Author Topic: [GB] Monarch (WKL 65, knob, interchangeable inserts) EXTRAS AVAILABLE!!!!  (Read 81403 times)
Offline DoCallMeKing
Monarch by King Boards
EXTRAS ARE NOW AVAILABLE!!!
Group Buy links below are now live! GB will be starting December 5th at 11am EST and running through December 20th (unless all slots are claimed earlier).
I've decided to go with a FCFS style for this first GB. Based on volume and demand, I will alter this approach for the next GB if needed.
There will be 200 slots available of the Standard kit and 50 slots available for the Limited Edition.
Standard Kit Link                    Limited Edition Link
Taeha Types completed a build stream December 8th at 9pm EST.
Background
Please review the IC here https://geekhack.org/index.php?topic=108826.msg2962758#msg2962758 for any and all background information.
Description
Monarch is a WKL 65% with a separated arrow cluster, rotary encoder knob, and interchangeable inserts. (Initially I was only going to offer WKL but the amount of requests I received to also make WK has led me to offer that option as well).
I wanted the board to be customizable based on the users preference and the keysets they had on hand.
For example if you have been rockin' GMK Striker for a few months and want to change it up, I thought it would be great if you could change the look of your board as well to match GMK 8008 if you're throwin' that on!
The interchangeable inserts is really what I set out to create because I like to switch my keysets frequently and I was too often left with only a couple options that I could ever match to my board due to its color.
Simply pop the case open, swap out the insert to a new color, and you've completely changed the look of your board!
The rotary knob has grown to become something I really love on a board because it gives me easy quick control of so many different things.
Each kit will come with 1 brass knob and you'll have the choice of one of 4 colors (Gold, Black, Silver, Carbon Gray).
Monarch deploys a 7.7o typing angle for a comfortable typing position anchored by an o-ring burger mount.
The front lip height has been kept at a low 17.5mm for a smooth transition.
Having a separate arrow cluster not only increases usability but also shows off more of the stunning insert colors.
The board will also come with a 2mm custom internal liner for increased sound dampening.
Each kit will also be shipped with a carrying case custom designed for Monarch.
A portion of the large brass weight is visible from the back of the case but also spans a large portion of the bottom of the case with a beautiful engraving of the King Boards logo.
The PCB is QMK and VIA compatible. It also has ISO compatibility however the plates offered will not support it. I will make the plate files publicly available later on so members can cut their own if they want.
This design also utilizes a daughterboard to enable a symmetrical center-location port.
Plates will be available in Aluminum and Brass.
There will be 2 versions of Monarch available. Standard and Limited Edition.
This board is a beastly beauty weighing in at about 7.5lbs for the Standard version and a whopping 9.4lbs for the Limited Edition.
Prototype Images
This image shows the slightly modified bottom to allow for easier access
to the daughterboard and better cable management.
Additional Color Renders can be found here...
https://imgur.com/a/p6iJDir
Layout
Standard Kit
$500 + ship
The standard kit will include...
  • A Top and Bottom Case of The Same Color (Black, Blue, Red, Gray)
  • Aluminum Insert in Choice of Layout (WKL or WK) and Color (Black, Blue, Red, Gray)
  • Plate (Aluminum or Brass)
  • Brass Weight
  • Rotary Encoder
  • Brass Knob (Gold, Black, Silver, Carbon Gray)
  • Inner Sound Dampening Liner
  • Custom Carrying Case Made Specifically for Monarch
  • PCB
  • Daughterboard
  • Associated Cables, Screws, O-rings, and Bumpons
Color Options For Case and Insert
Black
Blue
Red
Gray
Limited Edition
$575 + ship
For the Limited Edition model you have the option of either an E-White or Black case paired with a gorgeous full Brass Insert in your choice of WK or WKL.
The Brass Insert is only available as part of the Limited Edition version and will not be available to purchase as an extra.
This Insert adds roughly 2lbs to the overall weight and even more to the uniqueness.
Extras
  • Plate - Aluminum ($20) , Brass ($24)
  • Insert - Aluminum ($65) (Black, Blue, Red, Gray)
  • PCB - Comes with PCB and Daughterboard ($40)
  • Encoder - $4
  • Knob - $8 (Gold, Black, Silver, Carbon Gray)
  • Carrying Case - $20
Summary
  • WKL 65% (also available as WK)
  • 7.7o angle
  • Rotary Encoder Knob
  • Interchangeable Insert Pieces
  • O-Ring Burger Mount
  • QMK/VIA compatible
  • 17.5mm Front Lip Height
  • 2mm custom internal liner for sound dampening
  • Roughly 7.5lbs for standard version and 9.4lbs for Limited Edition
  • USB-C Daughterboard
FAQ
  • Any ISO?
