Author Topic: Lubing Box Jades?  (Read 11401 times)
Offline CamTheKid22
Lubing Box Jades?
« on: Wed, 09 December 2020, 02:03:00 »
I'm fairly new to mechanical keyboards, I mean I've had one for years (currently the duck one 2 full-size), and have always loved clicky switches. Not a huge fan of liner switches, as I love having tactile feedback. Recently I ordered a set of Kailh Box Jades for the Keychron K4 that I ordered recently as well, and was wondering if it was a good idea to lube them. I've heard that it's not a good idea to lube cherry blues, as you can pretty much take away the clicky sound, but I was curious if it would be different with box jades, as they use a spring bar, and I assume that wouldn't be near as affected as blues. I just want a very smooth switch with a nice satisfying click.
clicky switches best switches
Offline treeleaf64
    • treeleaf64
Re: Lubing Box Jades?
« Reply #1 on: Wed, 09 December 2020, 15:50:14 »
Don't need to lube, they come factory lubed and are smooth enough stock in my opinion.
Everyone must pay the cat tax
Offline Leslieann
« Reply #2 on: Wed, 09 December 2020, 21:09:06 »
Lubing my stems did nothing.
The clicker was pre-lubed quite well in mine.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline Zlax
« Reply #3 on: Tue, 22 December 2020, 18:32:31 »
Don't lube it, the switch will lose the tactility, they already have a good touch from factory.
Offline ddrfraser1
  • RIP Neil
« Reply #4 on: Tue, 22 December 2020, 20:37:11 »
I lubed the springs on my pinks and very very lightly lubed the sliders - as in I basically handled the sliders with my fingertips which had lube residue on them and that tiny bit was enough. Excellent results I say.
Offline lakeboredom
« Reply #5 on: Tue, 22 December 2020, 20:57:12 »
Lubing the bottom and top out points improves the sound on BOX switches a lot. Obviously you shouldn't lube the clickbar. I'd say hitting the stem is optional, since it can put lube onto the box which rests outside the housing and may collect dust.
