Author Topic: [IC] 🐒 Binary_Monkey - 3key macropad | Delivery Start !!!  (Read 25336 times)
Offline JKDLAB.
« on: Sun, 06 December 2020, 07:20:10 »
🙊Binary_Monkey
3Key Macropad, Inspired by Monkey
Hello, this is JKDLAB®.
We decided to commence our first project of 2021 as BINARY_MONKEY.
Binary_Monkey has the minimum elements of a keyboard that a programmer would require.
Theoretically, you can process any project with this single keyboard, which applies to every programmer, graphic designer and OSU player.
Binary_Monkey has been designed with great details; a compact body smaller than 5cm and 42mm PCB.
Our signature option, brass weight backplate, is provided after the careful mirrored finishing.
3-key-Binary_Monkey provides 3 different modes of input which are;
1. Binary input
2. Expanded ASCII code binary input
3. Key macro input which can be customized through QMK as well as your own tool
Including Monkey_Brown (our signature colour), there are 4 total options possible which are; 1) Monkey_Brown, 2) Retro_Gray, 3) Black and Orange, and 4) Black.
As an additional option, you may order Keycaps for DSA Profile and Brass weight backplate which PVD mirror finishing has been applied.
Pre-order is going to be opened for a month, starting on 22nd January to 22nd February.
You may pre-order Binary_Monkey on our official online store.
SPECIFICATION
  • Size : 48*48mm
  • Color : Monkey brown, Retro Gray, Black and Orange, Black
  • Weight : about ~90g, about ~140g(with Brass Plate)
  • Meterial : Aluminum 6063(Upper Case)(Bottom Case)(Plate), Brass(Brass Plate)
  • PCB info :1.6T, Black, 3Key Hotswap socket, Atmega32u4, Micro 5Pin USB C, QMK, Customized KeyMapping Program, ISP for AVR Programmer/Hacker
  • Price : 60 USD, 20 USD(Keycaps), 15 USD(Brass Plate)
  • MOQ : 100
[IC] FORM : https://forms.gle/8vg4E3AqRgRQV9iy9
INSTAGRAM : https://www.instagram.com/jkdlab_official/
DISCORD : https://discord.gg/VUWd4857cs
Dec.12.07 update:
Accepting some of your opinions, we started to work on C-type version for Binary Monkey!
Thanks for your considerate feedbacks, and we are always willing to get any feedbacks. Thanks!
Dec.12.24 UPDATE
We Makes Final Design of C type versions!
3D printed Mock-up
Monkey Brown
Retro Gray
Black and Orange
Black
JKD Orange Plate
Retro Gray Plate
Black Plate
OPTION : BRASS PLATE
OPTION : Keycaps
« Last Edit: Wed, 31 March 2021, 15:41:14 by JKDLAB. »
Offline keyboardbad
Re: [IC] Binary_Monkey - 3key macropad
« Reply #1 on: Sun, 06 December 2020, 07:37:51 »
Budget RAMA.
Offline Sonbadak
« Reply #2 on: Sun, 06 December 2020, 07:40:09 »
awesome! so cute!
Offline kw88
« Reply #3 on: Sun, 06 December 2020, 07:53:00 »
the whole laboratory, specialized in macropads, very nice  :thumb:
Offline powwu
    • Discord
« Reply #4 on: Sun, 06 December 2020, 08:05:11 »
Interesting!
Not sure if it'll hit 500 MOQ though, it seems too niche... GLWIC
Offline JKDLAB.
« Reply #5 on: Sun, 06 December 2020, 08:13:33 »
Interesting!
Thanks for reminding me.
I changed the wrong numbers :)
Offline JKDLAB.
« Reply #6 on: Sun, 06 December 2020, 08:44:23 »
Offline Xonuss
« Reply #7 on: Sun, 06 December 2020, 10:18:00 »
This looks very nice! A bit sad it's runs micro USB tho, no change on USB C?
Offline Ireris
  • p a i n
« Reply #8 on: Sun, 06 December 2020, 10:26:39 »
Micro usb will be deal breaker for me
Sent from my Pixel 5 using Tapatalk
Offline JKDLAB.
