Author Topic: [IC] Venn - 65% keyboard (AVAILABLE INSTOCK @ TYPEPLUS)  (Read 299351 times)
Offline SurfGalaxy
Re: [IC] Venn - 65% keyboard (Proto build stream Jan 13th 10pm PST)
« Reply #100 on: Mon, 11 January 2021, 18:58:48 »
Looks promising. Any possibility of a top right badge? Loved the one on the 7V.
Offline Livid
« Reply #101 on: Mon, 11 January 2021, 20:12:27 »
Where? He would have to change the layout
Offline nxxinf
« Reply #102 on: Tue, 12 January 2021, 00:30:55 »
Hotswap PCB? :)
Offline ReverbSlush
  • 16/52 RNG score
« Reply #103 on: Tue, 12 January 2021, 10:17:39 »
Do we know which will come first between this or Type K?
Offline gok_nz
  • Enjoy your PBT
    • Website
« Reply #104 on: Tue, 12 January 2021, 12:49:24 »
Really enjoying the large chamfered edges, along with weight design seen from the back it looks gorgeous.  I second those saying a burgundy color way
Ooo burgundy and green both insta cop
Sent from my SM-G965U1 using Tapatalk
V2 prototype has been ordered in burgundy. I will see how I feel about it after seeing it in person.
I have ideas of how this could be executed but I think I'll be going for no corner blocker.
Will the pcb come with rgb backlighting if not, can it? Also suggesting a dark blue case would be sweet for this
It doesn't come with back lighting. It will come in the same blue that was used for the 7V.
Hotswap PCB? :)
I believe that there will be hotswap versions of the graphite PCBs.
They are basically running in parallel and I don't know which one will finish first.
Reminder that there will be a build stream of the green prototype tomorrow on Epsilon keyboards stream. Link and details in the OP.
Offline KZzzz
« Reply #105 on: Tue, 12 January 2021, 16:02:32 »
What plate materials have you been experimenting with? Which one do you think provides the best typing experience with the leaf spring mounting? I personally never own a leaf spring mounted board, so I am a bit curious.
Offline keystream
    • keystream.me
« Reply #106 on: Tue, 12 January 2021, 16:16:51 »
Looks exceptionally good. Would be in if I didn't already have a 65% on order. Really wanted to get in on 7V too, but I will try to get in on Type K  ;D
Who wont be trying to get the type k, it is such an amazing board. GL   :D
Offline gok_nz
  • Enjoy your PBT
    • Website
« Reply #107 on: Wed, 13 January 2021, 01:09:14 »
Alu, POM and polycarbonate. I will likely go with POM. The idea is to have a really flexible material so that the alphas can be bouncier without going half-plate. The plate has a lot of mounting points which would usually over-stiffen the plate but the leaf-springs offset this. For the revised plate, I went with more but longer leaf-springs to make the typing feel more consistent.
Also, a reminder that the proto build stream is happening tomorrow on Epsilon keyboard's stream.
Offline kbye
« Reply #108 on: Wed, 13 January 2021, 12:50:54 »
The rainbow PVD looks amazing, I hope this makes it into GB
Looking forward to the proto stream
Offline XiXora
« Reply #109 on: Thu, 14 January 2021, 20:27:28 »
Will there be an ISO plate available too?
Offline tsara27
    • Personal Blog
« Reply #110 on: Thu, 14 January 2021, 20:43:24 »
When I look into this board, I fall in love instantly.
I hope venn65 will do unlimited group buy.
Offline SekaiJutsu
    • GeekHack
« Reply #111 on: Fri, 15 January 2021, 01:17:04 »
Great Proto stream, so excited for this board! Hope burgundy turns out great!
Is there a discord to follow more along?
Offline hottrout
  • I'd Hit Dat Key
« Reply #112 on: Fri, 15 January 2021, 06:44:15 »
Very interested if there will be an ISO PCB and plate.  Clean lines and good colours.
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
Offline KZzzz
« Reply #113 on: Fri, 15 January 2021, 17:43:43 »
Awesome, that's interesting. I will try POM plate, which would be new to me.
BTW, this is a question regarding the pcb: does it support usb-c to usb-c connection? It's a minor feature, but I want to ask for good measure.
Offline JCraftCables
    • Instagram
« Reply #114 on: Sat, 16 January 2021, 03:52:14 »
Really like the back design and very clean overall!
