Author Topic: DZ60: Keys on third row suddenly send all keys in same column  (Read 2068 times)
Offline hanzoh
« on: Sun, 27 December 2020, 09:32:38 »
Hello,
I have assembled a DZ60 3.0 PCB with alu plate and alu case last year and suddenly have the following issue now (keyboard has been working fine for months after assembly):
Pressing any keys in rows 1, 2, 4 or 5 is working as expected.
Pressing a key in row 3 however leads to this (added quotes when there is also a space in there):
a: 2qay
s: 3wsx
d: "4edc "
f: 5rfv
g: "6tgb "
h: 7zhn
j: "8ujm "
k: 9ik,
l: 0ol.
I remember that some time before, I felt a zap when touching the keyboard, like when you touch someone and you were statically charged before,
could this be related and what could this have damaged?
I visually examined the board on the back, but could not see any burnt components.
Measuring the diodes with a multimeter also seemed to be fine, although I'm no expert on that front (testing electronic components).
I would appreciate if someone has an idea how to find out what the issue is and if this can be fixed.
Kind regards
hanzoh
Offline Sup
Re: DZ60: Keys on third row suddenly send all keys in same column
« Reply #1 on: Sun, 27 December 2020, 15:53:01 »
Did you try to reflash it? I had this with DZ60 REV 1 a long time ago.
current
Coming soon
Offline hanzoh
« Reply #2 on: Sun, 27 December 2020, 15:59:12 »
Yes, I reflashed the default DZ60 ANSI layout and also my layout with directional keys,
issue is still the same.
« Reply #3 on: Wed, 30 December 2020, 10:45:02 »
Hi hanzoh, and welcome to geekhack.
If you shocked the PCB you could have killed a pin on the controller which could do this.
There are so many different 'DZ60' PCBs out there that I can't attempt to guess which pins might be unused on yours to suggest a fix, where are you getting the firmware from?  Assuming it's QMK the file I'd like to read is config.h if you have one.  Hopefully not an over-helpful website which shows nothing useful...