« Reply #9 on: Sun, 06 December 2020, 10:32:51 »
Yes, It runs with micro 5Pins. Because it's really compact and tiny. there is not enough space for USB C ;( (if i have just 1~2mm in my board, i will put it inside)
My next Products will be include USB C
Offline paperassgasket
« Reply #10 on: Sun, 06 December 2020, 12:32:46 »
Usb micro and no QMK is a pass for me.
Design is super cute though. I love the "budget RAMA" look.
GLWIC
Offline Ireris
  • p a i n
« Reply #11 on: Sun, 06 December 2020, 12:36:07 »
GLWIC
Yea same, guess I'll wait for round 2
Offline JKDLAB.
« Reply #12 on: Sun, 06 December 2020, 12:48:19 »
GLWIC
We compatiable with QMK and i forgot to write it, and i fix it!
our customizable tool based on QMK with and it make key setting more easier! thanks for waiting next round
I think i need modify my design and make C type version now :) thank you!
Offline Congree
« Reply #13 on: Sun, 06 December 2020, 13:43:31 »
Very cute, would definitely join if it was USB C, unfortunately not with micro. Will follow for next version!
Offline firewrath9
« Reply #14 on: Sun, 06 December 2020, 15:43:32 »
i love rama
Offline JKDLAB.
Re: [IC] Binary_Monkey - 3key macropad | UPDATE - C TYPE
« Reply #15 on: Mon, 07 December 2020, 05:35:48 »
Dec.07 UPDATE
Offline donny_pete
« Reply #16 on: Mon, 07 December 2020, 11:24:30 »
Yeah I'm gonna need one of these lol :thumb:
Offline harlekein
« Reply #17 on: Mon, 07 December 2020, 13:54:48 »
No QMK on a macropad is a deal breaker for me.
Offline JKDLAB.
« Reply #18 on: Mon, 07 December 2020, 22:36:25 »
Binary_Monkey can use QMK! also we make own custom programs! You can choose what you want to use. 🐵
« Last Edit: Mon, 07 December 2020, 22:41:24 by JKDLAB. »
Offline JKDLAB.
Re: [IC] Binary_Monkey - 3key macropad | UPDATE - C TYPE RENDER
« Reply #19 on: Thu, 24 December 2020, 05:22:58 »
Dec.12.24 UPDATE
3D printed Mock-up
Come and see our works!
Offline harlekein
« Reply #20 on: Thu, 24 December 2020, 08:19:16 »
Okay, great!
Offline JKDLAB.
Re: [IC] 🐒 Binary_Monkey - 3key macropad | See you at GB!
« Reply #21 on: Tue, 05 January 2021, 03:12:45 »
🐵We have reached the MOQ in IC!
Now we're going to move on to GB round!
See you at GB!
Offline JKDLAB.
Re: [IC] 🐒 Binary_Monkey - 3key macropad | Pre-order starting soon!
« Reply #22 on: Wed, 20 January 2021, 09:09:41 »
1. Binary input
« Last Edit: Tue, 02 March 2021, 03:43:01 by JKDLAB. »
Offline i luv chuletas
« Reply #23 on: Wed, 20 January 2021, 11:08:44 »
Uff would definitely pick one up, they look sick dude!
Offline JKDLAB.
« Reply #24 on: Thu, 21 January 2021, 10:44:15 »
Thanks for your words  ;)
Offline dimamantra
  • | (• ◡•)| (❍ᴥ❍ʋ)
« Reply #25 on: Thu, 21 January 2021, 22:54:34 »
Maybe I missed it, is there a physical prototype that has been made?
I also wasn't able to find a link to the "official store". Kind of weird since the GB starts tomorrow...
Offline RIFT
    • RiftKeys
« Reply #26 on: Thu, 21 January 2021, 23:39:32 »
Hey are we able to get an update on this, Interested in it but says the website is still under construction.
Offline JKDLAB.
« Reply #27 on: Fri, 22 January 2021, 00:53:40 »
I'm sorry to have kept you waiting.
The Pre-Order website will open at 13:00 GMT.
Considering the fact that this quantity is not much, we are producing color chips first to match the color we want rather than the initial quantity production with a high amount.
BrassWeight Plate : PVD + Mirror finishing
Anodizing Color chips
For JKD ORANGE color, it will be changed to powder coat version.
As soon as the pre-order is properly prepared, we will contact SMT and the processing plant to order the initial quantity.
The version you see in the picture is the micro 5pin version.
