Author Topic: [IC] GMK Gateway | SET LIVE - GB THREAD SOON  (Read 47568 times)
Offline elmo
  • Hello I like keyboards
    • Elmo's keyboards
Re: [IC] GMK Gateway | GB DATE ANNOUNCED
« Reply #50 on: Thu, 17 December 2020, 07:14:27 »
I see on your colors sheet that you have labeled WS2 as #FFFFFF. Considering that this is a nearly impossible color to achieve on plastic as it is legitimately pure white, there is no way that this is the representative hex for WS2. Having spoken with GMK about this, #F6F5F5 is more representative of WS2. If you used #FFFFFF for your renders, your renders may not be great representations of the color in person.
RGB color codes are never representative of a plastic color because it always change with the lighting on the picture.
Especially for white plastic.
Offline SMOKEY
« Reply #51 on: Thu, 17 December 2020, 08:53:26 »
Thanks for pointing it out. That's a placeholder that slipped through.
Renders are done the right way, looking at Stormtrooper / Monochrome whilst.
I will correct the HEX, thanks again.
But please be aware, that HEX / RGB codes are never representative of a plastic color.
Offline SMOKEY
« Reply #52 on: Thu, 17 December 2020, 14:45:42 »
| FORMS BOXART-123765478-22:
Offline Witters
« Reply #53 on: Fri, 18 December 2020, 18:02:06 »
Love the set! Is there any plans for more kits, for instance ergo/ortho? I would really love to get the option to use this with my Corne. If there are no more sets coming, is it inadvisable to use R1 and R4 on R2 and R3 (since there are no orange 1u accent keys).I have never used a sculpted set before, and would like to know how big of a tradeoff it is. Nonetheless, GLWGB!
Offline obzkure
  • Mode Designs
« Reply #54 on: Sat, 19 December 2020, 09:50:40 »
Great work with the set, it is refreshing color combo that will stand out. Looking forward to picking up a few sets.
Offline SMOKEY
« Reply #55 on: Tue, 22 December 2020, 02:04:42 »
40s / Ergo / Ortho is extremely difficult to run with this set, because of the split colors.
That rightaway means you can not reuse a lot of keys from the base kit for 40s.
For example, you would have to have an extra 1.75u and 1.25u Shifts just for the alternate colors.
I just don't think that is feasible to run, so I opted against it.
And yes, I would  not advise using keys from different rows in different rows.
Offline SMOKEY
« Reply #56 on: Sat, 26 December 2020, 14:40:21 »
Just a quick heads up:
After today's events, revolving around the allegations made against MUBAI / enoch_xu, effective immidiate this collaboration will not happen.
He is said to be the middle man for some dumb dumb chinese "makers"  who are cloning many maker's honest work and said to be in a very close 1:1 quality.
Some of the 'works' include CYSM, Artkey Universe, Brocaps, Alpha Keycaps etc.
I, myself, am a artisan collector. Faking, buying, selling and trafficking fake artisans is not cool!
Please buy and trade responsibly!
« Last Edit: Sat, 26 December 2020, 14:45:44 by SMOKEY »
Offline SMOKEY
« Reply #57 on: Fri, 01 January 2021, 07:05:23 »
| FORMS KEEBSTUFF-739520667-18:
| [FILE LOADING...
| [INSPECTING TEST SUBJECT X...
| [INSPECTING TEST SUBJECT Y
| [STATUS: STILL ALIVE
| [EXIT
| TECH DETAILS
  • Cable is USB 2.0, 2x AWG24 wire (power), 2x AWG28 wire (data), double shielded
  • Cable diameter 4.5mm, coil inner diameter 10mm
  • mdpc-x is a uv-stable PET material produced in germany, similar to techflex but tighter meshed
  • 4-pin connectors from Weipu are grounded on 1 side
| TEST SUBJECT X DETAILS
  • ~20cm coiled USB C device end, sleeved in mdpc-x Oxide Orange
  • ~1.8m straight USB2.0 A host end, sleeved in mdpc-x B-Magic
  • Weipu SA12 push-pull connector, black
  • black shrinks
| TEST SUBJECT Y DETAILS
  • ~20cm coiled USB C device end, sleeved in mdpc-x B-Magic
  • ~1.8m straight USB2.0 A host end, sleeved in mdpc-x Oxide Orange
  • black shrinks
« Last Edit: Fri, 01 January 2021, 07:36:51 by SMOKEY »
Offline SMOKEY
« Reply #58 on: Wed, 06 January 2021, 06:57:46 »
Cypher by Cable Car Designs
Offline SMOKEY
Re: [IC] GMK Gateway | KEEBSTUFF PROTO PICS & MORE RENDERS
« Reply #59 on: Wed, 13 January 2021, 05:28:12 »
Offline Ella
  • Why is it called an oven
Re: [IC] GMK Gateway | LESS THAN 2 WEEKS TO GB
« Reply #60 on: Thu, 14 January 2021, 04:08:15 »
This set looks really good, I just hope Valve won't send you a C&D
Offline SMOKEY
« Reply #61 on: Sun, 17 January 2021, 15:13:05 »
Offline SMOKEY
« Reply #62 on: Mon, 18 January 2021, 03:11:01 »
Offline harlekein
« Reply #63 on: Mon, 18 January 2021, 06:56:21 »
Check this out for alt layouts: https://geekhack.org/index.php?topic=110077.0
Offline w1ntermute
Re: [IC] GMK Gateway | ONE WEEK TO GB
« Reply #64 on: Wed, 20 January 2021, 07:43:31 »
Absolutely love it!
Offline ClickClack919
« Reply #65 on: Tue, 26 January 2021, 18:53:24 »
Today's the day for the GB to open, right? I don't see it on Kono yet, maybe running slightly behind?
Offline KambingSuSu
« Reply #66 on: Tue, 26 January 2021, 19:02:45 »
Maybe render this set on an Alice and look back at your kitting.
Offline w1ntermute
« Reply #67 on: Tue, 26 January 2021, 19:04:55 »
Same with Deskhero.ca in Canada. Haven't seen any reason it's being delayed.
Offline metreo
« Reply #68 on: Tue, 26 January 2021, 19:10:11 »
I love these color profiles they are so modern and classic, very nice, the `IT IS A LIE` key for backspace I'm thinking
Offline w1ntermute
« Reply #69 on: Tue, 26 January 2021, 19:14:27 »
Yeah, I love it! Sneaky clever yet not infringing on the source inspiration.
Offline SMOKEY
« Reply #70 on: Tue, 26 January 2021, 22:29:06 »
GB Thread is being prepared right now.
Set is LIVE in US, EUROPE, AUSTRALIA, CANADA and KOREA.
ASIA following shortly.
We had a slight delay, bc GMK sent the quotes kinda last minute due to their heavy work load.
« Last Edit: Tue, 26 January 2021, 22:30:46 by SMOKEY »
Offline w1ntermute
« Reply #71 on: Tue, 26 January 2021, 23:00:06 »
Ordered!
