Author Topic: [GB] Monarch (WKL 65, knob, interchangeable inserts) EXTRAS AVAILABLE!!!!  (Read 82701 times)
Offline james97
Re: [GB] Monarch (WKL 65 w/ arrow cluster, knob, interchangeable inserts)
« Reply #150 on: Tue, 15 June 2021, 21:15:19 »
Nice work you guys. I am late for the group buy but looking forward to seeing the nexto nes  :)
Offline hyppialonso
« Reply #151 on: Fri, 18 June 2021, 11:48:31 »
Finally got my monarch!
Will there be a build guide? Or basically is it okay if I just follow Taeha video to build?
Also, the JSON file for VIA Design Tab in the website is not working for download.
Offline DoCallMeKing
« Reply #152 on: Fri, 18 June 2021, 13:41:17 »
Glad it arrived for you!
Sorry but we don't have a build guide to offer at the moment.
Most of it should be straightforward like any other build, but we do recommend inserting the JST cable into the pcb before soldering since it can get a little tight right there once a switch is installed.
As for the JSON file, you shouldn't need it since VIA is updated to contain Monarch now.
We do recommend that you download the file called "BIN file for flashing" and flash that firmware to the pcb so the encoder is more precise, accurate, and consistent.
If you have any problems or questions just let us know.
Thanks a lot!
Offline prototype26
« Reply #153 on: Fri, 02 July 2021, 11:06:27 »
I am selling brass limited edition white with extra insert and some other extras. PM if interested.
« Last Edit: Fri, 02 July 2021, 11:27:08 by prototype26 »
« Reply #154 on: Wed, 21 July 2021, 19:45:49 »
Extras have dropped!!
We wanted to push them out secretly like a new album drop, so get em' while they're hot!!
www.kingkbs.com
Some buyers mentioned that it was difficult to see which configurations were still available so we updated the website to better reflect where the extras were located and the still available options.
Sorry for the confusion and thanks again!!
Have a great day!
Offline cricket-alone
Love that knob!
Offline olsen34
Good guy king, no markup for the extras.
Thanks! We want to be a company of the community since we're a part of it too and don't believe that we should try to maximize profits at all costs.
We just want to share some cool and fun designs with everyone.
