Author Topic: [IC] Gerald65 – Alice-Style 65% Gasket-Mounted Keyboard  (Read 46974 times)
Offline aidan.smith
« on: Tue, 24 November 2020, 12:51:23 »
265984-0
Gerald65 – Alice-Style 65% keyboard
Introducing the Gerald65, a 65% Alice-style keyboard. Right above the arrow keys, this keyboard features a full 4 keys maintaining a consistent border around the top of the arrow keys. The Gerald65 will be built out of stacked acrylic layers and will have a variety of plate options. Similar to the Arisu, there is not an additional key on the right-hand side. However, unlike the Arisu, this keyboard has the ‘P’ in the horizontal position, to make it easier for your pinky to find.
Picture gallery: https://imgur.com/a/CDK5Rlh
Interest Check Form: https://forms.gle/iqRuaKkyAhg7maEv5
Discord server: https://discord.gg/grqYTzUSNa
Features:
•   Hotswap
•   Multiple plate materials (POM, FR4, Carbon Fiber, Aluminum, Acrylic)
•   Plate foam & case foam
•   Acrylic sandwich mounted, currently experimenting with gasket mounting it
•   PCB with QMK and VIA support
•   Adjustable typing angle (0 or 6 degrees)
Timeline:
GB going live today (May 9th 2021). Currently live in EU/UK and Asia. Will be live for NA at 1pm PST
Pricing:
$150 for the base kit (slight cost increase for different colors)
Extra plates will also be sold, each plate will come with an extra gasket kit.
Vendors:
NA: Paper Crane Keyboards (Our own storefront) https://papercranekeyboards.com/
Asia/SEA: Zion Studios https://zionstudios.ph/product/groupbuy-gerald-65-alice-keyboard/
EU/UK: Prototypist https://prototypist.net/collections/live-group-buys/products/group-buy-gerald65
265986-1
265988-2
265990-3
Update:
4/5/2021
-Updated pictures to the current prototype
2/24/2021
-The corners are now slightly rounded, making it much nicer to handle, and making it look a bit nicer
-Gasket has been redesigned. The plate no longer goes all the way to the side of the keyboard and is instead hidden by an additional acrylic layer. This makes the side look much cleaner, and also gives us more flexibility with the gasket. I don't have pictures of this new system yet, but once I receive the new switch plates, I will update with some pictures.
-Added approximate timelines and price to this thread
If you would like to stay up to date on this project, you should consider joining our Discord server: https://discord.gg/grqYTzUSNa
« Last Edit: Sun, 09 May 2021, 20:11:13 by aidan.smith »
Re: Gerald65 – Alice-Style 65% keyboard
« Reply #1 on: Tue, 24 November 2020, 12:53:40 »
Questions:
  • I assume there is encoder left of the arrows? Is this final? Because it isn't mentioned in the post. Is it optional?
  • Typing angle?
« Last Edit: Tue, 24 November 2020, 12:55:58 by AspiringMechKeebFan »
Offline aidan.smith
Re: [IC] Gerald65 – Alice-Style 65% keyboard
« Reply #2 on: Tue, 24 November 2020, 12:57:33 »
Yes, currently there is no encoder next to the arrows. The hole you see there is actually to see the silkscreen logo that will be on the PCB. If you select a solid colored case for the top, you won't be able to see it though.
« Last Edit: Tue, 24 November 2020, 13:12:51 by aidan.smith »
Offline aidan.smith
« Reply #3 on: Tue, 24 November 2020, 14:12:26 »
[size=78%]Typing angle?[/size]
The typing angle of this currently is 0 degrees since it is an acrylic sandwich case, but I am working on different ways of propping it up.
Offline xanserkx
« Reply #4 on: Tue, 24 November 2020, 16:12:49 »
Gasket mounted? Very nice. Good luck with the IC
Oblotzky AIS65 - Rama Zenith - RME Studio Emery65 - TGR Tomo - Hex 4B - Cablecar Design Angel - Cablecar Design Phoenix - Cablecar Design Cypher - Hand Engineering Haus - TX HJ75 - Parallel Limited Portal -  SingaKBD Kohaku -  and bunch of prototypes that I made :(
Sold: Merisi Ottantaquatro
Offline Ireris
  • p a i n
« Reply #5 on: Tue, 24 November 2020, 17:00:10 »
Is it tented
Sent from my Pixel 5 using Tapatalk
Offline holer
« Reply #6 on: Tue, 24 November 2020, 17:01:33 »
Is there any chance you will make this support split left shift? (2.25u --> 1.25u + 1.0u)
I'm willing to give up my ISO enter, but I love my extra by the left shift.