Offline thebreadsaver
« Reply #115 on: Sat, 16 January 2021, 04:09:07 »
it's...beautiful :')
Offline gok_nz
  • Enjoy your PBT
    • Website
« Reply #116 on: Sat, 16 January 2021, 04:16:23 »
This is an option that I really want to offer but I will need to treat it similarly to the 7V PVD weight and only offer it as an extra as opposed to an optional upgrade. It will probably also be really expensive.
It should either be a high cap or unlimited.
I need to think about this. With the plate being so flexible, I don't want to have a universal cutout that supports both ansi and ISO on the same plate and I'm not sure if I want to double the number of sku's. At the very least, I would post the plate file so you could get your own made.
There isn't an official discord because I don't want to manage a server but Epsilon keyboards has a channel dedicated to it here.
The PCB supports ISO but not sure if I will offer am ISO plate. I elaborate on it in the reply above.
I'll need to test this with my mobile phone when I get the proto back from Epsilon.
Offline Xeryn
Re: [IC] Venn - 65% keyboard (16/01/2021 STATUS UPDATE)
« Reply #117 on: Sat, 16 January 2021, 15:36:56 »
Nice to see the rainbow PVD weight added as an extra! Also hoping the burgundy turns out well, +1 interest for the burgundy color.
Will there be any builds/test with a polycarbonate plate? Curious to see hear how the flex consistency is on a sandwich poly plate is.
Offline CookieFlow
« Reply #118 on: Sat, 16 January 2021, 17:02:50 »
That back view is truly gorgeous.
Just a bit sad that the best angle is not the one you get to see during use.
Personally a bit torn on the current 2 color offerings, light silver is not my cup of tea.
Olive is a very nice shade, but probably a bit limiting for which keycaps would work well with.
Looking forward to the potential Burgundy, or a more neutral color. I would have really liked to see a dark grey, I believe would look incredible with the rose gold weight (can't go wrong with black, but I don't often see Dark Grey (something like Apple's Space Grey)).
Hoping the Rose Gold PVD stays as it looks fantastic.
(Kinda secretely hoping this GB isn't too soon, as Q1 is very loaded already)
« Last Edit: Sat, 16 January 2021, 21:26:41 by CookieFlow »
Offline sup3r170va
« Reply #119 on: Sat, 16 January 2021, 19:45:57 »
I hope the rose gold PVD back weight is still an option. The update says polished SS but doesn’t say if it’s coated :)
Offline afynyth
« Reply #120 on: Sat, 16 January 2021, 20:21:37 »
Is there a possibility of a black color? Silver doesn't fit with some keysets sometimes, and it would be nice to have a color neutral option. The green on Epsilon's VOD looked very nice though!
Offline deedz
« Reply #121 on: Sat, 16 January 2021, 20:37:30 »
I agree! Was a bit bummed to see no mention of the polished rose gold. Hopefully it is still being considered as an offering!
Offline tsara27
    • Personal Blog
« Reply #122 on: Mon, 18 January 2021, 17:56:10 »
You made my day! Save money now and go for the venn 65 later this year!  ;)
Offline nettik
« Reply #123 on: Mon, 18 January 2021, 21:19:36 »
+1 for the rose gold! It's too pretty to not be an option
Offline soloplayer
« Reply #124 on: Mon, 18 January 2021, 22:38:19 »
how much do the brass and ss accent cost compared with aluminum accent? brass accent with brass weight would be dope
Offline Ranger_Trivette
« Reply #125 on: Mon, 25 January 2021, 07:36:51 »
nice!
Offline Gnome
« Reply #126 on: Mon, 25 January 2021, 11:36:13 »
This looks great. I really dig the design, looks super clean. I know you said you didn't want to do an E-white but an e-white with that rainbow weight would look heavenly. As a newcomer i would appreciate a hotswap version so i will be crossing my fingers and wait.
Is there a discord server or something similar to follow the updates?
Offline Hellenic94
« Reply #127 on: Wed, 27 January 2021, 14:37:10 »
Hotswap is not offered usually on Gok boards. Learn to sold millmax its very easy.
Offline gok_nz
  • Enjoy your PBT
    • Website
« Reply #128 on: Wed, 27 January 2021, 17:12:09 »
I don't want to offer too many colours because with there being 3 parts that can be interchanged, SKUs get a bit crazy.
I'll probably just be testing it myself so no streamed builds of this.
I will probably only offer 1 PVD option and I'm leaning towards rainbow at the moment because it is more unique. Plain polished stainless steel has yielded nicer surface finishes in my experience.
Pricing TBD but it's usually quite a bit more expensive for non-plate parts.