    The PCB will support ISO and I will make the plate file public to allow anyone to get their own ISO plate cut.
  • Can I get a custom color?
    Sorry not at this time.
  • Can I get a custom finish?
  • How long until delivery?
    If you've been a part of GB's before you know the normal timelines but I've made every effort to get this completed quicker then normal. Most vendors use Sea shipping to receive their parts whereas I'm doing Air so the delivery time should be cut down by around a month. I would ballpark about 10-12 weeks based on my relationship with my manufacturers with the obvious COVID delays always possible.
  • Is it Hotswap?
  • Will I be able to purchase extra pcb's, plates, inserts, etc.?
    Yes. They should be listed above but if I've missed something you're interested in, please let me know.
  • Can I please get a brass insert?
    Sorry but they are only part of the Limited Edition.
  • How will I pay?
    If you are one of the first 200/50 then I will send you an invoice to be paid within 24hours of receipt. If payment is not made within the timeframe, I will offer the kit to another buyer. A separate invoice will be sent out once the kit is ready to be shipped to avoid hassles with people changing addresses.
  • Is there a Discord?
    Sorry but at this time there is not. I should have some more time coming up soon in order to maintain a channel, at which time I would notify everyone of its creation.
  • How will you handle updates?
    I will post updates to this thread at the very moment I have them. Rest assured I will keep everyone updated as the process moves along and the current status of everything.
I really hope you enjoy the design! I look forward to getting them in the hands of everyone that wants them.
« Last Edit: Thu, 22 July 2021, 02:50:11 by DoCallMeKing »
Re: [GB] Monarch (WKL 65 w/ arrow cluster, knob, interchangeable inserts)
« Reply #1 on: Tue, 01 December 2020, 21:32:57 »
RESERVED
- Taeha Types will be doing a build stream of Monarch on December 8th at 9pm EST
12/6/20
   - All LE invoices have been sent out at this time. Please remember the 24 hour timeframe for payment has now begun or I will open up the slot to someone who is waitlisted. Thank you all so much!
12/7/20
   - All Standard Edition slots have been accounted for! Invoices for these will be going out over the course of the next 12 hours. Please remember you have 24 hours to make payment from the time of invoice receipt or the slot will be opened up to another member. Thank you all for the tremendous support! I can't tell you how much I appreciate it!
   - UPDATE: As is typical in a GB, some people entered duplicates, and some others haven't responded to their invoices so there are a small number of Standard Edition spots that have been opened back up. The Standard Edition form is now back open and I will close it down again once I have these slots filled.
1/15/21
   - Production of the keyboards are well underway!
   - Carrying Cases are almost complete with production. I will have a couple images of them on my website soon.
   - Website will be announced in the coming days (hopefully not weeks  :))
2/1/21
   - Website is live at www.Kingkbs.com
   - Updates for Monarch and announcements for future projects will be posted there.
   - There is a "News" section that will contain the updates.
   - We'll post updates here as well but mostly trying to point people over to the website so its a little easier and more controlled for us.
   - Please sign up for the newsletter so you will receive updates and news the moment its pushed out and you won't have to search for it.
   - Stay Safe All!
2/2/21
   - New production update posted to the website in the News section. Please go there to view it.
   - Thanks and have a great day!
3/11/21
   - New production update posted to the website in the News section. Please go there to view it.   www.kingkbs.com
   - Stay safe!
3/29/21
   - Thanks very much and stay safe!
4/14/21
   - Another production update posted to the website. Check it out at www.kingkbs.com
   - Have a great day!
4/25/21
   - Latest production update posted to the website.
   - Stay Safe!
5/5/21
   - Packaging for shipping has begun.
   - Get hyped!!
7/22/21
   - Extra Monarch's are now available!
« Last Edit: Thu, 22 July 2021, 02:51:17 by DoCallMeKing »
« Reply #2 on: Wed, 02 December 2020, 09:25:54 »
Approved
Offline hyppialonso
« Reply #3 on: Wed, 02 December 2020, 09:29:32 »
Just realised that silver ooption is gone  :( But still a must buy for me , hope I can secure a spot.
« Last Edit: Wed, 02 December 2020, 09:31:28 by hyppialonso »
« Reply #4 on: Wed, 02 December 2020, 09:54:49 »
Just realised that silver option is gone  :( But still a must buy for me , hope I can secure a spot.
Hi there!
