Author Topic: What Keyboard Cases Do You Use/Recommend?  (Read 3820 times)
Offline Band1t
« on: Thu, 17 December 2020, 19:51:26 »
I was wondering what kind of cases people use/like because my knowledge on them is very limited. I would say that the only cases I really know about are the Tofu ones from KBDFans and the NK65. However, I'm very interested in cases like the ones below, I just don't know which ones they are:
As an extension, what case(s) do you use and why do you like it?
Thanks for any responses!
Offline _rubik
Re: What Keyboard Cases Do You Use/Recommend?
« Reply #1 on: Thu, 17 December 2020, 20:08:32 »
Are you asking about cases specifically (because there are lots of those and many are quite similar) or are you asking more about layout?
Seems like you're attracted to 65 - 80% boards, don't have a preference for a function row, like arrow keys, and like a single column nav cluster.
Offline Band1t
« Reply #2 on: Thu, 17 December 2020, 20:29:29 »
I'm asking more about cases specifically, but I would definitely be more interested in cases that are 65-80%.
Offline PTRS
« Reply #3 on: Mon, 21 December 2020, 06:03:22 »
acrylic
« Reply #4 on: Mon, 21 December 2020, 07:17:33 »
Take off the top shell and use it naked.
- D Trump 2026-10-24
Offline Darthbaggins
  • PC Cannibal
« Reply #5 on: Mon, 21 December 2020, 08:12:23 »
Naked boards are fun to use,  :cool:
Offline Engedi_
« Reply #6 on: Sat, 26 December 2020, 17:13:54 »
The 65% looks like Tsukuyomi.
The second one looks very similar to GMMK Pro which has not been shipped yet...
I know it's not, but basically no difference.
Depends if you like 60%, 65%, 75%, TKL or even full.
Offline dingusxmcgee
« Reply #7 on: Sat, 26 December 2020, 20:17:02 »
The first one is Nemui. They share a very similar blocker(crescent moon) but Nemui has the sleepy Z’s.