Due to a different modification than we expected in the beginning when it was changed to C type, the prototype that we already had was not available.
The work seems to be delayed, but we are working on it with the goal of delivery in March.
Thank you for your interest in binary_monkey.
For those who participated in the internest check, which is scheduled to end soon, we are preparing a small but secret gift that we can prepare.
Please participate in Interest Check before Pre-Order starts!
« Last Edit: Fri, 22 January 2021, 02:31:35 by JKDLAB. »
Offline JKDLAB.
Re: [IC] 🐒 Binary_Monkey - 3key macropad | Pre-order OPEN!!
« Reply #28 on: Wed, 10 February 2021, 04:39:34 »
🙊Binary_Monkey
1. Binary input
« Last Edit: Tue, 02 March 2021, 03:43:15 by JKDLAB. »
Offline MIGHTY CHICKEN
« Reply #29 on: Wed, 10 February 2021, 13:28:46 »
Me like, glwic!
Offline JKDLAB.
Offline JKDLAB.
Re: [IC] 🐒 Binary_Monkey - 3key macropad | ON PRODUCE!!
« Reply #31 on: Tue, 09 March 2021, 16:14:48 »
🙊Binary_Monkey
We are on produce!!
Offline Ustinj
« Reply #32 on: Tue, 09 March 2021, 16:16:55 »
I like it. Glad to see an update
Offline JKDLAB.
« Reply #33 on: Wed, 10 March 2021, 05:11:53 »
we will start delivery them next week!
Offline Xury46
« Reply #34 on: Wed, 31 March 2021, 15:17:48 »
I love this, are there any keycaps left? I don't see them as an option on GumRoad.
Offline JKDLAB.
« Reply #35 on: Wed, 31 March 2021, 15:25:30 »
I put down the product for a while because it interfered with production. Keycap products will be registered again within a day or two. :D
For keycaps, delivery will begin in mid-April.
Contact us via Discord to hear back faster.
discord link : https://discord.gg/VUWd4857cs
Offline audiosl4ve
  • Just slave
Re: [IC] 🐒 Binary_Monkey - 3key macropad | Delivery Start
« Reply #36 on: Wed, 31 March 2021, 15:30:55 »
oh nice, Osu! board  ;D
Offline JKDLAB.
« Reply #37 on: Wed, 31 March 2021, 15:34:53 »
Offline JKDLAB.
« Reply #38 on: Wed, 31 March 2021, 15:40:39 »
Binary_Monkey Delivery Started!!!
The first shipment has been delivered.
We still have stock left, so please purchase it at this link :)
Offline Cubic // esc lab
  • Formerly 'esclab'
    • esc lab
Re: [IC] 🐒 Binary_Monkey - 3key macropad | Delivery Start !!!
« Reply #39 on: Wed, 31 March 2021, 18:44:54 »
Soooo cute. Very reasonable price too. Gonna grab one.  :thumb:
EDIT: In your product page, I don't see an option for the keycaps?
« Last Edit: Wed, 31 March 2021, 18:50:37 by loop | esc lab »
Offline JKDLAB.
« Reply #40 on: Wed, 31 March 2021, 19:01:05 »
thanks :) 🥰
  • Formerly 'esclab'
    • esc lab
« Reply #41 on: Wed, 31 March 2021, 19:08:53 »
thanks :) 🥰
How do I get the keycap set?
Offline JKDLAB.
« Reply #42 on: Wed, 31 March 2021, 20:27:47 »
thanks :) 🥰
This is our Key Cap Packaging Sample :)
We are printing the key cap ourselves, and there was a problem while printing, so we postponed the delivery of the key cap until April.
Currently, the product is down on the product page to notify you about the delivery.
The keycap set will be uploaded back to Gumroad within 1~2 days.
Keycaps will be delivered separately in mid-April.
Offline Xury46
« Reply #43 on: Wed, 31 March 2021, 20:39:13 »
Awesome, thanks for the update!
Offline JKDLAB.
« Reply #44 on: Wed, 31 March 2021, 20:46:55 »
thanks to read :)
Offline Xury46
« Reply #45 on: Wed, 27 April 2022, 16:49:30 »
I ordered off of Gumroad and it never showed up. Are there any updates on this project?
« Reply #46 on: Sat, 23 July 2022, 17:38:02 »
Yeah I just wrote this off as burnt money, never received a thing.