Sorry about that but yes the Silver option has been removed as I needed to trim down some of the possibilities due to all the choices already :)
Best of luck on the entry!
Offline BrainBunker
« Reply #5 on: Wed, 02 December 2020, 14:38:51 »
The insert idea is honestly fantastic! Do you plan to support more insert colors sold separately in the future? Are you open to offering E-white in any future run of this board, or is it only for limited edition in the first round?
« Reply #6 on: Wed, 02 December 2020, 19:47:54 »
Hi mate!
Great question!
Yes I intend to offer more colors at a future time. Probably like 2-3 months after everyone has their boards I will make a posting for more colors to be ordered.
I know people's preferences change and the idea is to be adaptable with this keyboard so I will definitely be doing that.
I'll most likely post a poll question to see what colors people would like to see and then just produce more inserts.
I can't answer the question about e-white for a subsequent round at this time because I need to see if the demand is there first.
I also have other projects in the works that I want to get into production.
If the board is well received and people would like more of them, I have no problem running it again with e-white as an option for the standard kit.
Thanks for the interest and have a great day!
Offline DuellM
  • Keyboard Fatty
« Reply #7 on: Thu, 03 December 2020, 02:26:16 »
Mmmm Lilac with graphite insert that would look amazing, sorry just thinking and writing
« Reply #8 on: Fri, 04 December 2020, 06:59:59 »
That does sound like a nice combo for sure!
Offline Eoen
« Reply #9 on: Fri, 04 December 2020, 08:22:34 »
Where will the signups be hosted? Website, Google Form, Other?
Board looks great.
« Reply #10 on: Fri, 04 December 2020, 09:31:06 »
Board looks great.
It will be a google form this time around.
I'm working on getting a website up and going for all future releases.
Thanks so much !!!
« Reply #11 on: Fri, 04 December 2020, 20:36:30 »
I’ve received a lot of questions about the brass and wanted to post that PVD is not option for this gb unfortunately. We’ll see in the future but I have mixed feelings about it personally.
Offline prototype26
« Reply #12 on: Fri, 04 December 2020, 20:50:09 »
Where is this shipping from?
« Reply #13 on: Fri, 04 December 2020, 21:32:39 »
Offline brohothepirate
« Reply #14 on: Fri, 04 December 2020, 21:50:53 »
Can we order both LEs on the form or is it limited to one board?
Offline hyppialonso
« Reply #15 on: Fri, 04 December 2020, 22:18:33 »
Sorry for my ignorance, if the brass is not PVD, does it mean that it will get rusted easily?
« Reply #16 on: Fri, 04 December 2020, 22:27:32 »
You cannot order both LE’s on the form at once sorry.
« Reply #17 on: Fri, 04 December 2020, 22:34:14 »
It won’t rust, it will patina over time giving character. PVD is a very specific and expensive process that can yield excellent results if done perfectly but in my opinion the cost isn’t worth the gain.
I for one love the feel and texture of sandblasted brass.
« Reply #18 on: Fri, 04 December 2020, 22:49:40 »
I see, but the implication is that as long as I'm fast enough to come back I can get the other one on a second attempt? Or is it 1 LE per person?
Offline asmashedpumpkin
« Reply #19 on: Sat, 05 December 2020, 02:56:15 »
It’s a shame your logo isn’t the Monarch from Ventura Brothers.  I’m sure that would have brought a whole different set of issues though.  Anyways... gl to everyone in the GB.
« Reply #20 on: Sat, 05 December 2020, 06:46:50 »
Haha that would’ve been funny.
Monarch is only the name of the first board though. My subsequent ones aren’t butterfly related names :)
Hence the Lion logo.
Thanks for the interest!
Offline prototype26
« Reply #21 on: Sat, 05 December 2020, 09:17:43 »
Also are there any options for plate color? Or we don't get to choose?
« Reply #22 on: Sat, 05 December 2020, 09:39:38 »
Sorry but no color choice for plates in this round. There are a lot of options already so I needed to try and minimize them.
Offline hyppialonso
« Reply #23 on: Sat, 05 December 2020, 10:03:04 »
Just realised that since I don't know whether I made it to the limited edition, should I go for the standard one as well for securing a spot?
« Reply #24 on: Sat, 05 December 2020, 10:03:51 »
If you already submitted for LE, then you made it.
Offline stormer_kbds
« Reply #25 on: Sat, 05 December 2020, 10:05:28 »
That wasn't so bad.  3 pages went pretty quick.  Hope I actually get a slot for once.  Great keyboard design, I love anything unique.  Nice job and I look forward to your next creation!