Best place to follow updates is actually here. I try to keep the status up to date. If there hasn't been anything new posted, that probably means that I am still waiting for things to arrive.
Offline sup3r170va
« Reply #129 on: Thu, 28 January 2021, 07:54:51 »
Thanks for answering. Not sure how others feel, but I think rose gold PVD is a more classic and timeless option than rainbow PVD, notwithstanding that the latter is more “bling”. Exudes more class IMO. hope u reconsider. Thanks.
Offline Zeelobby
« Reply #130 on: Thu, 28 January 2021, 08:17:36 »
I dunno, Jane V2 CE pretty classy. Bring on the rainbow! There's enough rose gold elsewhere.
Offline Livid
« Reply #131 on: Thu, 28 January 2021, 12:30:14 »
Rainbow is definitely the right choice here
Offline CookieFlow
« Reply #132 on: Thu, 28 January 2021, 13:00:18 »
Seems to be pretty polarized.
Personally not a big fan of rainbow, looks a bit out of place on a classy board to me.
Sure we see rose gold on cases, but it's generally more pink color and on aluminum. Rose Gold PVD is totally on another level and looks so classy.
And it matched (surprisingly to me) super well with the olive green color.
Offline KZzzz
« Reply #133 on: Thu, 28 January 2021, 23:36:37 »
+1 on the rose gold PVD weight. It must be real nice with a blue case, alongside GMK Pink on Navy.
Rainbow is cool, but considering the design language of this board, it would look out of place in my opinion.
Also, it would be cool to see a black PVD weight. Though, knowing the notoriously difficult process of production and QC for PVD parts, it probably won't happen.  :'^(
« Last Edit: Thu, 28 January 2021, 23:38:56 by KZzzz »
Offline deedz
« Reply #134 on: Fri, 29 January 2021, 00:49:17 »
On a classy board, I agree. The rose gold PVD definitely seems more fitting when comparing the rainbow to the rose gold from the pictures.
Offline ChiKaSama
« Reply #135 on: Fri, 29 January 2021, 09:00:08 »
It looks elegant with rose gold weight, but I am sure that I will purchase the rainbow pvd weight as well. Rainbow maybe a cherry on top. Looking forward to join the group buy.
Offline light_switch
« Reply #136 on: Wed, 03 February 2021, 13:42:25 »
What other color cases are you looking to include? I would love to see an E-White option or a milky white option.
Offline j.cal0187@gmail.
« Reply #137 on: Wed, 03 February 2021, 15:24:53 »
Maaaaaybe sum purple action?
Offline holer
« Reply #138 on: Mon, 08 February 2021, 07:41:33 »
Great design and the olive green is straight fire! :D
I'll add my voice to the people requesting a ISO plate too.
Offline galdrom
« Reply #139 on: Mon, 08 February 2021, 09:16:43 »
Hoo.... gorgeous
Offline fropsie
« Reply #140 on: Mon, 08 February 2021, 10:59:23 »
Please & Thank you
Offline Que7797
« Reply #141 on: Tue, 09 February 2021, 01:21:29 »
Looks good, gok.
Offline bert039
« Reply #142 on: Tue, 09 February 2021, 09:43:14 »
Looks amazing, especially with the rose gold
Offline MQLYU
« Reply #143 on: Wed, 10 February 2021, 01:05:59 »
Love it!!!
Offline afynyth
« Reply #144 on: Wed, 10 February 2021, 19:55:55 »
Will there be "Venn" written on the bottom like in the render, or any other sort of branding on the board? The "Venn" inscription in the render looks good.
« Last Edit: Wed, 10 February 2021, 20:03:40 by afynyth »
Offline iSniper1010
« Reply #145 on: Thu, 11 February 2021, 11:36:38 »
Wow, this keyboard looks really good!
Offline JKKEEBS
« Reply #146 on: Thu, 11 February 2021, 11:45:32 »
GLWIC
Offline bert039
« Reply #147 on: Sun, 14 February 2021, 21:03:34 »
Whoa, white and rose gold is breath taking
Offline Airea
« Reply #148 on: Tue, 16 February 2021, 00:01:50 »
Would you consider an E-white version of this board? I personally feel like it would look great with the rose gold plate
Offline DannyDP
« Reply #149 on: Thu, 18 February 2021, 20:54:44 »
rose gold PVD weight / rama rose gold thermal keycap / green venn. This is the way. Please make this happen, this combo would be absolutely killer.
« Last Edit: Thu, 18 February 2021, 21:03:03 by DannyDP »