Regardless, good luck with the IC  :)
Offline Kacperoni
« Reply #7 on: Tue, 24 November 2020, 17:49:15 »
KB looks sexy!
I wanted to try an ergo keyboard, but none of them looked interesting lately. This one tops all of them!
I'd love some future renders with black polycarb on top and maybe a brass plate to see how it looks like.
Offline aidan.smith
« Reply #8 on: Tue, 24 November 2020, 18:05:19 »
Yep! I am currently experimenting with various ways of gasket mounting to figure out which one will be the best.
Offline aidan.smith
« Reply #9 on: Tue, 24 November 2020, 18:06:35 »
Is it tented
No, this keyboard is not tented. It is just the outwards tilt of the keys.
Offline aidan.smith
« Reply #10 on: Tue, 24 November 2020, 18:09:12 »
Yup, I am working on increasing options for the solder PCB! Currently, that plate was made for just the one layout, but I am working on a new plate that will have both options for split backspace and split left shift.
Offline aidan.smith
« Reply #11 on: Tue, 24 November 2020, 18:11:56 »
KB looks sexy!
Thank you! Yeah, I have been working on some renders, but I decided to just include pictures for this IC. I will make sure to include some cool combinations like that when they are ready! Thank you!
Offline diymkb
« Reply #12 on: Wed, 25 November 2020, 07:24:48 »
I'm interested in your project. Do you have a target price/price range at the moment? What's your current planned timeline?
Offline Freeaboo
« Reply #13 on: Wed, 25 November 2020, 10:07:51 »
gib nao
Offline aidan.smith
« Reply #14 on: Wed, 25 November 2020, 12:26:19 »
Both of these things are very approximate right now, that's why I haven't listed them in the post. I am hoping to be done in about December or January, so the group buy would happen after then.
For price, I am aiming for somewhere in the range of $150, but that is very approximate too and may not be final.
Thank you so much for your interest!
Offline afynyth
« Reply #15 on: Wed, 25 November 2020, 15:02:59 »
Is there a way to have the screws screw in from the bottom of the case instead? Very nice looking board, the Alice + arrow key layout is great. Also, depending on the gasket mounting method, it might be good to have translucent gaskets.
Offline aidan.smith
« Reply #16 on: Wed, 25 November 2020, 17:33:03 »
Thank you! I currently have translucent gaskets, however, with the completely transparent top acrylic, you can still see them. There will be options for other tops when we have the group buy. I am also still experimenting with what kind of gaskets will work the best for this type of board.
For the screws, they screw in to the top and the bottom in order to bind the sandwich together. I plan on getting some lower-profile screws before the group buy though.
Offline Magnificent Bureaucrat
  • Sooooo much red tape
« Reply #17 on: Wed, 25 November 2020, 17:44:20 »
Keeping an eye on this one. I've been tempted to try an alice-like for a while so something at a more reasonable price point is a tempter.
Also it has an old man's name.
Offline aidan.smith
« Reply #18 on: Wed, 25 November 2020, 18:59:34 »
Sweet! I am glad to hear it! It is named after a little paper crane (that I named Gerald) that has been my good luck charm for many years now. Gerald the paper crane sits on my car dash and keeps me safe!
Offline hottrout
  • I'd Hit Dat Key
« Reply #19 on: Sat, 28 November 2020, 04:27:33 »
Interesting and interested.
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adιlie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
Offline r13lbag
« Reply #20 on: Wed, 24 February 2021, 20:32:09 »
If you're wondering what's the status of this GB, you might want to consider joining the discord server. Very interesting.
Re: [IC] Gerald65 – Alice-Style 65% Gasket-Mounted Keyboard
« Reply #21 on: Thu, 25 February 2021, 02:11:22 »
No, I don't think I will join countless Discord servers to stay updated on project progress. Discord is suboptimal platform to do so.
Offline Livid
« Reply #22 on: Thu, 25 February 2021, 09:46:32 »
ok
Offline aidan.smith
« Reply #23 on: Thu, 25 February 2021, 15:18:56 »
That is totally ok! If you still want to be updated, you can add your email to the list (in the interest check). I am just going to send out an email once the keyboard is in GB. Otherwise, you can continue to find updates here! :)
« Last Edit: Thu, 25 February 2021, 15:25:00 by aidan.smith »
Offline edawg
« Reply #24 on: Thu, 25 February 2021, 17:28:44 »
Thoughts on metal vs acrylic? Would love to see this in some sleek gunmetal forms
Offline zionsped
    • Simbusped
« Reply #25 on: Sat, 10 April 2021, 13:40:30 »
Love this!!