Offline prototype26
« Reply #26 on: Sat, 05 December 2020, 10:06:45 »
Submitted. Hopefully I win :)
Offline ZavaZ86
« Reply #27 on: Sat, 05 December 2020, 10:07:17 »
Now the painful waiting time begins until invoices are out  :'(
Offline spicysol
« Reply #28 on: Sat, 05 December 2020, 10:07:59 »
How soon will invoices be out? no rush
Also, if we didn't make LE, we're defaulted to standard?
« Reply #29 on: Sat, 05 December 2020, 10:08:52 »
Thank you!
I'll be in contact as quickly as I can with the winners!
« Reply #30 on: Sat, 05 December 2020, 10:09:58 »
Hope you do as well.  A 9.5 lb keyboard that has no window blocker and isn't TKL... dear lord sign me up!
Offline Bantalope
« Reply #31 on: Sat, 05 December 2020, 10:11:11 »
Since I got in for LE just double checking that definitely means I got a spot?
Also just wondering when the invoices are gonna be sent out, no rush on it just was interested.
« Reply #32 on: Sat, 05 December 2020, 10:12:12 »
Thank you!
I'll get back to everyone soon.
I'll do my best to get everyone notified as quickly as possible :)
Offline chowder78
« Reply #33 on: Sat, 05 December 2020, 10:12:50 »
I submitted the form for the LE but wasnt sure if i put my discord user in correct, so i submitted another one, is that okay? I will only purchase 1 board.
Will the invoice also show the options we chose?
« Reply #34 on: Sat, 05 December 2020, 10:13:24 »
If you entered for LE, you have made the cut!!
There are only a couple slots remaining for LE.
« Reply #35 on: Sat, 05 December 2020, 10:15:13 »
The invoice will show the chosen options yes.
I will contact you separately about the order when I review them all.
Thank you for letting me know.
Offline zanaduk
« Reply #36 on: Sat, 05 December 2020, 10:17:01 »
Will we be able to modify our orders (like in terms of the extras)? In a rush to get a spot for the LE I might have chosen the wrong additional insert color.
Offline chowder78
« Reply #37 on: Sat, 05 December 2020, 10:18:12 »
I hopefully made the cut tho. For the possible wrong discord name input, you should have my email
« Reply #38 on: Sat, 05 December 2020, 10:50:43 »
If you need to make an adjustment, please send me a PM with your email address you used for the form and let me know what you would like adjusted.
« Reply #39 on: Sat, 05 December 2020, 10:53:23 »
You are good, yes. There are only 2 LE spots remaining.
Invoices will be sent out when I can sift through all of them :)
I'll do my best to get them out soon.
Offline dlgusgh
« Reply #40 on: Sat, 05 December 2020, 11:12:57 »
I entered for the LE just now... But really not sure if I made the cut with only 2 LE spot remaining 20 min ago...
« Reply #41 on: Sat, 05 December 2020, 12:14:35 »
All the LE kits have been accounted for. Only the Standard kits now remain.
Thank you all so much for the support!
Offline KaosJ
« Reply #42 on: Sat, 05 December 2020, 13:24:36 »
Pm'd
anyway, can't find the white color for the top-bottom option in the form, i can see it only for the insert, is that a mistake?
« Reply #43 on: Sat, 05 December 2020, 14:58:32 »
I believe the white case option was only available in the LE version
« Reply #44 on: Sat, 05 December 2020, 15:05:35 »
Pm'd
Yes the other member is correct that e-white top and bottom was only available for the limited edition.
E-white insert is available for the standard edition but not top and bottom. Sorry about that if it was unclear.
« Last Edit: Sat, 05 December 2020, 15:28:08 by DoCallMeKing »
Offline chowder78
« Reply #45 on: Sat, 05 December 2020, 17:03:01 »
Hi, just wondering when should I expect to receive the invoice/ get in contact due to the possible wrong discord user?
« Reply #46 on: Sat, 05 December 2020, 17:11:21 »
Invoices for the LE kit should be out within the next 12 hours.
Please verify all the items are correct and PM me  if there are any issues or discrepancies.
« Reply #47 on: Sat, 05 December 2020, 18:05:50 »
Awesome news, money in hand!  Nice job today, very busy I'm sure.
Offline newtonapple
« Reply #48 on: Sat, 05 December 2020, 21:53:45 »
When should we expect to know if we got in on the standard edition?
Offline dlgusgh
« Reply #49 on: Sat, 05 December 2020, 22:13:43 »
Well, the LE results aren't out yet (I think and I hope because if they are, then I took the L) and the Standard GB runs until the 20th, so it probably might take some time.
