a single one has shipped. It's now been over a month since that last communication from Alex, almost a year since the initially promised GB fulfillment date.
He is no longer responding to support emails or Discord messages from anyone involved with the group buy. I have collaborated with Alex before, he was a well-known and well-trusted member of our community, and a vendor nonetheless.
The amount of disrespect and dishonesty shown towards Panc40 group buy participants is honestly abhorrent. Alex, if you're reading this, ship us our boards or refund us if you can. If neither of those things are possible, at least have the decency to be honest for once with us group buy participants and tell us the truth about what has happened with this group buy.
April 11th, 2022
The first communication from Alex since the shipping labels were generated. To my knowledge he still has not responded to any DMs regarding address changes or anything else (Alex, if you're reading this, please don't send my board to my old address). Thankfully this update is substantial.
Videos: 1 2
While I'm grateful to hear from Alex and get proof with pictures and videos, it doesn't diminish the terrible communication and inconsistent updates we've endured. Hopefully this board's saga will come to and end soon.
June 24th, 2022
Absolute radio silence from Alex. Any attempts at communication have been met with silence. He’s clearly capable of receiving messages however, as he requested address updates for GMK Thai Tea. So the Panc40 group buy participants are just being ignored.
September 2022
Still nothing from Alex to Panc40 purchasers, but now GMK Thai Tea buyers are also getting ignored. Check out the GMK Thai Tea GB thread to read about that, but it's a very familiar story:
  • Everything will be great
  • Everything is on hand
  • Excuses about minor thing needing to be done
  • A few updates full of lies about minor thing being done (QC for Panc40, shipping address updates for Thai Tea)
  • Absolute radio silence with no packages going out
« Last Edit: Tue, 13 September 2022, 11:56:24 by dededecline »
Offline cigs_coffee
« Reply #37 on: Sun, 03 April 2022, 02:05:55 »
Thanks dede and others for feedback, much appreciated.
Looking at the track record here in all its parts - should have seen it coming, seems to be pretty much the end of the line.
At this point i can't see anything good coming out of this. This guy must have lost it.
Very disappointing.
Offline dededecline
    • Linktree
« Reply #38 on: Mon, 11 April 2022, 11:36:47 »
Updated my timeline with the new update from Alex
Offline cigs_coffee
« Reply #39 on: Mon, 11 April 2022, 13:53:16 »
Gotta say, glad for the update.
This sounds / looks better. Let's see.
 I'd be really happy if this now would pass the finish line smoothly.
Offline munepi
« Reply #40 on: Thu, 28 April 2022, 11:10:03 »
Thank dededecline for posting the new update from Alex!!
But, I had not received any e-mail & his reply to my DM.
I'm terribly crowded how I can contact him.
Offline Blind_Panda
« Reply #41 on: Fri, 24 June 2022, 21:34:11 »
Three months later and we're not even a hair closer as far as anyone can tell  :confused:
Offline dededecline
    • Linktree
« Reply #42 on: Sat, 25 June 2022, 10:40:20 »
Updated the timeline with the Thai Tea comms
Offline cigs_coffee
« Reply #43 on: Tue, 28 June 2022, 17:00:13 »
quote - april 11, 2022:
"I have all of the parts and pieces of these orders and I'm currently putting them together and will provide every order in its entirety."
Oh, rly?
Offline cigs_coffee
« Reply #44 on: Tue, 23 August 2022, 17:30:44 »
Oh, rly?
4 months later still nothing -> bump for rip off.
Or prove us otherwise.
Offline Rumblehotep
« Reply #45 on: Fri, 09 September 2022, 12:47:52 »
Oh, rly?
Shipment notification for half my order was on 2/23/2002, USPS still doesn't understand the tracking number and the provided Shippo link still returns 400 error. The other half of my order, who knows? They might be in that photo, or those might be someone else's.  Drat cute 40%'s and their effect on me.
Offline IOVERCALLHISTIOCYTES
« Reply #46 on: Fri, 09 September 2022, 13:40:17 »
All quiet on the GB front for Thai Tea. There are no address change confirmations. Pwade, Thai Tea designer, is offering to come to the place of business and help them ship. I have requested a refund (it doesn’t sell for that much I can just buy it elsewhere) or to pick up in person but have received no answer.
Anyone here successful with a chargeback?
Offline dededecline
    • Linktree
« Reply #47 on: Tue, 13 September 2022, 11:57:01 »
Updated timeline to include link and some information about how the GMK Thai Tea group buy is now also getting ****ed by Alex
Offline cigs_coffee
« Reply #48 on: Fri, 21 October 2022, 00:13:21 »
let's not forget about this rip off
« Last Edit: Fri, 21 October 2022, 00:14:54 by cigs_coffee »
Offline jgodinez302
« Reply #49 on: Mon, 14 November 2022, 13:52:15 »
BUMP
Anyone heard from Alex?
