Author Topic: [IC] GMK 80082 | GB LIVE  (Read 174058 times)
Offline konstantin
  • Formerly constexpr
Re: [IC] GMK 80082 | December 6-31 2020
« Reply #150 on: Fri, 04 December 2020, 06:16:10 »
Please do not remove 5%€ it is used in Swedish layout. Both 4$ and 5% are in base, so why would you change one for another?
The Swedish layout also uses the E€ key, which is the euro sign's standard placement in that and all other layouts that can use 5%€ (SE/FI, NO, DK, IS, FO). 5%€ is a non-standard key that isn't used in all implementations of the Swedish and other layouts, whereas E€, being standard, is present in all of them.
Now, I would ordinarily not suggest the removal of this key because some users, like yourself, may prefer to have it. However, this is an extraordinary situation since the kits have been finalized and adding extra keys is likely not viable at this point. UK users (which make up a significant portion of the total ISO userbase) are currently disadvantaged compared to all other groups supported by the NorDeUK kit — they are missing keys and sublegends which are required for full support of their layout, whereas all of the other supported layouts have all of their keys and sublegends. In this case, I think it's a reasonable compromise to swap 5%€ (which, again, is a non-standard and partially redundant key) out for 4$€ in order to give UK users full support for their layout.
I hope you understand.
« Last Edit: Fri, 04 December 2020, 06:21:40 by konstantin »
Offline depletedvespene
    • Keyboard-related resources.
« Reply #151 on: Fri, 04 December 2020, 07:31:15 »
Let's clear up the confusion. On the placement of the euro symbol.
When the euro symbol was introduced, the EU recommended that it should be placed under AltGr-E (so the E keycap became E€).
ALMOST ALL national layouts in western Europe were updated at the time with this recommendation. The most notable exception was, of course, the English (UK) layout, which placed the symbol under AltGr-4 (so the 4$ key became 4$€).
Microsoft at the time was adding stuff to their (primitive) version of the "US International" layout, and AltGr-E was already taken, so they placed the euro symbol under AltGr-5 instead (so the 5% key became 5%€).
Later on, Microsoft revised their implementations of the national layouts for Western European languages, and added a second placement for the euro symbol, so it could be typed either as AltGr-E or as AltGr-5. But, this must be stressed, the second assignment is not the actual standard.
Check out the differing national layouts at http://www.farah.cl/Keyboardery/A-Visual-Comparison-of-Different-National-Layouts/. You won't believe where the Maltese national layout places the euro symbol!!!
Offline HappyB0T
  • I'm a Piggie
« Reply #152 on: Sun, 06 December 2020, 07:20:08 »
GB is live -  :D
Offline clackeys
    • Clackeys
« Reply #153 on: Sun, 06 December 2020, 17:09:17 »
Really looking forward to this set
Offline Galakc
« Reply #154 on: Mon, 07 December 2020, 14:49:52 »
The blue is calling to me...I need it lol
Offline zombie2life
Re: [IC] GMK 80082 | GB LIVE
« Reply #155 on: Tue, 08 December 2020, 05:57:12 »
Why are there extra F, J and B keycaps on the standard kit?
I cannot tell the difference ahahaha....
« Last Edit: Tue, 08 December 2020, 05:59:05 by zombie2life »
Offline Scriba
Re: GMK 80082 | December 2020
« Reply #156 on: Thu, 10 December 2020, 04:57:50 »
So if no color matching is happening, can I assume the blue will be just as dull IRL as the pink was versus the render?
The renders above reflect the colors IRL.
sry but that's not true. look my post at the GB Thread.
Offline HappyB0T
  • I'm a Piggie
« Reply #157 on: Sat, 12 December 2020, 06:50:27 »
F and J without the bumps
Split layouts sometimes have 2 B keys on them.
If your keyboard is split do you need the bumps?
 I’m sure there are people don’t like the additional texture on their keys.
Offline zombie2life
« Reply #158 on: Sat, 12 December 2020, 07:18:08 »
I see...
Thank you.
Offline MdotMaxson
« Reply #159 on: Thu, 17 December 2020, 04:43:29 »
It’s like GMK electric grew boobs
Offline merca
« Reply #160 on: Fri, 01 January 2021, 13:58:43 »
Blue is pretty dank, thank you Dixie.
Offline whezil
« Reply #161 on: Sat, 16 January 2021, 07:22:19 »
Can't wait to see the BL00 set IRL. Super excited to own this set. I'm going to tune the rgb in my room+pc to match perfectly.