Offline Gaul
« Reply #26 on: Mon, 12 April 2021, 02:02:29 »
that's a really beautiful keeb if i ever seen one, then for the price, 150 for gasket mount and alice style, sign me up :D
also, i've heard about an encoder on the bottom right, will there be one?
Offline aidan.smith
« Reply #27 on: Tue, 13 April 2021, 12:19:47 »
Thank you so much! I appreciate it!
No, there will not be an encoder down there. Originally, the pictures that I had here had no pcb, so there was no logo in the circle cutout. This led people to think there was going to be an encoder down there :).
Thanks so much for your interest and kind words!
Offline Chozo Ghost
« Reply #28 on: Tue, 13 April 2021, 13:50:24 »
Been itching to try an Alice-style keyboard for so long now, and I'm thinking this is for sure going to be the one! If you can make that $150 price tag a reality, that's an instant buy for me!
« Reply #29 on: Tue, 13 April 2021, 14:04:11 »
this is an extremely cool project, but you chose gerald as the name for some reason
Offline aidan.smith
« Reply #30 on: Tue, 13 April 2021, 17:18:03 »
Thank you, I appreciate it! Gerald is the name of a paper crane that has been my good luck charm for several years now :). Personally, I like the name a lot and it means something to me, but it's not visible anywhere on the keyboard after assembly if you're concerned about it.
« Reply #31 on: Tue, 13 April 2021, 21:37:59 »
ok that's actually kinda cool, you are excused, i might buy this
Offline LaserCrafter
  • reeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
« Reply #32 on: Wed, 14 April 2021, 02:45:53 »
why must you keep making me light my wallet on fire
Keyboard Collection: Unikorn, Orion v1, Orion v3, Realforce 87u, Das II, 356mini, Wang 325-3770, Lightpad v2, Deko Fast Action
Keyset Collection: OG Doubleshots x2, CRP 2551 R4, Muted 2, Cyan R1, WoB, DCS Wyse, ISO OG POM, ePBT Blanks, BSP Blanks, BoW + Gigachild, Minimal R1, SAD Dyesubs,
Offline aidan.smith
« Reply #33 on: Wed, 14 April 2021, 13:45:54 »
haha oops! I am very glad you like it tho :) Thanks for the support!
Offline UGunaLOSE
« Reply #34 on: Sun, 25 April 2021, 13:52:25 »
Oh this is def a beautiful board! GLWIC, might just join the discord for more updates :) <3
Offline aidan.smith
« Reply #35 on: Sun, 25 April 2021, 14:30:21 »
Thank you! And yeah, the discord can definitely help answer any questions that you may have too!
Offline hottrout
  • I'd Hit Dat Key
« Reply #36 on: Sun, 09 May 2021, 06:59:24 »
Can't wait to get my hands on one of these.
Systems -
  Keyboards -
Offline aidan.smith
« Reply #37 on: Sun, 09 May 2021, 13:11:10 »
Thank you! It will be going live very soon!
Offline Qwapa
« Reply #38 on: Mon, 10 May 2021, 19:06:49 »
Love the silk screen!
Offline aidan.smith
« Reply #39 on: Mon, 10 May 2021, 21:43:42 »
Thank you! I appreciate it!!
Offline hottrout
  • I'd Hit Dat Key
« Reply #40 on: Fri, 04 February 2022, 12:52:31 »
It arrived, I built it and it is beautiful, as follows
Specific 'Green Edge' Clear with Bespoke Carbon Fibre Plate
Custom Carbon Fibre Plate Wrist Rest with Personalised Design
Cerulean Tactile Switches with 65g Spring, Nylon Housing with POM Stem
GPL 105 on Springs, Factory Lube on Stems
Owlab Stabs with Silicone wire supports.
This is not only a good looking board, it has a really positive feeling and a great sound signature to boot.
« Last Edit: Fri, 04 February 2022, 13:09:33 by hottrout »
Systems -
  Keyboards -
Offline Timception
« Reply #41 on: Mon, 12 September 2022, 05:29:39 »
You can unfollow or leave a discord server at the click of a mouse, can you not lift your fingers  :-[?
I assume finger lifting should be a pleasantry since you are into keyboards ya grumpy chap.
Offline Nonnegaard
« Reply #42 on: Fri, 16 September 2022, 06:10:53 »
Is it tented
the top is a flat-ass plate of acrylic, what do you think
Aeon, TGR Jane V2, Dolphin 2021, Gherkin, Model M, 5°, NCR80, M0110-A
