Author Topic: [IC] Hot Swap 65% Tray Mount PCB With Nonstandard Layout  (Read 3812 times)
Offline SykesTheLord
« on: Tue, 22 December 2020, 09:48:51 »
Hello everyone, when I was getting parts for my first keyboard I noticed a surprising lack of ISO and 7u bottom rows. So I decided I would run a GB if enough people are interested. The concept is that I would make 3 different versions of the pcb. One with ISO enter and split left shift, one with 7u bottom row ANSI layout, and one with with 7u bottom row and split backspace. Would be open to any other layouts if enough people are interested.
[IC Form] https://forms.gle/gahTrh2cKiMjFisc8
« Last Edit: Tue, 22 December 2020, 10:22:31 by SykesTheLord »
Offline lukelex
Re: [IC] Hot Swap 65% Tray Mount PCB With Nonstandard Layout
« Reply #1 on: Tue, 22 December 2020, 10:45:30 »
Reserved
Sent from my SM-G975F using Tapatalk
Offline homerowco
    • Homerow.Co
« Reply #2 on: Tue, 22 December 2020, 18:35:23 »
where's the IC? that's a survey.
Offline verity
« Reply #3 on: Tue, 22 December 2020, 18:59:58 »
yes
Offline made in China
« Reply #4 on: Tue, 22 December 2020, 19:19:37 »
I think this is not a lot of welded  case can do it?
